Thank you Ogiewon for all of your effort on this project! I got my LinkNodeR8 up and running based on the LinkNode R4 code you included in the package. I had a **** of a time getting the children to populate but after leaving the boot jumper off and/or rebooting the ST hub, she chooched!
Here’s the final LinkNode R8 code I used if anyone else wants to play along. Relays correspond to switch numbers 1 - 8, top to bottom, left to right. I used NodeMCU 1.0 (ESP-12E Module) as the board in the IDE.
// File: ST_Anything_LinkNodeR8_ESP8266WiFi.ino
// Authors: Dan G Ogorchock & Daniel J Ogorchock (Father and Son)
// Summary: This Arduino Sketch, along with the ST_Anything library and the revised SmartThings
// library, demonstrates the ability of one LinkNodeR8 ESP8266 to
// implement a multi input/output custom device for integration into SmartThings.
// The ST_Anything library takes care of all of the work to schedule device updates
// as well as all communications with the LinkNodeR8 ESP8266's WiFi.
// ST_Anything_LinkNodeR8 implements the following Capabilities as a demo of what
// is possible with a single LinkSprite LinkNode R8 board
// - 8 x Switch devices (used to turn on a digital output (e.g. LED, relay, etc...)
// Board Programming details available at: http://www.linksprite.com/wiki/index.php?title=File:1-262-a.jpg
// Change History:
// Date Who What
// 2019-03-26 Dan Ogorchock Original Creation
// 2019-05-18 John Crusan Modified LinkNode R4 Code to support LinkNode R8
// SmartThings Library for ESP8266WiFi
#include <SmartThingsESP8266WiFi.h>
// ST_Anything Library
#include <Constants.h> //Constants.h is designed to be modified by the end user to adjust behavior of the ST_Anything library
#include <Device.h> //Generic Device Class, inherited by Sensor and Executor classes
#include <Sensor.h> //Generic Sensor Class, typically provides data to ST Cloud (e.g. Temperature, Motion, etc...)
#include <Executor.h> //Generic Executor Class, typically receives data from ST Cloud (e.g. Switch)
#include <InterruptSensor.h> //Generic Interrupt "Sensor" Class, waits for change of state on digital input
#include <PollingSensor.h> //Generic Polling "Sensor" Class, polls Arduino pins periodically
#include <Everything.h> //Master Brain of ST_Anything library that ties everything together and performs ST Shield communications
#include <EX_Switch.h> //Implements an Executor (EX) via a digital output to a relay
#include <S_TimedRelay.h> //Implements a Sensor to control a digital output pin with timing capabilities
//Define which Arduino Pins will be used for each device
#define PIN_S1 14 //LinkNode R8 Board Marking D8
#define PIN_S2 13 //LinkNode R8 Board Marking D7
#define PIN_S3 5 //LinkNode R8 Board Marking D10
#define PIN_S4 15 //LinkNode R8 Board Marking D11
#define PIN_S5 12 //LinkNode R8 Board Marking D6
#define PIN_S6 16 //LinkNode R8 Board Marking D9
#define PIN_S7 4 //LinkNode R8 Board Marking D17
#define PIN_S8 10 //LinkNode R8 Board Marking D12
//ESP8266 WiFi Information
String str_ssid = "yourSSIDhere"; // <---You must edit this line!
String str_password = "yourWiFiPasswordhere"; // <---You must edit this line!
IPAddress ip(192, 168, 1, 127); //Device IP Address // <---You must edit this line!
IPAddress gateway(192, 168, 1, 1); //Router gateway // <---You must edit this line!
IPAddress subnet(255, 255, 255, 0); //LAN subnet mask // <---You must edit this line!
IPAddress dnsserver(192, 168, 1, 1); //DNS server // <---You must edit this line!
const unsigned int serverPort = 8090; // port to run the http server on
// Smartthings Hub Information
IPAddress hubIp(192, 168, 1, 104); // smartthings hub ip // <---You must edit this line!
const unsigned int hubPort = 39500; // smartthings hub port
// Hubitat Hub Information
//IPAddress hubIp(192, 168, 1, 143); // hubitat hub ip // <---You must edit this line!
//const unsigned int hubPort = 39501; // hubitat hub port
//st::Everything::callOnMsgSend() optional callback routine. This is a sniffer to monitor
// data being sent to ST. This allows a user to act on data changes locally within the
// Arduino sktech.
void callback(const String &msg)
Serial.print(F("ST_Anything Callback: Sniffed data = "));
Serial.println(msg);
//TODO: Add local logic here to take action when a device's value/state is changed
//Masquerade as the ThingShield to send data to the Arduino, as if from the ST Cloud (uncomment and edit following line)
//st::receiveSmartString("Put your command here!"); //use same strings that the Device Handler would send
//Arduino Setup() routine
void setup()
//Declare each Device that is attached to the Arduino
// Notes: - For each device, there is typically a corresponding "tile" defined in your
// SmartThings Device Hanlder Groovy code, except when using new COMPOSITE Device Handler
// - For details on each device's constructor arguments below, please refer to the
// corresponding header (.h) and program (.cpp) files.
// - The name assigned to each device (1st argument below) must match the Groovy
// Device Handler names. (Note: "temphumid" below is the exception to this rule
// as the DHT sensors produce both "temperature" and "humidity". Data from that
// particular sensor is sent to the ST Hub in two separate updates, one for
// "temperature" and one for "humidity")
// - The new Composite Device Handler is comprised of a Parent DH and various Child
// DH's. The names used below MUST not be changed for the Automatic Creation of
// child devices to work properly. Simply increment the number by +1 for each duplicate
// device (e.g. contact1, contact2, contact3, etc...) You can rename the Child Devices
// to match your specific use case in the ST Phone Application.
//Polling Sensors
//Interrupt Sensors
//Special sensors/executors (uses portions of both polling and executor classes)
//Executors
static st::EX_Switch executor1(F("switch1"), PIN_S1, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor2(F("switch2"), PIN_S2, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor3(F("switch3"), PIN_S3, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor4(F("switch4"), PIN_S4, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor5(F("switch5"), PIN_S5, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor6(F("switch6"), PIN_S6, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor7(F("switch7"), PIN_S7, LOW, false); //Non-Inverted logic for "Active High" Relay Board
static st::EX_Switch executor8(F("switch8"), PIN_S8, LOW, false); //Non-Inverted logic for "Active High" Relay Board
// Configure debug print output from each main class
// -Note: Set these to "false" if using Hardware Serial on pins 0 & 1
// to prevent communication conflicts with the ST Shield communications
st::Everything::debug=true;
st::Executor::debug=true;
st::Device::debug=true;
st::PollingSensor::debug=true;
st::InterruptSensor::debug=true;
//Initialize the "Everything" Class
//Initialize the optional local callback routine (safe to comment out if not desired)
st::Everything::callOnMsgSend = callback;
//Create the SmartThings ESP8266WiFi Communications Object
//STATIC IP Assignment - Recommended
st::Everything::SmartThing = new st::SmartThingsESP8266WiFi(str_ssid, str_password, ip, gateway, subnet, dnsserver, serverPort, hubIp, hubPort, st::receiveSmartString, "LinkNodeR8");
//DHCP IP Assigment - Must set your router's DHCP server to provice a static IP address for this device's MAC address
//st::Everything::SmartThing = new st::SmartThingsESP8266WiFi(str_ssid, str_password, serverPort, hubIp, hubPort, st::receiveSmartString);
//Run the Everything class' init() routine which establishes WiFi communications with SmartThings Hub
st::Everything::init();
//Add each sensor to the "Everything" Class
//Add each executor to the "Everything" Class
st::Everything::addExecutor(&executor1);
st::Everything::addExecutor(&executor2);
st::Everything::addExecutor(&executor3);
st::Everything::addExecutor(&executor4);
st::Everything::addExecutor(&executor5);
st::Everything::addExecutor(&executor6);
st::Everything::addExecutor(&executor7);
st::Everything::addExecutor(&executor8);
//Initialize each of the devices which were added to the Everything Class
st::Everything::initDevices();
//Arduino Loop() routine
void loop()
//Execute the Everything run method which takes care of "Everything"
st::Everything::run();
