@bennetm3 All 4 channels can be controlled via Alexa or Google Home. As for the POW, I am still trying to figure it out. I am seeing similar issues as you (which is why I am still calling it beta).
@TCPExperts If you could write something up as outlined (minus the sections that you can’t) that would be awesome.
Hello. I am curious if there is a possibility to change (toggle) the boot up state from on to off and off to on by short disconnecting the mains power? For sonoff.
@bennetm3, @erocm1231, I have been trying to get the POW to work for a while. I have that @TCPExperts got it to work (post #497) so I thought that I am doing something wrong. I get it to flash and I can see the it broadcasting. I even managed to log in and to connect it to my network but than it stops working. @TCPExperts, how did you get it to work?
It does have some bugs (still beta). One causing what you are seeing. It has actually been the most challenging devices I have worked on, but stay tuned and I’ll try to get it working smoothly.
Are you sure your boards set to use Com20?
Try changing the com port in device manager to something a bit lower and skint forget to change it in the flash instructions.
Have you soldered the headers in place or are you holding them in place while you flash?
esptool.exe -vv -cd nodemcu -cb 115200 -cp COM%comport% -ca 0x00000 -cf Sonoff.ino.generic.bin
You delete the %comport% part and put 20 there so yours would look like …
Ok, I’m trying again with a Windows 10 system, is it normal to hang on thebelow output for a while, its been on that point with a blinking cursor for the past 4-5 minutes:
No that didn’t happen to me.
I’m no expert I struggled but half my trouble was because I was holding the headers in place.
Once you get to where you are the flash should start with loads of moving lines and it takes roughly a min to complete.
It may just be your not getting it into flash mode do any leds light up at all as from memory they stay of if in flash mode
Yeah I managed to hold the headers in place when I flashed I had to press quite firm and I also bent the pins slightly under the header as it seems to make better contact.
What is the error message you get as I was getting a error message every time I think I had the rx and tx the wrong way.
Once I had done my first though I managed to do a further 3 straight away within 5 mins
Which number pin are you using for power?
The square shaped one at the end? you have set it to the correct voltage 3.3v.
I’m just going if momory now as it was about 3 weeks ago I did mine I think I may have commented further up on what I did
