It WORKS!
The default password for ESP_Easy_0 network is configesp
So I’m now in the process of configuring the TH 16…
Got it turning on/off.
Now do I really need the temperature probe?
Anybody done this before?
It WORKS!
Following your work and have the TH16 programmed Thanks to you I got into ESP_Easy_0 network to setup WiFi and am now at the config page. What needs to go there to use with SmartThings?
By the way, did you fly the Warthog?
Looks like my troubles are only beginning!
The ESP firmware allows control of the Sonoff by sending web requests on the local network (192.169.1.xxx) but there is no device handler for ESP in smartthings, so I cant use the 8285 sonoff on Smartthings.
So I am exploring the options…
Will update when I make progress…
It looks like there may be a simple solution.
There is a device handler available that allows you to send local web requests.
http://thingsthataresmart.wiki/index.php?title=URI_Switch
I’m going to try it out and document it as I go…
The Sonoff app did not find it?
I did not try using the Sonoff app.
Have you? Which one?
Did it integrate with Smartthings?
It’s the only way to connect to ST, Install the smart app and it will find your device.
This is the whole topic of this post. I guess you have not read post 1?
i just re-read my response. This is not meant to sound like i’m being a jerk about it! Just a genuine question.
It could very easily by my lack of understanding how this is supposed to work but I cannot get the flashed TH16 to work with this app. I can web connect with the TH16 and I was able to manually add it using the app but could not get it working. The TH16 started showing unavailable shortly thereafter.
when you look at the device in the ST app, do you see the IP address or just zero’s?
If you just have zeros then make sure you have the latest version of the SmartApp. Or try what I said in october:
I guess I’m further behind than I thought. I never got an IP address displayed. Will try to flash again and see what happens. I may have bricked it already
Just flashed again and it wasn’t bricked. Found the WiFi SonoffTH.xxxxxxxxxxxxx but don’t have password
Found the password of configme
It works
OK I think things may have gotten a bit muddled. So here’s a recap:
I am trying to use the latest Sonoff devices that use the 8285 chip and not the older 8266 ones. I have loads of the older 8266 ones and they work really well with the erocm firmware and device handler.
I tried flashing with the standard(8266) firmware. They flashed OK, but failed to boot a network session. I guessed the 8266 firmware is incompatible with the new Sonoffs.
I did find 8285 firmware as detailed in an earlier post on the ESP Easy (details here:
https://rutg3r.com/sonoff-firmware-tutorial-to-esp-easy/)
The ESP Easy firmware for 8285 worked with the Sonoff and I have been able to turn the relay on and off by posting the relevant commands.
So the only question remaining is how to control it using Smartthings. I tried the erocm driver and was not surprised that it did not work (not erocm firmware).
I do have it working using a virtual switch and WebCore. Which I can detail if anyone is interested.
I am now trying to get it to work using URI Switch ( [BETA RELEASE] URI Switch -- Device Handler for controlling items via HTTP calls) which would be neat as it would be a local network solution and not relying on WebCore cloud.
I hope that makes sense…
Update.
I got it working by a simple modification to the URI Switch device handler (replacing GET with PUT. I am considering doing full documentation on how to use ESP Easy firmware with Smartthings.
Because the ESP Easy firmware is so flexible, it should work with any 8266 or 8285 based device. I am planning to try it out on a cheap RGBW led controller like these:
https://www.amazon.com/SUPERNIGHT-Wireless-Controller-Working-Compatible/dp/B01JS0KEBW/ref=sr_1_1?ie=UTF8&qid=1548757537&sr=8-1&keywords=magic+home+led+controller
I may fork the URI Switch device driver, but that may take a while as I’d like to be able to return data as well eg temperature from Sonoff TH 10/16.
I can potentially get a few of these devices cheap…
I have been unable to get the firmware to work with a Dual R2 (Think it is because the chip is the 8285 rather than the 8266). I successfully flash other firmwares which then work.
Has anyone made this work?
I’m going to have a go using the ESP Easy firmware that worked on my 8285 Sonoff.
The 8285 is a slightly cheaper chip, so I guess they are all going to be 8285s from now on.
I’ll let you know how I get on…
Well it’s an 8266 chip, so it should work. Only problem would be that you might have to work out what the GPIO pins map to. The sonoffs are so cheap, why would you bother?
Because my employer just got 200 of these in to stock, and at staff pricing they’re looking quite good…
David, did you follow the instructions here:
It’s for the 8285 version.
Yes thank you. Using Tasmota works with the Tasmota device handlers. I was trying to confirm that erocm1231’s firmware and device handlers do not support it
The only thing wrong (for me) with Tasmota is the lack of proper syncing (ie if you use the device button or a non-smartthing way to turn on/off)
