i have one request
i would like an option to disassociate the W2 channel from the W1 channel with the mutually exclusive option switched on
so that i can use alexa/GH to control my RGB and W1 channels and use the extra W2 channel for something else that i want to be able to keep on when the RGB is on
aslo i second the “linked devices”
i finally finished my kitchen cabinet project which required to use 3 H801’s
i had been using only one and only had my main cabinets lit
i figured that since i have one H801 grouped in with my other kitchen full color hue’s in alexa smart home and was able to have all the lights change to to a specified color when i command the group by voice request that it would work for the 3 controllers
so i made an alexa group ,named it “cabinet lights” and added the 3 H801’s into it
but the results are not as i expected at all
it won’t control all 3 H801’s so if i say to change the cabinet lights to red it will only change 1 or 2 sometimes all 3 but i usually have to give the command 2 ,3 , or 4 times or more to get them all to respond
then with the W1 channel it is not working at all i used the smart app to get the 5 seperate channel virtual switches then i put the W1 channel virtual switches for all 3 H801’s in an alexa group and into a GH room but when i tell either of them to switch on the group/ room i get nothing
also when i say to turn cabinet lights on ,the group with all 3 controllers in it behaves REALLY strange ,
sometimes 2 will come on sometimes 3 but they all change colors then one will sometimes go off after shifting to a few colors first
they don’t turn on all the same color
i am not sure what is going on but i had 2 H801’s working fine before this
one for one bank of kitchen cabinets grouped in with 6 hu br30 full color bulbs and no problems at all , then i added another one under the bed and i grouped it in with a osram lightify full color BR 30 and a hue full color bulb and no problems at all
i can tell it switch the group to a color and all 3 devices change to the right colors i can also switch on and off the W1 channel with no problems, the problems come when i add more than on H801 to an alexa group or GH room
also do you know what the switch debounce setting is for?
