@ercom1231 hey Eric is there any chance you can try and fix your smart app
it does not work for me at all now , after much headache getting one H801 to work months ago i bought 4 more and now i am having the same issues all over again , only worse
the smart app does not detect the controller , and if i add it manually like i was able to do before it just says that it is not fully configured still.
there is no way to get it working
i log into the controller using my browser and i go to the advanced settings tab and i entered all the fields manually like i did before but it still does not work either with autodetect or by manually adding it through the smart app , it just says "not fully configured’ and i can not control it through ST ,only from my browser
could you please work on the code or provide us with some alternate instructions to get these things to work?
it is really aggravating
EDIT: ok i can get it to control through the device handler
but i can not configure it in the smart app still and in the device handler there are dashes where the device IP should be and where the firmware should be
also when i go into the IDE and my go to my devices and click on the controller i noticed that there is no MAC address listed in there
the other controller i set up has the MAC address listed under where it says “port 80”
can anyone help me to get these added without the smart app? or to get it working with the smart app another way , it just says not fully configured when i click the device in the smartapp even after i do everything manually
and enter the device IP , subnet , gateway ,HA controller IP in the advanced tab through the browser interface
last time i entered everything manually it worked but last time the HA controller IP was in already there this time i had to enter it
and why does it not show a MAC address in the IDE?
also now i just noticed that under automation the smart app is showing up twice , is this supposed to show up twice? maybe this is causing a conflict?
EDIT: note that there was only one copy of the smartapp when i first tried to get the second controller working , i figured out that if i try and go to the smart app through marketplace>smartapps >my smart apps it will add a second copy of the smart app under the automation tab every time i go into the marketplace>smart apps>my smart apps tab
every time i go back there another copy of the smart life app is on the list under automation smart apps ,there were 5 of them in there at one point i called smart things support and they got rid of them for me but it still does not work , the smart app is broken and does not work at all the devices always just say not fully configured
