[quote=“anthony_rossetti, post:1487, topic:51182, full:true”]
Yes exactly , I got things working great with Alexa so far
I can add the controller to my kitchen group in Alexa smart home and when I tell her to change kitchen light red the hues and the controller turn red
So. This is perfect for when I get the other 2 controllers for the kitchen cabinets, i can just group them in alexa smarthome
i would like mutually exclusive W1 and RGB and then W2 as a separate device for the following reasons
One wall where the cabinets are is opposite a wall for a hallway where there is a small battery operated led wall sconce ,I wanted to use the RGB and W1 channels for the cabinets and drill through the wall and connect the sconce to the W2 channel ,I plan on setting it to trigger after dark by a motion sensor since the sconce is in the hall where the bedroom and bathroom doors are
I also plan on using 2 other controllers in the bedroom
One for the bed and one for strip around the TV and I want to
Use the W2 channel for a black light strip for the bed and TV and have RGB and W1 as mutually exclusive so i can control everything with alexa
W2 should work For black light strip right ? I mean it just has on and off and dim not anything specific for driving white only ,W2 should be able to drive a black light strip correct?
I would like the W2 channel to Show as a separate thing so I can use it with Alexa for the black lights and the hall light
And use a PIR for the hall light on W2 also
Also will programs show up as things? And is there a way to add more than 6 ? why is there a limitation of 6 preset programs and can i it be increased?
because I am trying to find a way to use an ifttt recipe I have been using with my hue br30 recessed lights with the controller instead , ifttt recipe ,change lights to specific color is weather condition changes to X and other ifttt recipes that change the color for different events
And for other color changes for ifttt recipes
