This may not be the place to post…if it isn’t, I can move it.
Anyway, similar to how others have suggested, you’ll need to create some virtual switches, since webCoRE and other 3rd party smartapps can’t access directly. I have created the following 6 switches.
STHM Armed Away Status, STHM Armed Stay Status, STHM Disarmed Status, STHM Arm Away, STHM Arm Stay, and STHM Disarm. (Note: I think I could probably get away with 3, but was initially having issues with reliability and this seemed to help.)
If you had SHM Delay setup in the past, you should have a “virtual” contact that you can place into the contacts to use for the new STHM.
For automations to create in the new app, here are some screenshots. I didn’t screenshot each automation, as I think you can get the gist after you look at these.
For the webCoRE piston, here is a green snapshot:
Where the anonymized devices translate like this:
Switch 20 = STHM Disarmed Status
Switch 17 = STHM Armed Away Status
Switch 18 = STHM Armed Stay Status
Contact Sensor 14 = is virtual contact used in STHM’s contacts to monitor for open/closed.
Contact Sensor 1, 4, and 7 are real door contact sensors (take out of STHM’s settings).
Motion Sensor 2 and 6 are real motion sensors (take out of STHM’s settings).
Switch 3 and 14 are entry/exit buzzers
Switch 4 is the siren (backup to make sure siren gets turned off…STHM is weird)
I realize these instructions are probably missing some explanation, so let me know if you run into something missing.
