It looks like it has two different modes…one is device.switch…the other is device.alarm. It looks like you are triggering the switch mode (on and off). I can define how long a beep lasts, however, I can’t think of any workable scenario with the switch (Beep) mode. If you could use the alarm mode, then you could trigger the constant alarm and leave it on until the delay had completed at which point you could turn it off.
I’d play with your code, however I’m so new to this, I’m still trying to understand it all. I’ve attached the DTH for konnected’s beeper below.
Suggestions?
Thanks in Advance!!
* Konnected Beep/Blink
* Copyright 2017 konnected.io
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Konnected Beep/Blink", namespace: "konnected-io", author: "konnected.io", mnmn: "SmartThings", vid: "generic-switch") {
capability "Alarm"
capability "Switch"
capability "Actuator"
capability "Momentary"
capability "Tone"
preferences {
input name: "invertTrigger", type: "bool", title: "Low Level Trigger",
description: "Select if the attached device or relay uses a low-level trigger. Default is high-level trigger"
// settings for momentary beep
input name: "beepDuration", type: "number", title: "Beep Pulse (ms)",
description: "Each beep or blink duration", range: "10..*"
input name: "beepPause", type: "number", title: "Beep Pause (ms)",
description: "Pause between beeps/blinks in milliseconds", range: "10..*"
input name: "beepRepeat", type: "number", title: "Beep Repeat",
description: "Times to repeat the pulse", range: "1..*"
// settings for infinately repeating alarm
input name: "alarmDuration", type: "number", title: "Alarm Pulse (ms)",
description: "Tone duration in alarm", range: "10..*"
input name: "alarmPause", type: "number", title: "Alarm Pause (ms)",
description: "Pause between tones in alarm", range: "10..*"
tiles(scale: 2) {
standardTile("beep", "device.switch", width: 6, height: 4, canChangeIcon: true, decoration: "flat") {
state "off", label: 'Beep', action: "tone.beep", icon: "st.alarm.beep.beep", backgroundColor: "#ffffff", nextState: "pushed"
state "on", label: 'Beep', action: "tone.beep", icon: "st.alarm.beep.beep", backgroundColor: "#00a0dc"
state "pushed", label:'pushed', action: "tone.beep", icon: "st.alarm.beep.beep", backgroundColor:"#00a0dc", nextState: "off"
standardTile("alarm", "device.alarm", width: 2, height: 2, decoration: "flat") {
state "off", label: "Off", action: "alarm.siren", icon: "st.security.alarm.clear", nextState: "turningOn"
state "siren", label: "Alarm", action: "alarm.off", icon: "st.security.alarm.alarm", backgroundColor: "#e86d13", nextState: "turningOff"
state "turningOn", label:'Activating', icon:"st.security.alarm.alarm", action:"alarm.off", backgroundColor:"#e86d13", nextState: "turningOff"
state "turningOff", label:'Turning off', icon:"st.security.alarm.clear", action:"alarm.siren", backgroundColor:"#ffffff", nextState: "turningOn"
main "beep"
details "beep", "alarm"
def updated() {
parent.updateSettingsOnDevice()
def updatePinState(Integer state) {
if (state == -1) { // represents an infinate alarm activated
sendEvent(name: "alarm", value: "siren")
} else if (state == triggerLevel()) {
sendEvent(name: "switch", value: "on", isStateChange: true, display: false)
sendEvent(name: "switch", value: "off", isStateChange: true, display: false)
} else {
sendEvent(name: "alarm", value: "off")
def off() {
def val = invertTrigger ? 1 : 0
parent.deviceUpdateDeviceState(device.deviceNetworkId, val)
def on() {
beep()
def push() {
beep()
def beep() {
parent.deviceUpdateDeviceState(device.deviceNetworkId, triggerLevel(), [
momentary : beepDuration ?: 250,
pause : beepPause ?: 150,
times : beepRepeat ?: 3
def siren() {
momentary : alarmDuration ?: 55,
pause : alarmPause ?: 45,
times : -1
def both() {
siren()
def triggerLevel() {
return invertTrigger ? 0 : 1
def currentBinaryValue() {
