When it is not working all that is logged is this:
1cd70cb5-b635-4a2e-a1b6-c2aba62088e6 9:56:37 AM: info HH execute(true, null, null), newMode: null
i.e. there is no “triggering a delay routine execute” or “firing target routine”
Even though there is a notification on the phone app to say the armed delay routine was executed, the execution is not entering the “routineHandler” (I uncommented some of the debug statements before the “if (evt.name == “routineExecuted” && evt.displayName == monitor_routine)” to prove this).
So the app works fine for about 3 times and then it stops getting into the “routineHandler”
When this happens, if I click the armed delay twice it seems to start up again on the second click of armed delay.
Why the routine does not trigger is something beyond my understanding, and I doubt using the Classic app you will get much of an answer from support, but that is a suggestion.
The next time this displays, please click on “1cd70cb5-b635-4a2e-a1b6-c2aba62088e6”. This will highlight issuing the app or device, hopefully pointing to something that can be helpful. However, newMode: null seems flatout wrong and may be the cause of the failure.
Hi,I’ve been trying to use the SHM Delay and TrueExit and have a few problems:
Using Delay, I have a door contact sensor on the front door and a motion sensor in the hall with an Android panel in the hall. I want to delay the setting of the alarm when leaving or arriving. The delay seems to be OK, but it isn’t monitoring the hall?
I’ve tried adding LANnouncer but it doesn’t seem to be working in SHM Delay? UPDATE: I found the section about LANnouncer not working when using Fully and Actiontiles on an Android tablet, so have changed this to the FullyTTS and BigTalker2 but still nothing sounding in SHMDelay.
I’ve tried TrueExit instead to see if I can get that working. It seems to work fine including playing the announcement on LANnouncer/BigTalker2, but I only have the option of creating one delay. I’d like one for Good Bye, Good Night and I’m back to allow for getting in and out of the house?
I’m sure I should be able to sort these things out myself!
On entry delay should the motion sensor be activated when entering the home, it must be added to the Delay Profile and removed from Smart Home Monitor. Since the keypad provides a real exit delay, motion sensors are not monitored until the system is armed in Away mode
Is the SHM Delay Talker module installed and a Talker Profile created? SHM Delay does not use or need Big Talker, although it may be used and should happily coexist. When using any output speech device make sure it works before attempting to use it with any Smartapp
When using a keypad the True Exit module is superfluous and should be removed, the keypad provides a real exit delay.
My profile is below. Front Door motion is removed from SHM open/closed sensors and Delayed Simulated sensor used instead. Hall is removed from the Motion Sensor in SHM.
I don’t have a keypad, just a Amazon Fire tablet, so I’m not sure whether I need the True Exit or whether everything I want should be achievable with just SHM Delay?
SHM Delay Talker module is installed and a Talker Profile created. I didn’t use BigTalker initially I just used FullyTTS, but that didn’t play the chime sound either. FullyTTS and BigTalker seem to work on their own OK.
True Exit is not necessary, SHM Delay should work with or without a keypad.
Lannouncer has built in sound files, including chimes. To get chimes with the Fully Kiosk Controller app, a sound file must be placed onto the tablet as explained in the documentation, then tested to be functional prior to attempting to use it with SHM Delay Talker.
Moving away from my sole Iris keypad and putting tablets near each door and discovered the need for your TrueExit app. Core SHM Delay doesn’t work (at least I am missing it) with the door locks. As soon as I hit the actual Goodbye routine it locks the door. Issue I am seeing is that there are times it never fires the actual Goodbye routine, and if it does it is never close to the time set. Below are some logs I pulled based on what you asked previously in this thread. This one it fired the Goodbye routine, I just tested it again and its been four minutes and it still hasn’t fired it. Any thoughts are greatly appreciated.
For my “delay” profile
8:31:56 PM: info HH execute(true, null, null), newMode: null
