RBoy
81
EDIT: From your logs and video it looks like its an issue with the siren/DTH. You’re using the Vision siren which resets itself after 30/60 seconds. So whenever you walk past a sensor it triggers the Siren which resets itself with a delay before turning on.
Try a different Siren like a Utilitech or Everspring which doesn’t turn itself off by itself/doesn’t have a delay turn on.
Good Afternoon! I installed a SmartThings button and the intruder alert. When I press the button, it tells me potential intruder, but the alarm does not go off.
On the smartapps, when I select intruder alert…then I select intrusion actions…on the turn on alarm(s) it says there are no devices of this capability
Hi, I responded to your email. I believe you’re trying to use the ADT built in alarm. SmartThings does not allow external triggering of the built in Siren in the ADT label. You’ll need a separate Z-Wave or ZigBee Siren paired to your SmartThings hub which will then show up for use in the SmartApp.
Hi ,
Testing the features of your great intrusion app.
Several questions :
Is there an option to beep or send some voice prompt at some interval before system get armed and ?
for example I set exit delay to 2 minutes and I want every 20 seconds the get a status of how much time left before system armed (using notification or echo device )
The same for entry delay
Is there an option to set type of siren for example
When I set armed stay (Night mode) I want the siren to be some kind of chime (I have necoolcam siren)
while armed away I want the primary siren to be activated .
When I sleep my phone is on vibrate mode which SMS and push notification will probably not wake me up. Can you add a call option ? (probably not but what is the best practice here )
I don’t have the option to flash lights . why is that ? does it support only specific bulbs ?
Enable detailed notifications from the Notifications page and select an audio device like Alexa (Echo Speaks) or Sonos and it will announce that information
You can setup new instances of Intruder Alert for each mode (Night and Away) and then select different sirens for each mode
ST doesn’t support calling at this time, you can use SMS, Push and Audio/speaker notifications
We removed the option for flashing lights because of delays in the z-wave/zigbee mesh made the flashing unreliable
For 1 I mean that it will announce every some interval how much time left before system going to be armed.
For example when I set delay of 2 minutes before arming it will announce on 30, 60,90
Can you explain the “Optional resident sensors to temporarily disarm the system” option?
I don’t understand what this means, and can’t find documentation or an answer anywhere.
RBoy
92
Great question. Two things to note:
When the system is “arming” using the exit delay it will ignore any intruder sensors until it’s armed and ready
When it’s armed and ready if it detects motion from a resident sensor, it will ignore the intruder sensors for the duration of the “exit delay” and then resume normal operation. For example if you define the resident sensor as your bedroom sensor and intruder sensor as all other motion sensor in the living room / kitchen / doors etc and set exit delay to 3 minutes. if you wake up at night to go to the kitchen for a drink of water, you will trigger the bedroom sensor (resident). Now when you walk into the living room and to the kitchen it will ignore these sensors (intruder) for a period of 3 minutes so you can have your water and return to bed without setting off the alarm. It allow you to extend the coverage in your house where traditionally you can’t arm any sensors where you may walk/use at night.
This is a robustness release to fix an issue with the ST platform and add some additional features
Intruder Alert with Actions - Version 03.07.00
Fix issue with platform randomly resetting selected operating modes
Announce when disarming system on mode change (requires detailed notification to be enabled)
Improve support for multiple mode configuration
PLEASE NOTE: After updating to this version you will need to go into the Operating Modes page and re-select your operating modes. This is required this app now uses a different method to track mode changes to avoid the platform random reset issue.
Monitor your house security for single/multiple modes (home, away, night etc)
Monitor devices for device thefts using the tamper alerts option
Announce your alerts over your speakers/Alexa to alert the whole house
Create custom alerts/announcements
Send SMS to multiple numbers
Trigger multiple alarms/devices and automatically turn them all off then once of them is turned off
Create upto 3 schedules per day/week for monitoring
Setup entry/exit delays
Optional countdowns while arming and triggering alerts (enable detailed notifications)
Install the app multiple times to create separate use cases (security monitoring, theft monitoring, general alarms, monitor activity during the day or night or when away etc)
Scroll down to the bottom, tap Custom Actions/Notifications -> Enable Custom Actions
Tap Keypad Unlock Actions
Setup your Disarming actions here (e.g. change Mode to Home, Run routine to Disarm, Turn off Alarms etc and tap Done/Save
Tap Keypad Lock Actions
Setup your Arming actions here (e.g. change Mode to Away and optionally Run routines, Turn on switches etc) and tap Done/Save
Now you can use your Keypad to arm/disarm your setup. You can create multiple users.
If you want to use the same Arming/Disarming actions for ALL users, then instead of defining custom actions for each user, on the Main page you can tap Lock/Unlock Actions to set the same actions globally for all users.
RBoy
95
We’ve released an enhanced custom device handler for the Vision Z-Wave Plus Siren so that the default behavior complies with the SmartThings standards. In your case the device was turning off automatically which wasn’t what you expected.
If anyone is using this siren, you can check out this DTH. It has some excellent features and is extremely loud.
I have been playing around with this App and would like to add a suggestion of having the ability to “enable” the system based the status of virtual switch(s). I think this would be helpful in situations where you want to set up multiple zones. In my case I have an in-law suite with a separate entrance, a detached barn, the main house and the main house garage. Right now I think the only way to have four zones is to install four instances of the App and then build modes for every possible combination of people being home / accessing each zone which is a bit complicated (I think it may end up to be around 24 modes). If you could have the app be enabled based off the status of a virtual switch then I could make four virtual switches and toggle each on if I want that zone enabled or toggle the switch off if I want that zone disabled. Please feel free to correct me if I am wrong and there is a better way to do all four zones with any combination of zones enabled / disabled other than making a whole bunch of Modes.
I am also new to SmartThings but I do like the app and really appreciate the community’s help and openness to feedback.
This is a major update on popular request to support multiple modes or arming the system. Earlier the system only operated on hub modes and operating schedules, now you can also use Classic SHM, Presence and Switches to arm/disarm the system.
For example, if you would like to use the Classic SHM dashboard to arm/disarm the system (make sure Classic SHM security module is installed by not configured). You can select the Classic SHM state (e.g. Armed Away) in the Operating Configuration page.
When Classic SHM is set to Armed Away, Intruder Alert with Actions will arm, when Classic SHM is switched to Disarmed, Intruder Alert with Actions will also disarm.
You can also Entry and Exit delays so you can replace Classic SHM Security Module with many more added features and still use the Classic SHM dashboard to control the system.
I’m currently trying to get my system setup with Intruder Alert with Actions bc I’m more than 50% switched over to the new app and not pleased with design philosophy and automation limitations with SHM in the new app.
Regarding your instructions… I assume best practice would be to stay away from utilizing routines of any kind in order to arm/disarm? I’m only saying that bc it’s unclear what the future of routines are since they’re currently non-existent in the new app. I was currently using routines to handle classic app SHM.
I’ve now killed and uninstalled classic app SHM. Would I need to reinstall that if I’d like actiontiles control over arming/disarming from my tablet?
Love the addition of Alexa voice notifications. Could you possibly implement the same volume control in the notifications section that you added to the Chimes and Alerts smartapp?
RBoy
100
