Does anybody know if this works the UK version of the ring alarm keypad?
Itâs not been tested with Gen 1 but weâre looking into it
Has anyone here managed to get the Ring Keypad (Gen 2) working to a point that it is able to change STHM status through virtual / simulated switches?
I have tried to follow @mvevitsis â instructions, but there is very little explanation on what to do on the LUM side. I have seen the screenshots, but those alone donât really say a lot.
Thanks, that did it!
@GrimDanFango @blashman @Matthew_Stewart
We now have a device handler for the Ring Gen1 keypads. Note the feature differences between Gen1 and Gen2 keypads in the keypad comparison table, Gen1 does not support Sirens, Arming and Chimes, only the Gen2 supports those features:
Fantastic job!
In the meanwhile I got an Iris v3 as an alternative.
Just preparing everything to add it to the network.
My Keypad Device now only updates status in one Direction.
Iâm using Rboys DH and Smart App.
How do I get the Wedcore Code to make it work ?
So I have everything finally setup with the device handler and the automations and ULM. I was wondering how to setup a automation so I can trigger the Away, Stay, Disarm icons on the STHM
Currently I have setup the automation for Stay and try to run it from STHM is runs fine but when I try to disarm it acts like it disarms but goes back to a Stay arm state
From the first post:
STHM Synchronization
- For changing STHM modes using the keypad see this post
- For two way synchronization of the keypad with STHM see this post
If youâre trying to sync the keypad to STHM by changing the STHM mode in the SmartThings app youâll need to use two way synchronization
So I created the the 3 virtual switches with in the first link for they keypad
Do I need to make two more virtual switches for the two way synchronization?
I was finally able to fix my issue and everything is working as expected. Thanks @RBoy @mvevitsis for pointing me in the right direction and for the excellent step by step instructions
I finally realized the problem I am having with my Ring Keypad is that I punch the numbers in too slow. If I hit them really fast, it works every time. How do I change the Ring Keypad pinCode Timeout?
Is there a WebCore command string to set pinCode Timeout?
You can adjust the pin entry timeout from the device settings page in the SmartThings mobile app
Found it - Thank you!
When using as a home alarm with STHM or other alarm apps, is there a light to indicate whether the alarm is armed or not? Thanks!
I followed all the instructions for synchronization, but I have 2 keypads (one for my front entrance, and one for the back entrance). When I disarm they seem to get stuck in a loop and keep bouncing back and forth between the two saying that the system is disarmed. Does anyone know why this would be happening or what the solution is to resolve this?
@AfternoonSnack - It does have 3 indicator lights on the keypad that show current armed state or disarmed. These light up once the keypad is approached.
@Ryan_Birch - I also have not been able to solve this on disarm. I get three disarm messages on my keypads. I gave up trying to solve it. I tried to add delays and variables into my Webcore code and havenât fixed it.
Planning to ditch my 2-gig/Alarm.com security system and move to something else. I already have Z-wave sensors on all doors/windows. Iâm just looking for perimeter monitoring. A few questions:
If I go with this approach instead of a Ring Alarm system, am I only forgoing the ability to have it monitored remotely (which isnât critical to me and is costing me $800/yr)?
Whatâs your sense of the longevity of this approach? Will it die when they kill WebCORE and IDE?
I should know this, but I havenât been tracking things carefully: will a smartapp like this run locally?
