What it does:
- Combines an actuator switch device and multisensor (contact/acceleration) into a single logical garage door device (capability.doorControl)
- Properly reflects the state of the door if opened/closed externally (door-button, garage remote, etc)
- opens/closes immediately when you tell it to
What it doesn’t do:
- Attempt to retry close/open operations if they don’t succeed
- Automate open/close operations based on other events (these automations can be accomplished with higher-level smartapps using this Virtual Garage Door device)
Doesn’t this already exist?
There are other implementations with a similar purpose, but they either rely on Smartthings’ simulated garage door device which isn’t optimal for this purpose, or they support a bunch of complicated automations which can already be accomplished with other more generic smartapps once you have a coherent virtual garage door device available.
Installation:
Install both the Virtual Garage Door device and Virtual Garage Door Manager smartapp, configure the smartapp with your door actuator and multisensor as well as the virtual device.
