Hi, you would need to call the following method:
setThermostatSettings([dehumidifyOvercoolOffset:value])
Values should be in the range 0 - 50 and be divisible by 5.
Regards.
Regards.
Under which specific smartapp would I find this? I found an option under MonitorandSetEcobeeHumidity for use AC as dehumidifier, but itâs an on or off setting, thereâs no values. Im not understanding where you are telling me to set this. Thank you.
Well, you may check if you can use webCore to do this.
Ah ok, I thought there was something in your smartapps specifically where this could be set. Thank you.
hi @yvesracine,
I have a couple of questions.
Is My Ecobee integration going to survive Samsung integration?
Any plans for Hubitat port?
thnx
Well, Iâm following any development on the ST front⊠Itâs too early to tell at this point, but I understand that ST will continue to support groovy and custom DTHs for a whileâŠ
For the moment, Iâve been accepted (ecomatiqhomes) as a company partner for the new ST development platformâŠ
As for Hubitat, I donât think that it supports cloud to cloud integration (yet) âŠ
EDIT: With the ST classic app, here is the ST answer about your concerns:
Regards
Okay, I am loosing my effing mind trying to get my ecobee, flair, and ST to produce one simple effing outcome: when A/C running open vents in one room wide open, and when heat running reduce airflow to that room. Instead Iâm ready to take all this shit and give it to somebody I donât like.
I have contributed to buy every ecobee and flair related app, but all it does is continue operating as if my wishes were never even a consideration.
Can ANYBODY help with this before Iâm in the next news cycle for flipping out and running naked through the streets? Seriously.
Iâm sorry, but I on vacation with little access to the internet.
I donât quite understand your use case. You need to provide more info by email (see email address below) such as:
Please send your configuration screenshots and your logs to services@maisonecomatiq.com
and I will look into it upon my return. I need both as my smartapp has many options.
In the meantime (as indicated in the downloaded zip file & the installation steps), Iâd recommend to read the configuration section at the ST community wiki (especially use cases 1,4 & 18):
http://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule#Configuration
To enable detailed tracing, refer to use case 13.
Regards
Thanks for the response, especially given you are away. Sincerest thanks.
Trying not to leave out anything from your message, I have inserted responses in all caps, not meant as yelling in case that might be perceived.
your thermostat mode (auto or else): AUTO
do you have colder/hotter rooms?: YES, BUT THE MAIN GOAL IS THE MASTER BEDROOM REMAINING COOLER. MY WIFE AND KIDS CAN THEN MOVE THROUGHOUT THE HOUSE WITHOUT LOOKING LIKE SHERPAS HEADED FOR THE SUMMIT.
did you create specific zones for each of these colder/hotter rooms?
I CREATED A SINGLE ZONE FOR EACH OF TWO THERMOSTATS. NOTE, ALL THE FLAIR VENTS AS WELL AS BEDROOMS ALSO ARE IN TJIS ZONE.
did you use the zonesâ temp deltas to adjust the target setpoints for those rooms?
I HAVE ENDEAVORED TO UNDERSTAND BASIC SETTINGS TO A POINT WHERE ANY RESULTING PERFORMANCE FROM AC WAS RECOGNIZABLE BEFORE ADDING FURTHER TRICKS.
did you set the vent setting option on in GeneralSetup?
I LISTED ROOMS AND BENTS IN EACH ROOM, BUT LEFT SETTINGS TO PROGRAMMING AS I SAW NO WAY TO DIFFERENTIATE BETWEEN BIAS TOWARD INCREASED COOLING AIRFLOW AND REDUCED HEAT.
I WILL TAKE SCREEN SHOTS, AND LOGS TO THE EMAIL. ASSUMING YOU MEAN LOGS IN IDE HUB?
I HAVE READ THROUGH THEM, NO REALLY. IM AN INVESTMENT PORTFOLIO MANAGER AND HAVE PROVEN, WITHOUT ANY QUESTION, THAT I AM NOT A PROGRAMMER. IVE ALWAYS FELT SLIGHTLY AHEAD OF THE TECHNOLOGY MINIMUM ACCEPTABLE APTITUDE, BUT NEARING 44, SEEMS TO HAVE RAISED THE BAR BEYOND REACH.
I will send you an email with my recommendations.
Basically, you need to make sure that your vents are all configured under RoomSetup>VentSettings for each of your rooms ( I cannot tell from the screenshots you sent me).
And, you need to set the VentSettings flag to true in GeneralSetup. Thatâs the part you missed in the configuration section of the ecobeeSetZoneWithSchedule smartapp.
Some people use the smartapp without any smart vents, so you need to set the flag to true to activate the ventsâ logic.
Thatâs it.
Hi, in the last version (5.9.9.y.2), I added the following command in My Ecobee DTH:
You can use the above command in your favorite rule engine to modify dehumidifyOvercoolOffsetâs value.
Also, a new version of MonitorAndSetEcobeeHumidity (v3.4.4) has been published at my github with a new dehumidifyACOffset input parameter.
You can download My Ecobee DTHâs new version using your Sellfy download link.
My Ecobee device is also available at my store.
Regards.
I really love the application. Yves is putting in a lot of work into continuous updates and improvements and I really appreciate it. I have been using the application for the past 2 years and I am very happy with it. Keep up the great work Yves!
Hi,
Just want to inform my contributors that a new version (v5.9.9y.3) can be downloaded at my e-commerce solution provider (sellfy) using the original download link or your sellfy account provided that youâve followed the update procedure indicated at my store (under the terms of service).
If youâre are a contributor to one of my support packages (and I have access to your ST account), the upgrade has already been done for you. You donât need to do anything, everything has been taken care of.
The new version brings more comfort & energy saving tips for multi-stage heating/cooling systems.
All the above smartapps are located at my github:
My Ecobee DTH is available at my store:
Regards.
Thanks for the updates Yvesracine! Great job!
Hi,
Just want to inform my contributors that a new version (v5.9.9y.4) can be downloaded at my e-commerce solution provider (sellfy) using the original download link or your sellfy account provided that youâve followed the update procedure indicated at my store (under the terms of service).
If youâre are a contributor to one of my support packages (and I have access to your ST account), the minor upgrade has already been done for you. You donât need to do anything, everything has been taken care of.
The new version (v5.9.9y.4):
Just as a reminder, several smartapps are available with my custom DTH. Among others, there are some smartapps to calculate and cumulate the ecobee runtime stats for more precise comfort & energy tips. Refer to the ecobeeGenerateStats below:
www.ecomatiqhomes.com/store
Regards.
So what does the road map for Switch+ support look like? Am considering a couple for strategic places but also want to be able to turn them on and off from SmartThings.
Hi, it all depends on the ecobee APIs⊠Ecobee says (for the moment) that they will be changed this summer⊠Iâm hoping for some push APIs for better performances (switches need to be turn on/off in real time as much as possible), but no information has been provided on this.
To be followedâŠIâll be ready to release v6.0 as soon as the APIs are ready.
Regards.
@yvesracine Hello, looking for some assistance. Ecobee is not working as of 12.59pm EST today, I tried to re login into ecobee but it will not get let me get past the 2nd page of authorize smart things. It is giving me some weird error!
Update: I was looking on the community and the other Ecobee App in the community is having the same exact issue with some of their users and it all happened at the exact same time. I think there might be an issue with the API, I hope this helps.
Iâve just tested the whole auth process, and everything works just fine, so I suspect it was either a temporary ecobee or ST issue.
Please make sure to follow all the instructions at the readme before trying it again.
Why would it stop working, I have had your app running for over a year. As of 12:59 it is no longer logging except for remote sensors.
