Yes yes yes. I have a cottage in the woods and it would be super helpful if the outside lights came on for guests on the day of check-in. Is this in the pipeline?
Matt
Matt
Pretty sure you can do that with Minut integrating with the lock and with Hue
Hi Matt, you can already do this through the app with check-in actions, under manage property.
Hi,
I got RLA working for my Airbnb and I have a couple questions.
I have been using the RLA app for a couple years to manage my Airbnb listing. I have a new Aeotec Smart Home Hub (my ADT hub was bricked) and until recently a Z-Wave Kwikset SmartCode 916 deadbolt (I donât recommend it, btw. The touch screen was terrible.) I replaced the 916 with a Z-Wave Kwikset SmartCode 914 deadbolt. The locked added to my hub fine and will lock and unlock from the app, but it cannot set the codes. There is a Z-wave light switch inches from the lock, but it is old and may not be a buffering device, so I got a Minoston Repeater/Range Extender Outlet and plugged it in a few feet away. Same issue. I decided it may be defective, and I ordered another 914 lockâsame issue. Additionally, I got a Z-Wave Kwikset SmartCode 912 lever and have the same issues with setting lock codes. Any thoughts on what may be wrong?
I donât use the same lock, but for another device to buffer it needs to be capable of meeting the equivalent Z-Wave security standard of the device itâs buffering for. My lock is S2, and I suspect most are, so your buffering device also needs to be S2. Maybe this is an issue?
I ordered an Aeotec Smart Switch 7 and for good measure excluded the lock and re-included the lock after including the Z-Wave S2 repeater which was only a couple feet from the lock. Still it would not program my lock codes. After some research, my locks are Z-Wave Plus (chipset 500) not S2 (chipset 700). I even increased the wait time between program attempts and increased the number of attempts. Anymore thoughts anyone?
Check if your lock is using the correct device handler (Z-Wave Lock or Universal Z-Wave Lock).
WORD!! I had an old lock device handler. I deleted it and install the Universal Enhanced Z-Wave Lock. Itâs working perfectly now!
Good morning. So I see that there was mention of yourporter not providing phone numbers which they do now, but Iâm not having any luck getting the system to recognize the phone number, but it is getting the name and date. I have tried without quotes âPhone Number: +â, âPhone Number:â and â+â. Below is the data from ical scrubbed of course to see the format. Iâm trying to use 6 digits which is why Iâm not grabbing the 4 digit code listed.
BEGIN:VEVENT
DTSTAMP:20211103T185040Z
DTSTART;VALUE=DATE:20210920
DTEND;VALUE=DATE:20211003
SUMMARY:My Place AirBnB-First Last-20 Sep-03 Oct
UID:sdafjh4f-85gh-f48d-f40n-fasdnblo947s@yourporter.com
DESCRIPTION:Phone Number(Last 4 Digits): 5555 Phone Number: +19525555555
END:VEVENT
I just did a quick test and itâs working here (it picked up 555555 from your example above). Make sure youâre using the latest version of RLA (v04.08.03) and check the following options:
Phone Number:
6
Using phone number
This is what it looks like
Thanks! I had the â\nâ in the end marker as I saw in the instructions. I didnât think of removing that since it was the end of the line. It is working correctly now!
RLA supports Channel Managers & Custom Calendars integrations for for hundreds of channel managers, custom PMS systems and custom calendars.
Thank you for the great app! We run two separate rentals and have purchased two licenses for your software as itâs an integral part of our operations.
Is it possible to request option to separate the time to enable / disable automatic code from the time check-in / check-out actions are performed?
We prefer to have the check-in codes before actual check-in just in case some connection error occurs, but would like to have real check-in actions run at the time of the real guest check-in.
Hi,
Is the Rental Lock Automater (RLA) compatible with this lock:
Samsung SHP-DP609 (WI-FI)
I already have this lock added to my Smartthings account.
Thanks you
Updates are great and all, but can you please address groovy being depreciated? Wonât that just break everything?
When exactly is that happening? Is there a hard date that the rboy rental app will end of life if nothing is updated?
@Ben_Fletcher I agree, since we donât have access into Samsung at the developer level, we count on RBOY to provide us feedback on the direction of the platform that they get from Samsung.
What will happen to WebCore, what about other Groovy Apps, including the ones that have just âworkedâ for 5+ years? Many of us rely on RBOY for our business, and we might need to lean on RBOY to develop a stand-alone Z-Wave product if Samsung fails us. They certainly have the background and knowledge to do so.
