SmartThings Community
[RELEASE] RemindR ~ don’t miss an important event!
smartapp_alerts
smartapp_weather
smartapp_voice
sonos
cron
(Krossfyah) #181
ok makes sense,
Does this work with Google Homes with announce the state of a contact (ie. contact open or closed)?
Do I need a seperate tablet or phone running this app to make this work?
(James Richardson) #182
Hi @SBDOBRESCU It’s working OK but still has a long delay, around 6 seconds…
Can you offer any assistance on the below? I rang my Ring doorbell at 15:59:36 and the message to play didnt reach the sonos until 15:59:42. I have several XML debug messages in live logging as below:
15:59:36: trace uuid; RINCON_B8E937B236C001400
db557845-c45e-4d91-aa56-08d8032e2fe1
15:59:36: debug Not parsing XML message:
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:SetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1">
</u:SetVolumeResponse>
</s:Body>
</s:Envelope>
<s:Body>
<u:StopResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
</u:StopResponse>
</s:Body>
</s:Envelope>
(Bobby) #183
Those look like Ring logs. Unfortunately you are up against multiple clouds and in my experience, Ring is pretty slow… I tend to say that 6 seconds is fairly decent.
(Mike) #184
@SBDOBRESCU Is it possible to get the message variables updated during the reminders? If I had &time in the message, have it updated to the current time.
(Bobby) #185
That’s what it suppose to do…
(Mike) #186
I have it set to remind me every minute for 10 minutes, and the time for each “In case you missed it…” is the same as the original message.
(Bobby) #187
Ah, yeah… Reminders are nothing more than recorded events. They don’t refresh the data.
(Krossfyah) #188
Can anyone help?
(Bobby) #189
Where are you stuck? You need to install and publish (for me) both apps in ide. Then, you need to go in Marketplace and install the RemindR app (not the profile). Once you click done, you will need to go out of the Marketplace and into your “Automation” page. Under SmartApps tabe you will see RemindR (see picture). That’s where you configure your profiles.
(Krossfyah) #190
sorry I am stuck getting this to work with Google home.
(Emerson Vier) #191
hi @SBDOBRESCU can this app work with LANnouncer?
(Bobby) #192
it should…
(Emerson Vier) #193
@SBDOBRESCU I can’t see the LANnouncer on the "Play on This Player "
(Jason "The Enabler" as deemed so by @Smart) #194
LANnouncer is a Speech Synthesis Device.
Scroll down to the “Play on this Speech Synthesis Device” section.
FYI, LANnouncer will NOT play the custom sounds… like dogs barking. It will only do the TTS
(Ron Sissons) #195
I am not sure if I missed it, but is there a quick tutorial on how to use this? I have both apps installed and see them in ST Marketplace My Apps. What’s the difference between RemindR and ReminR Profiles? Is Profiles based on a user profile that you create, or is it another name for routine? Sorry if this sounds dumb.
(Bobby) #197
You only need to open the RemindR in your “marketplace” and click done, then go to SmartApps tab under Automations to create first reminder (profile). Think of the Profile app as the place holder of your reminders.
(Emerson Vier) #198
Hi what kind of Notification Type I need to choose?
(Emerson Vier) #199
Hi other question here, I want to receive notification when one door still open like every 5 minutes, I Set Up this but after I close the door I am still receiver notification.
(Bobby) #200
Sorry, yes. I noticed that there is a bug on reminders not properly canceling. I need to fix that…
(Emerson Vier) #201
Thank you for your reply, please let us know when this will be fixed.
Enjoy your Thanksgiving :grinning:
