I’m trying to use the @tonesto7 community version.
I just:
Removed the Devices and SmartApp from the SmartThings App.
I removed the Rachio entries from My Device Handlers and My SmartApps in the Web settings.
I rebooted the router
Reinstalled the Rachio Device Handlers and SmartApp on the Web
Enabled OAuth on the SmartApp
Installed the SmartApp in the Smartthings App
Added the API Key
Selected my Rachio (I only have one) and the 6 active Zones and hit Save
The Devices were added for each Zone, but they, once again, had the name I had named them when I had installed the official one in 2017 (not necessarily a problem, just an observation). The Devices don’t work and all of them say Watering and eventually time out and say Device Unavailable.
I did all of this with live logging on. There were some Errors thrown in the Rachio Manager SmartApp (see below).
Thoughts?
Rachio Manager SmartApp Logs
572fd0e1-417c-4571-98ac-435e30943db7 3:27:49 PM: info Updating (1) Controllers and (6) Zone devices...
572fd0e1-417c-4571-98ac-435e30943db7 3:27:49 PM: error exception polling children: groovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Long#minus.
Cannot resolve which method to invoke for [null] due to overlapping prototypes between:
[class java.lang.Character]
[class java.lang.Number] @line 1077 (getCurrentRainDelay)
572fd0e1-417c-4571-98ac-435e30943db7 3:27:49 PM: info Rachio Manager -- Polling API for Latest Data -- Last Update was (10000 seconds ago)
572fd0e1-417c-4571-98ac-435e30943db7 3:27:49 PM: info Successfully Created API Webhook Subscription for Controller (e5cacb80-1c0b-4265-a9f8-64edab5b2a83)!!!
572fd0e1-417c-4571-98ac-435e30943db7 3:27:45 PM: trace appCleanup()
572fd0e1-417c-4571-98ac-435e30943db7 3:27:45 PM: info Zone Device Created: (Rachio - West Side of House) with id: [6aba87b8-497a-429b-a7dd-c3fe51c02e23]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:44 PM: info Zone Device Created: (Rachio - East Side of House) with id: [b9566959-f76e-4a67-92ff-27bade8e89ba]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:44 PM: info Zone Device Created: (Rachio - Front Lawn) with id: [121e2893-09ab-471c-b67a-b21084d0132e]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:43 PM: info Zone Device Created: (Rachio - Front Sidewalk) with id: [c7325293-4ce9-4dd0-8bab-9d3b6fe9c41b]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:43 PM: info Zone Device Created: (Rachio - Far Back) with id: [278a3722-c2e5-430f-b40c-2ccb449463b1]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:42 PM: info Zone Device Created: (Rachio - Back) with id: [55266750-d667-43f2-a971-787cda629d3f]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:41 PM: info Controller Device Created: (Rachio - Home Rachio) with id: [e5cacb80-1c0b-4265-a9f8-64edab5b2a83]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:37 PM: trace initialized...
572fd0e1-417c-4571-98ac-435e30943db7 3:27:37 PM: debug Updated with settings: [controllers:[e5cacb80-1c0b-4265-a9f8-64edab5b2a83], defaultZoneTime:10, e5cacb80-1c0b-4265-a9f8-64edab5b2a83_zones:[121e2893-09ab-471c-b67a-b21084d0132e, c7325293-4ce9-4dd0-8bab-9d3b6fe9c41b, 6aba87b8-497a-429b-a7dd-c3fe51c02e23, b9566959-f76e-4a67-92ff-27bade8e89ba, 55266750-d667-43f2-a971-787cda629d3f, 278a3722-c2e5-430f-b40c-2ccb449463b1], authKey:aec97e4e-a08f-44cd-8190-47af993c4551, pauseInStandby:true]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:36 PM: trace initialized...
572fd0e1-417c-4571-98ac-435e30943db7 3:27:36 PM: trace Installed with settings: [controllers:[e5cacb80-1c0b-4265-a9f8-64edab5b2a83], defaultZoneTime:10, e5cacb80-1c0b-4265-a9f8-64edab5b2a83_zones:[121e2893-09ab-471c-b67a-b21084d0132e, c7325293-4ce9-4dd0-8bab-9d3b6fe9c41b, 6aba87b8-497a-429b-a7dd-c3fe51c02e23, b9566959-f76e-4a67-92ff-27bade8e89ba, 55266750-d667-43f2-a971-787cda629d3f, 278a3722-c2e5-430f-b40c-2ccb449463b1], authKey:aec97e4e-a08f-44cd-8190-47af993c4551, pauseInStandby:true]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:28 PM: debug rachioDeviceList(): [e5cacb80-1c0b-4265-a9f8-64edab5b2a83:Home Rachio]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:17 PM: debug rachioDeviceList(): [e5cacb80-1c0b-4265-a9f8-64edab5b2a83:Home Rachio]
572fd0e1-417c-4571-98ac-435e30943db7 3:27:09 PM: debug rachioDeviceList(): [e5cacb80-1c0b-4265-a9f8-64edab5b2a83:Home Rachio]
572fd0e1-417c-4571-98ac-435e30943db7 3:26:32 PM: info No Rachio AuthToken Found... Please Login to Web App > Account Settings > Get API Key...
572fd0e1-417c-4571-98ac-435e30943db7 3:26:31 PM: info No Rachio AuthToken Found... Please Login to Web App > Account Settings > Get API Key...
572fd0e1-417c-4571-98ac-435e30943db7 3:26:11 PM: info No Rachio AuthToken Found... Please Login to Web App > Account Settings > Get API Key...
572fd0e1-417c-4571-98ac-435e30943db7 3:24:23 PM: info No Rachio AuthToken Found... Please Login to Web App > Account Settings > Get API Key...
572fd0e1-417c-4571-98ac-435e30943db7 3:24:08 PM: info No Rachio AuthToken Found... Please Login to Web App > Account Settings > Get API Key...
I deleted it from the My Smart Apps section in the IDE. After that I looked in the Installed SmartApps like your screenshot and it wasn’t listed there. Should I try removing it differently?
Make sure the Rachio devices aren’t listed under My Devices in the IDE.
I suspect since you had the old devices from the official integration that was the issue. Technically you could have went in and changed each existing device to use the Rachio manager device and been good but the new app will not work with the old official devices.
Thank you for all of your help and suggestions. Unfortunately, I’m still unable to get this working and I’m really puzzled.
I tried again for a fresh install:
This time, I removed everything via the IDE
I went into My Locations
Then into Devices and removed all of the Rachio entries
Then into SmartApps and removed the Rachio entry
Then into My Device Handers and removed the 2 device handlers
Then into My Smart Apps and removed the Smart app
I then rebooted the hub
I confirmed that in the IDE and in the App there weren’t any installed Rachio Devices, Device Handlers, Smart Apps or Smart App “handlers”
I then installed the Rachio SmartApp “handler” and the 2 device handlers via the Github integration into the IDE
I enabled OAuth in the Smart App
Then, in the App and I installed the Smart App from My Apps
Then added my API key, selected my Rachio and my 6 zones
The 6 Rachio Zone Devices and one Rachio Controller Device were added. The once again have the names that I had renamed the original devices last year (even though they’ve been deleted multiple times).
The Rachio devices all show watering and don’t update when I start or stop a Rachio zone from actually watering
I looked in the IDE and the Rachio Devices are using the Community Rachio devices and not the official integration
Have you looked into using the Rachio webhooks for events? I quickly edited the smartapp to poll every 30 seconds and I found out that they rate limit API requests.
If you haven’t already started to look into it I might take a crack at it. I want the sprinklers to open a zwave controlled water valve and it would be nice for there to be no delay at all with it.
Nothing ever good happens after 2AM
I think I was using the official published one before (which i don’t believe was using webhooks), so I took yours and modified it to have a higher poll interval before i even thought to look to see if you already had it done.
Im going to go ahead and comment out the rapid polling now.
+1 to that. I’ve caused a lot of problems while coding late at night.
The official one is the same (I wrote it) I only released the public one to push out Rachio API fixes because ST submissions are very slow.
I recently added support for multiple controllers to the public one which will eventually be submitted to ST.
If you are seeing events issues where real-time events are not occurring (~2sec) let me know.
I’m having a heck of time with getting this installed.
I had the official version installed (1.0.0).
I tried installing “manually” (like I do all smart apps) and it installs but I don’t see any devices.
Now one thing I did do was I uninstalled the Old one AFTER I installed the new version (Rachio Manager 1.1.1).
I tried reinstalling the new one again (with the old one removed first) and same result no devices.
I did notice that you also have a couple devices over on GitHub.
So then I figured ok, I’ll try the community installer (which handles dependencies?). Which goes fine until I click “Installer Home”. Not clear what that even is, but it asks for SmartThings or Samsung account. I have an IDE Account and a SmartThings Community Account (neither works).
This time it ASKED me Samsung or Smartthings Account.
I enter my Samsung account (that I just verified on the web) and it Failed too. Tried several times.
Then, I entering the same Samsung Login info the “Failed Login” page and that logged in !!
When I enter my SmartThings account email (which is different) it never prompts for Samsung vs SmartThings Account and appears to jump straight to Samsung login (which does not use that email), so it always fails.
Now it’s just stuck saying “Loading Data, Please wait”. This is so painful.
I’m only looking into this because Rachio (standalone) seems dumber than a brick. I think it’s main issue is poor weather prediction and past rain. I think if it gets that data correct it works “ok”. If not, it’s runs like crap (over or under waters).
I was tempted to get the RainMaster because it allows several sources of weather data and I’ve had very good luck with Weather Underground data in the past. Which Rachio doesn’t support. So I thought I’d look into doing it myself. I had done it before with SmartThings.
It never finished Loading Data. Tried a 2nd time and the whole login mess happened again. And it got stuck again.
Then I understood what it meant by Embedded vs Mobile Browser and switched it to Mobile Browser.
Entered my SmartThings account it went right in and Displayed the Community Apps.
Is there ST github intergration for easy updates? Sorry if I missed it, I’m outside sweating bullets installing this new rachio 3 controller in enclosure.
Like stated above, you should really use the ST Community App Installer listed above. @tonesto7 does have the Github repo as well, but just install the community installer and it will make it super easy through the ST app.
I can not remove the smart app from the IDE i have removed all the device handlers but when i try to remove the app it says “This app can not be removed at this time because it is installed by one or more users” i am the only one i setting it up …
It has never worked i did the branching from Tonseto repo on github but always the same watering and red dots beside the zones so i thought i would retry again
Denis
No luck here
I have never been able to integrate Rachio with smart things i should have saved some money with rain machine and just gone the IFTTT route.
I love Rachio and its own app but i bought it specifically for ST integration and although i have uninstalled the device handlers and smart app a million times and used this ones from this post and github always the same result …red dot by the side and watering.
what am i doing wrong is it actually working for someone ??
D
