That simply is not true. I use this switch to control GE+Link bulbs (Zigbee), Z-Wave wall switches, and anything else I want to control on/off state on. The device handler is only about receive the events from the switch. The control of the bulbs has only to do with the device handler for the bulb, and the SmartApp controlling the target device. The switch is not paired to the light in anyway, it is paid to the hub, and hub is responsible for everything else.
My suggestion to @xdreamwalker is to control the bulb directly from the ST app. If you can manually turn the bulb on/off and if dimmableâdim it, then the issue is your SmartApp that is controlling the bulb.
The Device Handler for the switch has only one purpose, to translate button pushes into button press events. Just take a look at the stock DH from ST to see how they implemented the logic. It becomes more clear what it happening when you look at this way. If you are using WebCore, it is likely your rules are not written correctly for the bulb.
So, it turns out ALL my lighting controls have failed to work in the past few days. I have opened up an issue with Samsung. This is a SmartThings hub issue. Nothing changed except for the recent firmware update, and I just learned all the smart apps that control lighting in any way (DimWithMe, SmartLighting, etc) all fail to execute on published events. I can use the SmartThings app to force the lights on/off, and can use Alexa, etc. But all my devices that are not load controlling no longer work. The on/off, Level Up/Down, and other events are picked up by the Device Handlers, but the Smart Apps are not being executed. To that point, even through the app, if I turn the switch/dimmers on/off, no rules are triggered. So, if you are having issues with this device handler, or the SmartThings generic Button Controller handler, itâs not your device, or your device handler, itâs the SmartThings update that broke the smart apps.
@adamoutler, have you considered removing the direct device control of bulbs and submitting this to Samsung for integration as an official device handler? I think the direct device control is the only thing that would be an issue, and your handler is a great device handler for this two button controller. Much nicer than the generic button controller preferred by the current SmartThings system.
has anyone gotten the lightify dimmer button to work right? been working on this for a bit now and I canât get anything to work. If so can you share please?
I have 3 of them. 2 of them I use as buttons to trigger ON/OFF for nearby switches (mounted low on the walls so my kids can use them. The 3rd, I use to control a pair of Cree connected bulbs. They all work well for me.
I have 6 of them but canât use them like a traditional dimmer. ST is just interpreting them as button presses/holds.
Press up - turn on various lights in a room to 100% (several different brands used which I can comment on later if desired)
Press down - turn off various lights in a room.
Hold down - turn various lights in a room to 10%
Hold up - turn off all lights but 1 in a room and set the 1 to 1% (thinking of it as a nightlight) or in some cases it togges other appliances like a/c, xmas lights, âŠ
I am using the default device handler that ST assigns.
@adamoutler
This is what I have been looking for but for the Philip Hue Dimmer Switch. It has four buttons, i.e. #1 is ON, #2 is increase brightness, #3 is decrease brightness, #4 is OFF. Will try to workout a DH using the same approach. Any suggestion?
Thank you. I am currently using the ZHA DH with Smart Lighting smartapp. The result is not ideal. The two middle buttons can only be set to a preset level of brightness levels. I am looking for DH or smartapp that can make the middle two buttons to work as what is described here, i.e. increase or decrease incrementally when either of the two middle buttons are pressed.
@adamoutler Sorry if I missed it in this thread, I noticed you mentioned under ST system locally, if I understand correctly this doesnât mean this DTH is working locally (local processing) right?
As far as I know itâl only work locally as long as itâs not a pulished (git hub integrated) DTH.
Thanks for the clarification Adam. Didnât go through the code, so the last step in your installation guide is to associate the lights you want to control correct?
Thank you Adam, so this is only capable of controlling single light then I suppose? Is it possible to control more light one light i.e. group of lights? I have trend setter group setup, but that is recognized as cloud device so I guess putting that groupâs network id in would not be local any more
So Iâm having a bit of an issue.
I strictly want to use this switch as an on/off for 4 bulbs in a ceiling fan.
It will work correctly SOMETIMES.
When theyâre off, tapping up always turns them on just fine. Full brightness, no issues.
But Iâd say 50% of the time, when I tap down, which should turn them all 100% off, they will dim to 50% or so. I can tap again and theyâll go completely off, but now if I tap up again, it only turns them on to 50%, and another tap makes them full brightness. The only way to get them out of this mode is for me to say âAlexa turn off/on the kitchen lightsâ. Using commands thru Alexa or manually turning each bulb on/off the the smartthings app always works flawless so that kind of rules out an issue with the bulbs.
Itâs almost as if the switch thinks I am doing double taps or holding the button down or something. Iâve pulled it off the wall and held it in my hands to make sure mechanically nothing odd is happening.
I wanted to maybe try and edit the code (which is out if my skill level) to delete any other control options besides up=on/down=off⊠Completely eliminating the option for dim, or hold a button to do this, push both buttons to do that. I have no need for any of that.
I just want on and off⊠Nothing more
if the switch is off pressing down will cause it to turn on at 10% brightness. The switch turns off automatically after a little while. This is a feature so you can turn the lights on to a low level instead of previous level.
Is there an easy way to disable that?
Iâm sure itâs a case of deleting part of the code, but that is not something Iâm familiar with.
I was going to make an attempt at middling the code so that it only included on and off and got rid of all the other âbuttonsâ and combo presses and such.
I just need it to function as if it were a normal paddle switch
