SmartThings Community
[RELEASE] NST Manager v5.0
thermostat
smartapp_hvac
dth_hvac
cameras
nest
#3910
Ah ok. Next time I’ll go into nest manager and hit done to see what happens.
Is there a way I can get a notification when it goes down? Is this possible in core? It’s just a pain to having to keep checking it’s done what the routine has asked it to do…
(Eric) #3911
there are notification settings in not manager you should look at. These can warn if unable to check with nest.
(Eric) #3912
Tony has posted an update that is more conservative on sending command to nest.
Please ensure your nst manager, automations and device handers are up to date
(Joey W.) #3913
Can the nest manager change the display and farsight settings? This would really help me out. Thanks!
(Eric) #3914
I’m not aware these are in their API.
If you find parameters you want in their published API (developers.nest.com), that is what we have available.
(Joey W.) #3915
OK. Thanks!
(Joey W.) #3916
Does anybody know the correct syntax for the ‘setNestEta’ command? I want to get the travel time when I leave work, from google API’s and use that for the 'setNestEta. However, I’m not sure exactly the formatting Nest requires.
(Eric) #3917
the command is
setNestEta(tripId, begin, end)
and cancelNestEta (tripid)
Tripid is a string you make up
begin and end are string times, in iso 8601 format
begin must be > now, and end must be > begin (in time)
https://developers.nest.com/guides/api/away-guide
(Joey W.) #3918
Thank you. I’m new to webcore and smartthings. Is there a quick way to format a webcore date to iso8601?
(Eric) #3919
I expect in webcore you would use formatDateTime
https://wiki.webcore.co/Functions#formatDateTime
I expect the format string looks something like: “yyyy-MM-dd’T’HH:mm:ssZ” or “yyyy-MM-dd’T’HH:mm:ssXXX”
You might have luck asking some of this in the webcore forum
(Joey W.) #3920
Thank you again for everything!
(Joey W.) #3921
The documentation seems to suggest that the begin and end are just arrival window times and not the begin and end of the tip (which is what I would think). In other words, if you leave work at 5:00PM and are expected to get home 5:30PM,
I would think:
begin is 5:00PM
end is 5:30PM
but the documentation seems to suggest:
begin is 5:25PM
end is 5:35PM
Can you help enlighten me on this?
(Eric) #3922
My reading of this is
  • if you are leaving at 5:00 and expect to be home at 5:30
you would set arrival window for 5:25 - 5:45 (and you would have done this around or before your 5:00 PM
(Joey W.) #3923
Thanks again for your wonderful help.
