Check the CES 2019 Samsung logo that shows everything that will work with them.
Nest seemed like they will officially integrate… You never know
That’s an excellent thought. If we could example know it’s ‘John’ that is outside, smartthings would open the door automatically.
Yes, and it would even work with just a photo of ‘John’
I need some help and I’m not sure where to start.
I have created an automation using remote sensors and two schedule automatons to look at the upstairs rooms at night and the whole house during the day. For some reason the app seems to quit controlling the nest thermostat at random times and doesn’t kick the heat on. I’ve also had times where the heat was turned on and not told to turn off once the parameter was hit.
If I open the smarthings app and open the NST Manager SmartApp, it seems to solve the issue and starts communicating with Nest again.
I’m on version 5.5.8
Any thoughts?
IDE “live logging” should give some more insight into the operations.
You can enable debug logs for NST manager and the built-in automation (if you are using the built-in).
You don’t need to turn on trace or verbose logs, and many times it is too much data.
I turned the logs on, let’s see if it happens again soon.
can someone explain how the schedule works? I have defined a schedule in one of the automation routines using remote sensors. I am able to name the schedule period- but i dont see where you define the period (like 8am-11am M-F). Where can that be found?
It just happened again, what should I paste from the log?
This is the past hour;
7:37:32 PM: info | Manager: NST Manager (v5.5.8) | Reset Application Data Disabled
7:33:57 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:33:57 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:33:56 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:28:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:28:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:28:56 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:23:57 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:23:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:23:56 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:18:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:18:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:18:56 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:13:57 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:13:57 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:13:56 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:09:24 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:09:23 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:09:23 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:08:58 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Jordan’s Room Temp 3 | Value: (63.9) with a delay of 147ms
7:08:53 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:08:53 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:08:52 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:08:29 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Guest Bedroom Temp 2 | Value: (65.3) with a delay of 153ms
7:06:42 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:06:42 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:06:40 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:06:09 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Guest Bedroom Temp 2 | Value: (65.4) with a delay of 134ms
7:06:07 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:06:07 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:06:07 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:05:41 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Dining Room Temp 1 | Value: (65.2) with a delay of 137ms
7:05:28 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:05:28 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:05:27 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:04:58 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Guest Bedroom Temp 2 | Value: (65.3) with a delay of 135ms
7:04:52 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:04:52 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:04:52 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:04:30 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Dining Room Temp 1 | Value: (65.1) with a delay of 173ms
7:01:08 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:01:07 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:01:07 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:00:38 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (20sec) because (18sec) Left
7:00:38 PM: trace | Automation-a6b84: Default Setting | HUMIDITY Event | Device: Dining Room Temp 1 | Value: (37) with a delay of 139ms
7:00:35 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Master Bedroom Temp 4 | Value: (63.3) with a delay of 187ms
7:00:18 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:00:18 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:00:17 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Using Schedule 1 (2) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
After opening the NST manager SmartApp screen in the Classic SmartThings app, it started working fine again.
7:47:46 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Unit: (F) | Original State: (F)
7:47:46 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | nestType: (physical) | Original State: (physical)
7:47:46 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Device Type Version is: (5.4.4) | Original State: (5.4.4)
7:47:46 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | isCodeUpdateAvailable(): newVer: 5.4.4 | curVer: 5.4.4 | newestVersion: null | result: false
7:47:46 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Device Debug Logging is: (On) | Original State: (On)
7:47:46 PM: warn | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | ------------START OF API RESULTS DATA------------
7:47:44 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | UPDATED | Last Nest Check-in was: (Jan 23, 2019 - 7:47:38 PM) | Original State: (Jan 23, 2019 - 7:43:41 PM)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Parent Refresh time: (Jan 23, 2019 - 7:47:39 PM) | Previous Time: (null)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Device Type Version is: (5.4.3) | Original State: (5.4.3)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Sound Sensor State: (not detected) | Original State: (not detected)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Motion Sensor is: (inactive) | Original State: (inactive)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Event Type: (Motion Event) - Zones: null
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Event End Time: (Wed Jan 23 19:14:56 CST 2019) - Zones: null | Original State: (Wed Jan 23 19:14:56 CST 2019)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Event Start Time: (Wed Jan 23 19:14:26 CST 2019) - Zones: null | Original State: (Wed Jan 23 19:14:26 CST 2019)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | UPDATED | Image Url: (https:/removed link) | Original State: (null)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Firmware Version: (217-610040) | Original State: (217-610040)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Audio Input Status is: (Enabled) | Original State: (Enabled)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Device Debug Logging is: (On) | Original State: (On)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | API Status is: (Good) | Original State: (Good)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Online Change was: (Jan 9, 2019 - 6:51:41 AM) | Original State: (Jan 9, 2019 - 6:51:41 AM)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Nest Aware Status is: (Inactive) | Original State: (Inactive)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Public Sharing Status is: (Enabled) | Original State: (Enabled)
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Location Security State is: () | Original State: ()
7:47:39 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Camera Live Video Streaming is: (on) | Original State: (on)
7:47:38 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | isStreamingEvent(true, false)…
7:47:38 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Online Status is: (online) | Original State: (online)
7:47:38 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | onlineStatusEvent(true)
7:47:38 PM: warn | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | ------------START OF API RESULTS DATA------------
7:47:38 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (20sec) because (6sec) Left
7:47:38 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Master Bedroom Temp 4 | Value: (65.2) with a delay of 274ms
7:47:35 PM: info | Manager: NST Manager (v5.5.8) | API Device Data HAS Changed (POLL(ASYNC))
7:47:35 PM: info | Manager: NST Manager (v5.5.8) | Updating Structure Data (Last Updated: 238 seconds ago) | Updating Device Data (Last Updated: 238 seconds ago) (async)
7:47:20 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (23sec) because (24sec) Left
7:47:20 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Guest Bedroom Temp 2 | Value: (66.2) with a delay of 310ms
7:47:20 PM: trace | Automation-a6b84: Default Setting | HUMIDITY Event | Device: Guest Bedroom Temp 2 | Value: (37) with a delay of 126ms
7:46:22 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:45:52 PM: info | Automation-a6b84: Default Setting | Too Soon to Evaluate Actions; Re-Evaluation in (30 seconds)
7:45:49 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:45:29 PM: trace | Automation-a6b84: Default Setting | HUMIDITY Event | Device: Jordan’s Room Temp 3 | Value: (38) with a delay of 126ms
7:44:35 PM: info | Manager: NST Manager (v5.5.8) | No Device or Structure poll - Devices Last Updated: 58 seconds ago | Structures Last Updated 58 seconds ago
7:44:03 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Last Parent Refresh time: (Jan 23, 2019 - 7:43:51 PM) | Previous Time: (null)
7:43:51 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (24sec) because (12sec) Left
7:43:51 PM: trace | Automation-a6b84: Default Setting | HEATINGSETPOINT Event | Device: Nest Thermostat - Downstairs | Value: (71) with a delay of 78ms
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | thermostatSetPoint Temperature is (71°F) | Original Temp: (65°F)
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Heat Setpoint is (71°F) | Original Temp: (65°F)
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Safety Temperature Exceeded is (false) | Current Temp: (64.0F)
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | checkSafetyTemps: (curMinTemp: 0.0 | curMaxTemp: 0.0 | curTemp: 64.0 | exceeded: false | curRangeStr: false)
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature is (64°F) | Original Temp: (64)°F
7:43:51 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Lock Maximum is (72.0F) | Original Maximum Temp: (72.0F)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Lock Minimum is (68.0F) | Original Minimum Temp: (68.0F)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Comfort Dewpoint Maximum is (0.0) | Original Maximum Dewpoint: (0.0)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Comfort Humidity Maximum is (80%) | Original Maximum Humidity: (80%)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Safety Temperature Maximum is (0F) | Original Maximum Temp: (0.0F)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Safety Temperature Minimum is (0F) | Original Minimum Temp: (0.0F)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | API Status is: (Good) | Original State: (Good)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Firmware Version: (5.9.3-6) | Original State: (5.9.3-6)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Time to Target: (System is Idle) | Original State: (System is Idle)
7:43:50 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | SunLight Correction Active: (false) | Original State: (false)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | SunLight Correction Enabled: (true) | Original State: (true)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Online Status is: (online) | Original State: (online)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | lastCheckinEvent(2019-01-24T01:43:37.419Z, true) | onlineStatus: online | lastConnSeconds: 12 | hcTimeout: 2700 | curConnSeconds: 12
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Last Nest Check-in was: (Wed Jan 23 19:43:37 CST 2019) | Previous Check-in: (Wed Jan 23 19:31:27 CST 2019)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Fan Active: (on) | Original State: (on)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | OperatingState is (heating) | Original State: (heating)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | nestOperatingState is (heating) | Original State: (heating)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Humidity is (30) | Original State: (30)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Leaf is set to (Off) | Original State: (Off)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Hvac Previous Mode is () | Original State: ()
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | whoSetEcoMode is (Not in Eco Mode) | Original State: (Not in Eco Mode)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | NEST Hvac Mode is (heat) | Original State: (heat)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Presence - Present: (present) | Original State: (present) | State Variable: true
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Lock is set to (false) | Original State: (false)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Unit: (F) | Original State: (F)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | nestType: (physical) | Original State: (physical)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Device Type Version is: (5.4.4) | Original State: (5.4.4)
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | isCodeUpdateAvailable(): newVer: 5.4.4 | curVer: 5.4.4 | newestVersion: null | result: false
7:43:49 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Device Debug Logging is: (On) | Original State: (On)
7:43:49 PM: warn | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | ------------START OF API RESULTS DATA------------
7:43:45 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | UPDATED | Last Nest Check-in was: (Jan 23, 2019 - 7:43:41 PM) | Original State: (Jan 23, 2019 - 10:54:00 AM)
7:43:45 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Last Parent Refresh time: (Jan 23, 2019 - 7:43:45 PM) | Previous Time: (null)
7:43:44 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Parent Refresh time: (Jan 23, 2019 - 7:43:44 PM) | Previous Time: (null)
7:43:44 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Device Type Version is: (5.4.3) | Original State: (5.4.3)
7:43:44 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (22sec) because (19sec) Left
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Heat Setpoint is (65°F) | Original Temp: (71°F)
7:43:44 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Nest Thermostat - Downstairs | Value: (64) with a delay of 277ms
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Safety Temperature Exceeded is (false) | Current Temp: (64.0F)
7:43:44 PM: trace | Automation-42f22: Nest Location Home Watchdog | TEMPERATURE Event | Device: Nest Thermostat - Downstairs | Value: (64) with a delay of 244ms
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | checkSafetyTemps: (curMinTemp: 0.0 | curMaxTemp: 0.0 | curTemp: 64.0 | exceeded: false | curRangeStr: false)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Temperature is (64°F) | Original Temp: (66°F)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Lock Maximum is (72.0F) | Original Maximum Temp: (72.0F)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Lock Minimum is (68.0F) | Original Minimum Temp: (68.0F)
7:43:44 PM: info | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Automation Schedule Data for this device has been Updated
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Comfort Dewpoint Maximum is (0.0) | Original Maximum Dewpoint: (0.0)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Comfort Humidity Maximum is (80%) | Original Maximum Humidity: (80%)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Safety Temperature Maximum is (0F) | Original Maximum Temp: (0.0F)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Safety Temperature Minimum is (0F) | Original Minimum Temp: (0.0F)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | API Status is: (Good) | Original State: (Good)
7:43:44 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Firmware Version: (5.9.3-6) | Original State: (5.9.3-6)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Time to Target: (System is Idle) | Original State: (System is Idle)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | SunLight Correction Active: (false) | Original State: (false)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | SunLight Correction Enabled: (true) | Original State: (true)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Online Status is: (online) | Original State: (online)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | lastCheckinEvent(2019-01-24T01:31:27.700Z, true) | onlineStatus: online | lastConnSeconds: 736 | hcTimeout: 2700 | curConnSeconds: 736
7:43:43 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (24sec) because (20sec) Left
7:43:43 PM: debug | Automation-a6b84: Default Setting | scheduleAutomationEval: Skipping Schedule Change: (21sec) because (20sec) Left
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Last Nest Check-in was: (Wed Jan 23 19:31:27 CST 2019) | Previous Check-in: (Wed Jan 23 10:41:15 CST 2019)
7:43:43 PM: trace | Automation-a6b84: Default Setting | THERMOSTATFANMODE Event | Device: Nest Thermostat - Downstairs | Value: (On) with a delay of 58ms
7:43:43 PM: trace | Automation-a6b84: Default Setting | THERMOSTATOPERATINGSTATE Event | Device: Nest Thermostat - Downstairs | Value: (Heating) with a delay of 50ms
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | OperatingState is (heating) | Original State: (heating)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | nestOperatingState is (heating) | Original State: (heating)
7:43:43 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Fan Mode: (On) | Original State: (Auto)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | OperatingState is (Heating) | Original State: (Idle)
7:43:42 PM: trace | Automation-a6b84: Default Setting | HUMIDITY Event | Device: Nest Thermostat - Downstairs | Value: (30) with a delay of 62ms
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | │ Took Snapshot: (true)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | nestOperatingState is (Heating) | Original State: (Idle)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | └──────────────
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Humidity is (30) | Original State: (25)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | UPDATED | Image Url: (https:removed link)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | UPDATED | Leaf is set to (Off) | Original State: (On)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Firmware Version: (217-610040) | Original State: (217-610040)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Hvac Previous Mode is () | Original State: ()
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Audio Input Status is: (Enabled) | Original State: (Enabled)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | whoSetEcoMode is (Not in Eco Mode) | Original State: (Not in Eco Mode)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Device Debug Logging is: (On) | Original State: (On)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | NEST Hvac Mode is (heat) | Original State: (heat)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | API Status is: (Good) | Original State: (Good)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Presence - Present: (present) | Original State: (present) | State Variable: true
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Last Online Change was: (Jan 9, 2019 - 6:51:41 AM) | Original State: (Jan 9, 2019 - 6:51:41 AM)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Nest Aware Status is: (Inactive) | Original State: (Inactive)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Lock is set to (false) | Original State: (false)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Public Sharing Status is: (Enabled) | Original State: (Enabled)
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Temperature Unit: (F) | Original State: (F)
7:43:42 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Location Security State is: () | Original State: ()
7:43:42 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | nestType: (physical) | Original State: (physical)
7:43:41 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | getCamApiServerData resp: (status: 200) | data: [items:[[capabilities:[statusled.watching.on_off, image.properties, force_idr, usb_setup, streaming.data-usage-tier.120, streaming.cameraprofile.VIDEO_H264_100KBIT_L30, aspect_ratio_16x9, audio.gain, streaming.start-stop, audio.microphone, night_vision, streaming.params, streaming.cameraprofile.VIDEO_H264_2MBIT_L40, video.flip, stranger_detection.disallowed, btle_setup, statusled, streaming.data-usage-tier.300, streaming.cameraprofile.VIDEO_H264_530KBIT_L31, sharing, backfill, watermark, talkback.chime, labs, notify.email, audio.speaker, talkback.chime.on_off, dptz, irled, standby, detectors.on_camera, dptz.8x, streaming.data-usage-tier.30, statusled.watching, statusled.on_off], description:, direct_nexustalk_hdeleted info3, name:Jordan’s Room, nexus_api_http_removed link, where:Jordan’s Room]], status:0, status_description:ok, status_detail:]
7:43:41 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Device Type Version is: (5.4.4) | Original State: (5.4.4)
7:43:41 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | isCodeUpdateAvailable(): newVer: 5.4.4 | curVer: 5.4.4 | newestVersion: null | result: false
7:43:41 PM: debug | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | Device Debug Logging is: (On) | Original State: (On)
7:43:41 PM: warn | Thermostat-c1562: Nest Thermostat - Downstairs (v5.4.4) | ------------START OF API RESULTS DATA------------
7:43:41 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Camera Live Video Streaming is: (on) | Original State: (on)
7:43:41 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | isStreamingEvent(true, false)…
7:43:41 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | Online Status is: (online) | Original State: (online)
7:43:41 PM: debug | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | onlineStatusEvent(true)
7:43:41 PM: warn | Camera-d13ca: Nest Camera - Jordan’s Room (v5.4.3) | ------------START OF API RESULTS DATA------------
7:43:37 PM: info | Manager: NST Manager (v5.5.8) | API Device Data HAS Changed (POLL(ASYNC))
7:43:37 PM: info | Manager: NST Manager (v5.5.8) | Updating Structure Data (Last Updated: 9 seconds ago) | Updating Device Data (Last Updated: 10 seconds ago) (async)
7:43:33 PM: info | Manager: NST Manager (v5.5.8) | nestCmdResponse | Processed Queue: 0 | Obj: (devices/thermostats{target_temperature_f:71}) SUCCESSFULLY!
7:43:33 PM: trace | Manager: NST Manager (v5.5.8) | Processing Queued Cmd: [ObjId: eGrblPXPLLe3Uw4O1GFsiDM8Ed5Ie-RW | ObjType: devices/thermostats | ObjKey: target_temperature_f | ObjVal: 71 | QueueNum: 0 | Redirect: true]
7:43:33 PM: trace | Manager: NST Manager (v5.5.8) | Processing Queued Cmd: [ObjId: eGrblPXPLLe3Uw4O1GFsiDM8Ed5Ie-RW | ObjType: devices/thermostats | ObjKey: target_temperature_f | ObjVal: 71 | QueueNum: 0 | Redirect: false]
7:43:33 PM: trace | Manager: NST Manager (v5.5.8) | workQueue │ Run Queue: 0 | (async)
7:43:29 PM: debug | Manager: NST Manager (v5.5.8) | Too Soon for Update; Elapsed (2) seconds; minimum (null)
7:43:29 PM: warn | Manager: NST Manager (v5.5.8) | forcedPoll(null) received
7:43:29 PM: debug | Manager: NST Manager (v5.5.8) | sendMsg: Sent Push Message (NST Manager Debug Logging Reminder: Your debug logging has remained enabled for more than 24 hours please disable them to reduce resource usage on ST platform.)
7:43:29 PM: info | Manager: NST Manager (v5.5.8) | createSavedNest | Cameras(1): [HKm3B9a4fmGVxXgBpoLZEkTsEZtnCd1oL6B8rfpbOHkzPBHeSHvkVg]
7:43:29 PM: info | Manager: NST Manager (v5.5.8) | createSavedNest | Protects(null): null
7:43:29 PM: info | Manager: NST Manager (v5.5.8) | createSavedNest | Thermostats(1): [eGrblPXPLLe3Uw4O1GFsiDM8Ed5Ie-RW]
7:43:28 PM: info | Manager: NST Manager (v5.5.8) | Updating Meta Data (forcedPoll)
7:43:28 PM: info | Manager: NST Manager (v5.5.8) | Updating Structure Data (forcedPoll)
7:43:28 PM: info | Manager: NST Manager (v5.5.8) | API Device Data HAS Changed (POLL)
7:43:27 PM: trace | Manager: NST Manager (v5.5.8) | stateCleanup
7:43:27 PM: info | Manager: NST Manager (v5.5.8) | Updating Device Data (forcedPoll)
7:43:27 PM: info | Manager: NST Manager (v5.5.8) | Last Forced Update was 1000 seconds ago.
7:43:27 PM: warn | Manager: NST Manager (v5.5.8) | forcedPoll(null) received
7:43:27 PM: info | Manager: NST Manager (v5.5.8) | createSavedNest | Cameras(1): [HKm3B9a4fmGVxXgBpoLZEkTsEZtnCd1oL6B8rfpbOHkzPBHeSHvkVg]
7:43:27 PM: info | Manager: NST Manager (v5.5.8) | createSavedNest | Protects(null): null
7:43:27 PM: info | Manager: NST Manager (v5.5.8) | createSavedNest | Thermostats(1): [eGrblPXPLLe3Uw4O1GFsiDM8Ed5Ie-RW]
7:43:26 PM: trace | Manager: NST Manager (v5.5.8) | stateCleanup
7:43:09 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:43:09 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:43:09 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:42:45 PM: trace | Automation-a6b84: Default Setting | TEMPERATURE Event | Device: Master Bedroom Temp 4 | Value: (64.3) with a delay of 129ms
7:42:00 PM: info | Manager: NST Manager (v5.5.8) | Reset Application Data Disabled
7:38:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - HeatSetpoint is already (71.0°F)
7:38:56 PM: info | Automation-a6b84: Default Setting | Remote Sensor: HEAT - Adjusting HeatSetpoint to Turn On Thermostat
7:38:56 PM: trace | Automation-a6b84: Default Setting | setTstatTempCheck: Schedule 1 (1) use Motion settings: false | isBtwn: false | previousBtwn: false | motionOn null
7:38:29 PM: info | Manager: NST Manager (v5.5.8) | sendFirebaseData({“guid”:“303f822d-5b25-4abf-a9b9-11bb129dc54f”,“beta”:false,“versions”:{“apps”:{“manager”:“5.5.8”,“automation”:“5.4.9”,“service”:“Not Installed”},“devices”:{“thermostat”:“5.4.4”,“vthermostat”:“Not Installed”,“protect”:“Not Installed”,“camera”:“5.4.3”,“presence”:“Not Installed”,“weather”:“Not Installed”}},“thermostats”:1,“protects”:0,“vthermostats”:0,“cameras”:1,“appErrorCnt”:9,“devErrorCnt”:0,“installDt”:“Wed Oct 25 08:14:11 CDT 2017”,“updatedDt”:“Tue Jan 01 10:39:24 CST 2019”,“automations”:{“disabled”:0,“nestMode”:0,“remDiag”:1,“schMot”:{“remSen”:1,“tSched”:1},“storage”:0,“watchDog”:1},“timeZone”:“America/Chicago”,“apiCmdCnt”:6108,“apiStrReqCnt”:77279,“apiDevReqCnt”:78004,“apiMetaReqCnt”:1101,“appNotifSentCnt”:11,“apiRestStrEvtCnt”:0,“appUseMetCnt”:{“appNotifPrefLoadCnt”:0,“autoGlobPrefLoadCnt”:0,“autoLoadCnt”:5,“camZoneFltLoadCnt”:0,“chgLogLoadCnt”:2,“custWeathLoadCnt”:0,“devCustLoadCnt”:3,“devCustNameLoadCnt”:1,“devLocLoadCnt”:0,“diagLoadCnt”:0,“helpLoadCnt”:15,“infoLoadCnt”:0,“logPrefLoadCnt”:6,“mainLoadCnt”:30,“nestLoginLoadCnt”:0,“notifPrefLoadCnt”:0,“pollPrefLoadCnt”:0,“prefLoadCnt”:6,“protTestLoadCnt”:0,“vRprtPrefLoadCnt”:0,“viewAutoSchedLoadCnt”:0,“viewAutoStatLoadCnt”:0},“devUseMetCnt”:{“tstatVoiceRptCnt”:0,“tstatManTmpChgCnt”:0,“tstatProgTmpChgCnt”:5915,“tstatManModeChgCnt”:3,“tstatProgModeChgCnt”:51,“tstatManFanChgCnt”:1,“tstatProgFanChgCnt”:0,“tstatHtmlLoadCnt”:49,“camManStrChgCnt”:19,“camProgStrChgCnt”:0,“camHtmlLoadedCnt”:37},“stateUsage”:“13%”,“mobileClient”:“android”,“liteAppMode”:false,“datetime”:“Wed Jan 23 19:38:28 CST 2019”,“optOut”:false}, clients/303f822d-5b25-4abf-a9b9-11bb129dc54f.json, null, heartbeat
So I’ve been trying to figure out if nst manager works on the new ST app and well it works to the extent that the smart app is there and that I can do some changes like in classic, but I can’t see my camera live feed? Seems like they are listed as motion detectors on the new app… Is this how it is or have I missed something? Thanks.
Hey I’m a new user and installed the latest Nest Manager but I can’t obtain a Client Id and secret. I went to the nest developer page but it looks like they are no longer accepting new developers. How can i get this to work now?
I still get nest developer data missing when i go to the smart apps on my mobile device?
![image|690x102](upload://uYNDsPp9xieOqM5ujpnAh9SLc3V.pn
OK I’m past the client id stuff but now the part that should be very easy isn’t. I’m logging into my nest account via the app and it gives me the following. I just verified my user name and password and it works fine. what am i missing now?
I need help when creating nest product in nest developer account.
When I reach the point of setting up permissions for thermostat, I click on “thermostat read/write v6” as per instructions, but then it pops up a box like this:
What do I enter here? There are no instructions anywhere for this and I googling didn’t help.
Thanks in advance.
did you read the instructions in the following link?
Still getting the nest error message when i try and log into my nest account. Does anyone know what I’m missing I’ve reviewed the instructions but i must have missed something. any help would be appreciated. Thanks
Edit: If I type in the wrong pass word it says i have the wrong user name and password but if i type in the correct password it just says oops.
it sounds like a problem in the settings in the developer account and/or cut / paste of id/secret
I finally got it figured out. Thanks
Yes the default text typed there was intimidating, I (stupidly) thought something complex need to be filled up. Just pasted a description and it worked. Thanks for responding.
