It would be good to see logs to understand what is happening.
I have seen folks have nests “home/away assist” be enabled on some devices (commonly if you add new nest equipment), and I have seen a couple of things happen:
a) home away assist starts “flip flopping”, so it sends a lot of changes into Nest mgr
b) if you have an automation (built in Nest manager, or other automations WebCoRE, etc) monitoring home away or modes, they can start sending a lot of commands during a “flip flop episode” that causes api commands to exceed limits (ie fail).
Without seeing longs, above is just guesses. IDE logs are best. Sometime hitting save can clear it up, sometimes you have to ensure “two more more automations stop fighting it out”. (ie watch nest mode (built in), WebCoRE, and home away assist)
Thanks Eric. The log told me everything I needed to know. I just hadn’t added Nest storage App. Once added, everything is working. sorry for the bother.
I’m having the same issue as ciscosurplus. Both with the community installer and manual installation none of the settings fields are showing. Just “Add setting definitions in the source code and then set the values here”.
I had to save and publish a few times and then the field just appeared again.
i’m still stuck. my NST manager appears as if it’s working. but it’s not. when I try to use my action tiles, and verify that the temperature changed. it hasn’t. I still am getting an access denied error! and I even created a new developer account and got a new token. still not working. if anyone could help, I would appreciate it.
Thanks to tonesto7 for this great code! I am new to Nest Manager and am installing the latest release for the first time. I am having a few basic problems installing the code into Smartthings IDE.
I used my current github integration to do the installation.
I clicked the publish checkbox and installed all three modules (Manager, Automations, Storage).
I went to enable OAuth and I got a 505 error message “You do not have permission to view this page”
I tried to delete them and either got the above of a 500 Internal Server error.
So, I’m stuck before I’ve started unfortunately. Has anyone else encountered these issues?
