Either this is some sort of ST issue going on, or there may be an issue with the previous token within the SmartApp and it won’t allow you to update the Settings.
@tonesto7@E_Sch. This is the 2nd person so far that can’t update the Settings in NST Manager and receiving 403 error. Replacing old expired token with new Nest Developer token. I’m sure there are going to be more. Can you investigate to see if this is an ST issue or something that can be resolved within NST Manager itself?
Two different shards where access was denied. Just FYI.
I had the same issue but i just re signed in to Nest and it seems to be working again apart from my thermostat, which I noticed last night that it last checked in on sunday 4th of Feb @ 9:37:27. Any ideas what i’m looking for to fix? all the other devices are fine.
I previously had a working token and now I get the screenshot on the botton. There is no way to enter in the token information. I logged into my Nest Developer account and everything looks fine on that end.
I noticed when I log into the native Nest app and look at my “Works with Nest” connections, I no longer see NST Manager. It appears that it might be permission related.
Also fwiw, I just starting using @tonesto7’s Community Installer app to update NST Manager and perhaps that played a role in this?
Edit: I put the Nest Developer token info into the settings(except for devopt, as I don’t know what that is) in the the NST Manager smartapp in the IDE and the STmobile app now asked me to log back in to my Nest account and permissions now show up in Nest native app, but in ST it doesn’t appear NST Manager is working. I am also getting mobile app errors saying it’s unable to remove my devices. In device selection, it says Null for location so it doesn’t appear it’s connecting to my Nest account properly. In the IDE, I am getting warnings about No Structure found. Here are other errors I see jn the IDE logs. I am really helping I don’t have to rebuild everything from scratch as this would be like the 6th time
I reset everything up due to the nest Developer account issue but now my automation wont work I keep getting temp not separated by 3. My set points are 69 and 72 I have tried spreading them more and it does the same error. Any help please…
Hmmm…@TonyFlesher above mentioned that after he removed everything and started over, it’s working for him. I would think if Nest is actively blocking requests, it would be an all or nothing deal, right?
It sounds more likely a ST platform issue if anything. I just got home and my routine didn’t trigger either. Here we go again.
