To do this requires a custom vid.
How can we create a custom vid?
Use the CLI, see the developer subforum there is a very long thread on it
Am I being thick? I canāt seem to get this to work. Iāve looked through all the other replies and canāt see that anyone else is having issues.
Iāve created my fork of the code, and uploaded the app and device handler into the IDE.
When i try and run the device manager smartapp it says that it is unable to connect. but then creates a thermostat with the temperature at 23 degrees C, but i canāt do anything to edit it.
you must select a humidity sensor as well, even though it says optional.
It works totally fine for me as long as both temperature humidity and one outlet are selected.
looks like its something to do with the temperature sensor Iām using (Shelly IOT HT sensor). Iāve changed it so that its using my hive thermostat instead and all loads ok
