Alarm volume seems to also control the chime volume.
If i set alarm to 3 and chime to 1 volumes, all three switches just play different tunes at the highest volume. So what is the point in having chime volume if it just plays at the volume of the alarm?
About 12 hours ago you posted and PM’d me about the Zipato Siren so do you have the NEO Coolcam Siren are you trying to use this handler with that device?
I believe the new version of the Zipato Siren looks a lot like the NEO Coolcam siren, but the firmware is different so it’s not fully functional with the siren DTHs I’ve written for NEO, Dome, or Zooz.
Go into the Hub utilities section of the IDE and perform a general exclusion. The exclusion instructions should be in the manual. After the device has been excluded try adding it again through the mobile app.
This usually happens because of either something extra being copied or something not being copied so when you go to copy the code from GitHub you should click the “raw” link which will open the code in a new window and make it easier to copy.
I have just bought the Neo Cool Siren with Green Light. I have installed and assigned your device handler. I am trying to monitor my wet sensors and I used the home monitor in the classic app but I do not have an option to change the volume or change the sound. Is there another way that would give me that option. Also in the device interface in the classic smartthings app I am not able to just trigger the light only without the sound. When I tap on strobe the sound comes on. I would appreciate your help. Thank you.
Thank you for the reply. How about adjusting the volume ? Is that possible? Thank you again. I also did not see the DTH for NEO listed on your github main page.
Sorry, I was thinking of a different DTH I wrote. I implemented the chime feature in this DTH with switch level.
Select the device as a light/dimmer in any mobile app and set the level to the corresponding sound #. I’m not sure if ST supports 1, 2, 3 so I also mapped those to 10, 20, 30…
