I won’t be converting the Neo Coolcam Door/Window Sensor DTH into an Edge Driver so it will stop working once the Groovy platform is retired, but it doesn’t need a custom driver
The Neo Coolcam devices I have were discovered as Z-Wave Door/Window Sensor Devices so didn’t need a DTH and they work locally. What is the benefit of using this DTH vs the ST one ?
Just the ability to change the configuration parameters.
Users that need to change the parameters are probably better off using this handler to change them and then switching back to the built-in handler so that the device executes locally…
I have an Inteset Door/Window Sensor which is supposed to be a rebranded Coolcam Door/Window Sensor, but when I add this DH and update the fingerprint so it is recongnized, the open/close sensing doesn’t seem to work. I tried resetting the device and adding it again, but that didn’t help.
The generic Smart Things DH seems to work.
The RAW Description for this device is: zw:Ss2 type:0701 mfr:039A prod:0003 model:0101 ver:2.12 zwv:6.02 lib:06 cc:5E,9F,55,6C sec:86,73,85,8E,59,72,5A,80,84,30,71,70
