is it not possible to use custom capabilities and presentations for adding those buttons ?
I am asking because I am also working on migrating one of my custom devices to the new style.
I actually succeeded in showing custom states on the new ST but for the buttons I was not successful.
Agreed, when they stabilize it sure… But at best its a stopgap. This should be implemented as a cloud connected device in the new paradigm. Given the choice of a do-over. Thats probably the best way.
Neato Device Handler updated to v1.14. Moves necessary tile settings to device settings so they can be configured in New Smartthings app. As I said, this is a temporary fix as I think the whole thing may need a rewrite over the next year.
You’ll notice a webcore option for each of the settings. That’s for those people who want the settings controlled via a webcore piston rather than in the device handler itself.
This is normal for any DTH if you add/change a vid in a DTH and the device is already installed. It only reads the vid at installation or a major change to the device.
You can remove and add the device, buy the easiest way to force an update is to edit the name for the device in the IDE. Force close the app and you should see the change.
I have added some more info. @Alyc100 have you had a look at the official robotcleaner capabilities? If those are added I could probably add some more fancy controls.
@cscheiene was posting a prototype of something thats possible with the new Robot Vaccum capability as well as custom capability. Most of this stuff is still very beta, experimental and not ready for primetime. The ask was for those features to be incorporated into the Neato (Connect) DTH as its being updated - not a functional DTH.
