That fixed my issues of not being able to control the doors from the My Home screen. It also fixed the issue with my webCoRE piston. Now I can tap them and they as they should. Thank you!
I have had the new device handler installed for 1.5 hours now and it hasnāt gone unavailable. Thanks!
Iām not sure what to doā¦? Iāve run the Z-Wave Repair Utility 3 times in hopes of solving this, but it doesnāt appear to help. This morning when they were unavailable I went to each device and operated it and it resolved the issue. Thatāa not the case now.
Do you have Device Health turned on? If so, could you try turning that off? I have no idea what āUnavailableā really means in the classic app anyway.
What does it look like if you click on one of those Unavailable doors?
Yes, I have device health turned on. Iāll turn it off
When I click on it, it appears as usual but has a grey bar across the top that says itās unavailable. It still seems to operate.
I went in to take a screen shot for you and now they are all āavailableā? I donāt know enough about ST to give you much to go onā¦ All I know is everything was great after the new DH this morning. There was a funky instance that appeared to be widespread in the community where I couldnāt view my devices for about 30 minutes. Everything appeared fine after that, then when I opened ST I was greeted with āunavailableā again for two doors. Now, (one hour later) all is good againā¦
My GD is unavailable again.
Just feedback: Woke up this morning and I still have all of my doors. Device health has been off since last night at Brianās recommendation.
Sorry you guys are having trouble. I hate that I canāt reproduce on my end.
At @storageanarchyās suggestion, I just pushed another small update to the device handler to try and resolve the āunavailableā issue. Iām about 98% sure itās caused by me adding the āHealth Checkā capability to the handlers, and something related to that isnāt working correctly. It was one of the things I added to improve support for the new ST app, but if it keeps causing trouble for people, Iāll just remove it altogether until I get it sorted out.
I still appear to be OK at this point on my end. Will it be of any assistance if I stay on the current version with health off and report status?
IMHO, and as a collaborator of Brianās on MyQ Lite, it would be great if you could get Brianās latest and then re-enable Health Check. You can always disable Health Check if it still doesnāt work. If you do try the new version, just let Brian know if it does or doesnāt work.
Sorry for the delayed response - family arrived todayā¦
OK, Iāll get the DH upgraded to the latest and see what happens with device health turned on. Iāll report my results.
For the record - I am currently having no issues and everything seems flawless from the last update since I turned health off.
I just updated the DH and turned on device health. As soon as I opened ST, this is what I had:
I included a screenshot of the device itself this timeā¦ I turned device health off and the unavailable went away. The doors are operating.
It would be great if you could turn on Device Health again after you have had the new code installed for a few hours. Than open and close the doors, and then wait for another 3 hours - and THEN check if they are still marked as bad.
I know, that can sound silly, but the way that device health works, it can take a bit to get things synchronized for devices that otherwise Report no activity for 12-24 hours.
Ok, Itās on now. All doors were unavailable. I went into each device and operated it, as soon as I did they all became āavailableā. Iāll monitor status through the day and report back.
Alright, I did some more digging into this today, and it looks like the health check capability is just not quite ready for 3rd party apps like this one. I have removed it for now and pushed new versions of the handlers. Could you update your code and see if that helps?
Updated DH per your request. For what itās worth I had two doors showing UNAVAILABLE again before I didā¦
Thanks to all for the ideas, persistence, and hard work. Iāll report my results. All (5) doors appear to be working now.
Iām having trouble with my doors responding today. I donāt know if itās the new DH (installed last night) or an issue with the MyQ server. Itās taking several attempts to get the doors to operate. Nothing consistent.
Iām thinking there were some MyQ issues. Initial indications this morning appear everything is back to 100% operational.
Just wanted to drop a line in and say great work! Easy install and working great! This is coming from a day-2 user of Smartthings.
Thank you for this, I purchased it on Black Friday not realizing that it doesnāt have native z-wave support like some of the other devices out there. I ended up buying the Smartthings multipurpose sensor a couple of days later after I installed it and realized it wouldnāt all work together and now things seem to be working good with IFTTT/Assistant. I have a couple of questions:
The Smartthings tilt sensor seems to be polling like crazy and itās draining the battery (7% since last night). Is this normal? Any idea on whatās going with it?
