Yes, mine is working.
Well that blows my theory out of the water. I wish I knew what was going on. I really need to mow the yard but Iām too lazy to manually push the button.
Yes mine is working as well. Mine did stop a couple of weeks ago but after updating the code to the latest it started working again for me.
Iām still running the code I originally used when creating the app over a year ago. With the app working for some and not others I was worried about updating the code until there was a sure fix. if it worked for you Iām going to compare the latest code to what I have and give it a shot. Thanks.
That would almost certainly do it. Update to the latest code and see how it goes.
Sure enough that did it. I was still running code dated 03/2017. I installed the newest code from the gethub (dated 11/2017) and my garaged door smartthings control is back! Well, I sure feel pretty dumb . And know. to mow the yard . Thanks guys!!
Iām having the same issue. Stopped working yesterday. I updated the smart app code and it went from no supported devices to bad username and password.
Just added this to my app this afternoon, using the non-sensor version. Works perfectly for me from my app and using the tiles for Alexa voice control. Not sure if the MyQ portals are all pointing to the same location at all but Iām using the Craftsman Assurelink to login for my device control.
Once I purchase and add a tilt sensor, get the sensor added to my hub and then add the DTH with-sensor code, do I delete the existing SmartApp and no-sensor code and rerun through the setup to get it to use the sensor version?
No need to delete - just tap through the setup again, this time selecting the sensor, and it should automatically switch over to the other device type. That said, I havenāt tested that piece too heavily, so if you run into issues, deleting and reinstalling should do it for sure.
Thank you! Once I get to that phase/step Iāll report back my experience or any issues I ran into.
This stopped working for me a number of days ago. I just looked up this thread again and updated the code to the latest version (Device Handler and Smart App). It still says it canāt find any supported devices when I try logging in with my credentials.
Any advice? Thanks!
Is anyone using this with the Samsung Multipurpose Sensor only? Is the multipurpose enough on its own to detect if the door is open / closed? Or do you still require a tilt sensor with it.
Thanks.
I had to completely remove the ap and re install it to get it working again. From the IDE and the phone. Then it started working.
Is this working? I go to SmartThings Classic on my phone and donāt see the SmartApp at all, but it appears Iāve added the device handlers and SmartApp correctly.
Make sure to login to IDE @ https://account.smartthings.com when adding your smart apps/device handlers and make sure to publish the smart app
The multipurpose sensor can handle the open/closed. You donāt need a tilt sensor on top of it. You can set up the Samsung Multipurpose Sensor as a garage sensor. Position it so the line (magnet) is facing to the right when mounting.
In case anyone was wondering about the MyQ outage today (June 7, 2018), here is a post on their community forumā¦
Dear myQ user,
We experienced an electrical outage today that affected our myQ servers. We have identified and corrected the root cause and are currently restoring service. For updates, visit www.chamberlain.com/support.
Please accept our sincere apologies for any inconvenience, but rest assured that at no time during the outage has any data been compromised.
Thank you for your patience while this issue is being resolved.
-The myQ Team
I also have experienced that the app stopped working about a month ago. I keep getting the ādevice unavailableā or something like that comment. I have tried to remove the app from āmy smartappsā on my phone but it never works. I have removed and reinstalled from the IDE platform.
Any ideas?
Are you using the SmartThings Classic app or the new SmartThings (Samsung Connect) app?
I am Using the classic app.
