that fixed it !!! Thank you !
I got a notification that a new version was available and I just want you to know in case you did not change versioning.
Will it be OK if I stay on the prior version and not update to the new method using the 3rd party server? Itās not like I am concerned about security but it is working now without the need for an other layer. I am thinking if I get a token error down the road I will try to use the exe you gave us to create a new key. With this I would not ask for help or support. If it fails I would then update to the new version.
If itās working for you as-is, you do not have to upgrade. Iād suggest turning off update notifications in the SmartApp. For what itās worth, the new version does still have an option to provide a token and avoid the other server callout.
I just updated from the Repo and stepped through config selecting email/password. All appears to be working fine. Thanks!
I just recently added the MyQ integration into my smartthings app to replace the integration I had with Hubitat. It seems I have things set up properly as I am able to control the garage door with the app. I am trying to set up an automation to open the door when I arrive home. However, I have the geolocation set up and created the automation, but it does not seem to be working. Is there something else I need to setup or check. I do not have a smartghings hub, so i assume this should still work fine. When I check my settings for geolocation, I see a red exclamation point on the section for āGet your location from this phoneā. When I go there, i do not see any issues. I am using an iphone 11 with the ios15 installed. How do I get this working?
What device Handler did you use for that zigbee relay? Also how did you get the momentary output to work with SmartThings?
The relay installed as a switch so no device handler is needed.
The default behavior of relay is momentary.
Best regards.
Well I just installed it (installed as Zigbee switch). When I click it in SmartThings it just stays on Untill I push it again it turns off. So the momentary doesnāt work. Maybe I need to figure out how to configure it in the relay?
Best Regards!
I remember reading the tiny manual and itās says something about momentary being the default but there were settings to allow you to change it to be momentary or on/off.
SmartThings automations will allow you to make a switch into a momentary switch as well:
In the above example when the switch turns on then it turns off after 4 seconds. You have control over how long you want it to stay on before it turns off which effectively creates a momentary switch.
My first choice would be to make the relay do it automatically. If for some reason the automation doesnāt run it could leave the switch on and drain the battery of your remote.
I got it working. The relay must have been defaulted to latched. I pushed the mode button on the relay circuit board once and that switched it to momentary.
Excellent.
I am glad it worked out.
Best regards.
Would some please assist me as I am getting the following error
In the IDE under Device Settings > Update from Repo > SmartThings_MyQ(Master.
in the New (only in GitHub) I see 6 items to select.
I select them all then select Publish then press Execute Update.
I receive the following error.
Oh No! Something Went Wrong!
Error 500: Internal Server Error
URI/ide/device/doRepoUpdates
Reference Id 35c923dc-2d0c-4e1b-ad77-6dc9577e720c
Date Mon Sep 27 14:39:21 UTC 2021
Any suggestions on how I can fix this.
Did you only choose the .groovy files? Make sure you donāt select any of the json or other types.
You should not check any of those boxes. The actual handlers would be .groovy files. This tells me you already have them. If updated, they would show up in a different column.
Hi Brian, great job. Iāve been using this since you introduced it. Lost functionality after the API update and didnāt bother with the token. Iāve only now updated to the latest version and am getting this error in the log for my Garage Door device:
groovy.lang.MissingMethodException: No signature of method: script_app_8fb9dd85bac8a88e782ad0a79853b4147208848154db9f050642b2b0bc28e130.sendCommand() is applicable for argument types: (java.lang.String, java.lang.String) values: [CG08430433E6, close]
Possible solutions: sendHubCommand(java.util.List), sendHubCommand(physicalgraph.device.HubAction), sendHubCommand(java.util.List, java.lang.Object) @line 117 (close)
That sounds like you may have updated the SmartApp but not the device handler (or vice versa)?
I thought so, too, but the Update from Repo didnāt show any Obselete items. I then proceeded to delete the DH and re-add it. Still the error.
Did you tap to modify your devices in the MyQ smartapp?
