[RELEASE] My Next ManagerV2 for your Nest® products
_ For all Nest users regardless if you have a Nest or Google account, my code can expose all your Nest Tstats, Protects, and Sensors under your Nest primary account (except the ones from a partner program such as with an utility).
_ If you have lost your auth tokens from Nest and/or migrated to a Google Account, and your ST-Nest integration is not working, then the new versions of MyNextManager (V2) MyNextTstatV2, MyNextAlarmV2 and MyNextSensorV2 may be for you.
_ MyNextManagerV2 leverages the standard ST UI (for faster rendering on both Android & iOS) & all ST standard capabilities plus new features from the Nest APIs for better synergy between the 2 ecosystems (ex. comfort & energy saving tips with the NestGetTips smartapp and voice commands).
The Next devices need to be created using the SmartThings classic mobile app, but you can switch back to the new Samsung Connect app after as both ST Classic and STSC can run in parallel without issues.
_MyNextManagerV2 (service manager for My Next devices) now uses the Nest Web APis (not the “official” APIs as they have ended since August 31, 2019). The Web APIs don’t have the strict rate limiting as the old APIs and they are as reponsive as the native Nest application.
_ MyNextTstatV2 now natively supports the following commands:
  • setHotWaterBoost: in the device UI and as a command for WebCore users. This is useful for Nest users in Europe.
  • setTargetHumidity: to set a target humidity level.
  • For the full list of attributes, capabilities & commands supported,refer to the ST community wiki:
https://thingsthataresmart.wiki/index.php?title=My_Next_Tstat
_And, MyNextAlarmV2 (for the Nest Protect) now with motion capability!
https://thingsthataresmart.wiki/index.php?title=My_Next_Alarm
_MyNextManagerV2 (service manager for My Next devices) also fully supports the Nest sensor (as a temperature sensor) in ST.
The code has been designed to work with an ecosystem of smartapps acting as “micro services”. The design is NOT a big monolytic application which limits its evolutivity and maintenance.
A contribution fee is required due to the amount of work for the design, development, and testing of the devices (equivalent of a few cups of coffee).
To download the SmartThings code, go to www.ecomatiqhomes.com/store
With your contribution, some complimentary smartapps are also available at my github for the most common use cases:
Here are some common use cases covered by the complimentary smartapps:
1) Setting your thermostat to Eco or Home based on ST hello modes
See the NestChangeMode smartapp.
2) Controlling your smart vents based on your indoor temp/motion sensors in conjunction with your thermostat’s programs & setpoints
Or See the more advanced (paid ) ScheduleTstatZones and ScheduleRoomTempControl smartapp
3) Turning off or setting your thermostat(s) to Away/eco when Window or Door contacts are open and restoring your thermostat mode when they are closed
See the WindowOrDoorOpen! smartapp.
4) Trigger to turn on/off or flash some switch(es) and/or execute hello phrases (routines) based on the thermostatOperatingState
See the TstatStateTriggerHA smartapp.
5) Sending your Tstat’s state changes to groveStreams for data analytics
See the groveStreams smartapp
6) Monitoring and setting your indoor humidity level using your humidifer/dehumidifer (when connected to Nest) and some humidifier/dehumidifier switch(es)
See the MonitorAndSetNestHumidity smartapp.
MyNextTstat
MyNestTstatP1 MyNestTstatP2
New releases:
MyNextManager v2.6.6, MyNextTstat v2.4.6
Corrected fanActive() method to avoid cast exception
MyNextManager v2.6.6, MyNextTstat v2.4.5, MyNextAlarm v2.4.5
Corrected inversion of Inactive/Active motion status
MyNextManager v2.6.6, MyNextTstat v2.4.2, MyNextAlarm v2.4.4
Corrected away & present methods in DTHs
MyNextManager v2.6.5, MyNextTstat v2.4.1, MyNextAlarm v2.4.3, MyNextSensorV2.1.6
Corrected fanActive() method, corrected is_online attribute in Protects, changed cache parameter
MyNextManager v2.6.3, MyNextTstat v2.4, MyNextAlarm v2.4.2, MyNextSensorV2.1.6
Added setThermostatFanSchedule command for scheduling fan based on fan_duty_start_time & fan_duty_end_time attributes
MyNextManager v2.6.2, MyNextTstat v2.3.8, MyNextAlarm v2.4.2, MyNextSensorV2.1.6
Service manager optimization to avoid state variable’s size limitation, new ocfDeviceType for better display in new Samsung connect app
MyNextManager v2.5.7, MyNextTstat v2.3.7, MyNextAlarm v2.4.2, MyNextSensorV2.1.6
Service manager optimization to avoid too many devices in memory for large Nest installations
MyNextManager v2.5.3, MyNextTstat v2.3.6, MyNextAlarm v2.4.1 Added motion capability to Nest Tstats, corrected last_connection and is_online attribute for Nest Protects
MyNextManagerv2.5.2, MyNextTstatV2.3.5,MyNextAlarmV2.4 with Motion Capability
MyNextManager (v2.5.2), MyNextTstat (v2.3.4), MyNextAlarm (v2.3.2) Optimization for faster queries to the Nest Web APIs
MyNextManagerV2.5, MyNextTstatV2.3,MyNextAlarmV2.2 : added presence capability, structure data & methods, rcs (sensors) & may other tstat attributes
MyNextTstatV2.1.9 - Corrected the home() method to revert back from eco mode.
MyNextManager (v2.3) and MyNextTstat (v2.1.7) - reduced caching to avoid stale data as much as possible, minor optimization, added some aux & emergency heating attributes
New versions of MyNextManager (v2.2), MyNextTstat (v2.1.5), MyNextAlarm (V2.1.4), MyNextSensor (v2.1.4)
MyNextManager (v2) & MyNextDevices: major versions based on the Nest Web APIs as the WWN (official APIs) program has ended since August 31,2019
My Next Manager (v1.4.3): minor correction for avoiding timeouts when creating many Nest devices
New version of My Next Tstat (v1.1.9) to fix the getWeatherAtribute() call
New version of MyNextManager (v1.4) to correct blank Nest Login Page issue
New Next device versions for automatic removal of forcefully removed Nest devices from ST
MyNextManager app (v1.3) with easier installation steps- no developer account required
New MyNextTstat and MyNextAlarm device versions
New version of MyNext devices (v1.1) with improved “replay” logic for greater resilience in case of outages
MyNextTstat (v1.0g) with setETA & cancelETA commands for Geofencing logic
My Next Devices (v1.0e) with new security attribute - NEST API changes
The code has been optimized to allow you to poll your Nest devices with high refresh rates (every minute if needed) for your HA scenarios in order to avoid missing any important event!
List of events (with a refresh rate of 1 minute):
My Next devices (MyNextTstat, MyNextAlarm) allow you to expose your Nest Learning Thermostat™ , Nest Protect™, and Nest Sensor™ to ST with the following features:
  • High performance throughput which enables the Next devices to be polled with different intervals down to the minute (also depending on your use cases and the number of devices).
I’ve tested the code at several user locations with up to 7 devices in order to achieve the best performances using advanced caching mechanism and distributed computing techniques.
  • Their unique design is based on a minimum number of state & atomicState variables for more resilience. See the effect of state variables here:
  • Just like for MyEcobee device, the code can “replay” failed commands up to 10 times over a period of an hour in case of SmartThings/Nest (temporary) outages.
I’ve developed more than 10k lines of code for integrating the Nest devices into ST.
  • The code exposes all the relevant Nest API capabilities (including your home structure in order to set your devices to home or away ):
    • MyNextTstat: based on the work I’ve done with MyEcobee device, I’ve created this new device for the Nest thermostat. You’ll find the same level of resilience with some comfort & energy saving tips for the Nest…
    • MyNextAlarm: exposes your Nest Protect’s attributes for Home Automation and integration with SHM
    • MyNextSensor: exposes the temperatureMeasurement capability.
All screenshots here:
_Service Manager (with Ask Alexa Integration for verbal notifications of Daily/Weekly Summary Reports)
http://thingsthataresmart.wiki/index.php?title=My_NextServiceMgr#UI_and_integration_setup_workflow
_Next Devices
http://thingsthataresmart.wiki/index.php?title=My_Next_Tstat#Look_.26_Feel
http://thingsthataresmart.wiki/index.php?title=My_Next_Alarm#Look_.26_Feel
  • All My Next Devices’ capabilities & attributes are exposed for easier integration with Rule Engines (SmartRules, Core or others)
Refer to:
http://thingsthataresmart.wiki/index.php?title=My_Next_Tstat#Information
http://thingsthataresmart.wiki/index.php?title=My_Next_Alarm#Information
- The code unlocks all Nest’s APIs features.
- The code has been designed to work with my ecosystem of Zoned Heating/Cooling smartapps.
- My NextTstat is also able to give you “energy savings and comfort tips” based on actual indoor/outdoor conditions at your home.
Refer to
http://thingsthataresmart.wiki/index.php?title=NestGetTips
You can also use the AskAlexa Integration as indicated here for verbal “play/repeat tips” commands:
http://thingsthataresmart.wiki/index.php?title=Ask_Alexa#MyEcobee_.26_MyNext_Devices.27_comfort_.26_energy_saving_tips
The following indoor/outdoor metrics will be processed by My NextTstat’s heuristic rule engine to provide “comfort and energy saving tips”:
  • current Indoor Humidity
  • current Indoor Temperature
  • current OutdoorTemperature
  • Ideal target Indoor Humidity calculated based on outdoor temp
  • average of Indoor Temperature over a given period of time (ex.weekly)
  • average outdoor temperature in the period
  • standard deviation of Indoor Temperature in the period
  • standard deviation of Outdoor Temperature in the period
  • count of Hold commands sent to thermostat
- If you have the Ask Alexa smartapp (developed by MichaelS), installed under SmartThings, I’ve also integrated some voice reports in the Service Manager (last page) that give you a summary of all events related to MyNext devices for the past day/week (optional)
For example, for MyNextTstat device, you’ll get the following summary voice report:
At your home, your Nest thermostat is in cool mode.In the past day,in the room Hallway where the thermostat MyTstat Hallway (My Nest) is located, there were 2 hold(s) observed, and 1 schedule change(s),your Nest thermostat’s setpoint was 22.0 degrees in average.The Nest’s minimum setpoint was 18.3 degrees on 2018-01-11 07:40,and the Nest’s maximum setpoint was 24.5 degrees on 2018-01-11 07:42
For MyNextAlarm, here is another summary voice report:
At your home,in the past 7 days,in the room Downstairs where the Nest Protect MyAlarm Downstairs (6EC0) is located,there were 1 event(s) triggered by the Nest Protect, which include the following,1 battery event(s).The current battery state is ok
- As a reminder, I have also built many smartapps to control any room thermostats (ex. eTRVs, minisplits, window units) and ST connected smart vents (Flair, Keen Home, EcoNet, etc.) with many smart features such as:
_ creation of virtual zone devices with delta temp (+/-) adjustment per zoned rooms activated by schedule
_ avg/median/min/max temp calculations for your thermostat's setpoints adjustment based on all your ST connected sensors (similar to the ecobee's follow me feature)
_ alternative cooling also activated by schedule
_ control of your vents based on any ST temp/motion/contact/presence sensors
_ built-in safeguards amongst others, the HVAC static pressure check based on some pressure differential
_ ability to set your thermostat to Away or Present based on all your ST motion sensors (similar to ecobee's smart away feature)
Here are the names of the relevant zoned heating/cooling smartapps: (smart vents are optional)
For the Nest thermostat and slave z-wave or zigbee thermostats,
http://thingsthataresmart.wiki/index.php?title=ScheduleTstatZones
_This last smartapp has less features but can control the vents based on rooms’ temp thresholds.
http://thingsthataresmart.wiki/index.php?title=ScheduleRoomTempControl
Note:
For more details, refer to
** Special thanks to William R. and Rich C. for their support during the beta testing.
Adding Nest to SmartThings
Nest is finally getting remote sensors! (And their doorbell is finally shipping)
List of official representatives from Third Party Companies?
[RELEASE] Introducing ScheduleTstatZones: multi zoned heating/cooling solution for your home
New to automation and ST: controlling Ecobee?
Nest manager help
Nest Integration Breaks Google Nest App and Google said “Will not help!”
Smart Thermostatic Radiator Valves (eTRV's by MiHome) following Nest Thermostat
Nest manager issues
Nest Unreliable API
Nest devices stopped updating at midnight last night (Sept 30 2018)
Smart things Nest intergration?
Turning off a Nest controlled heat/air conditioning system after a open door/window sensor
Latest Tom's guide review: Ecobee4 vs. Nest Gen 3: which smart thermostat wins?
Demo of EcobeeSwitch+, Ask Alexa, My ecobee, My Flair, My Automatic integrations
Nest In Heat Mode
Nest Developer account not working with NST
Nest Thermostat OAuth
[RELEASE] Best zoned Heating/Cooling Solutions for SmartThings
Would you like to do targeted heating/cooling in your home using your own Virtual Zone devices?
[DEPRECATED] Ask Alexa 2.3.7
[BROKEN] NST Manager v5.0 (Does Not Work Anymore)
Keen Smart Home Vents
NST manager not displaying properly
Nest Protect Device Type
How do I add Nest Thermostat into ST?
Nest Cam: Formerly Dropcam
Thermostats with good SmartThings integration
Integration of z-Wave /danfoss thermostatw
Open door shuts off tstat
Any news on Nest integration?
Need Help With Nest Hello Triggering Front Porch Light
Free Nest Thermostat E (if they control it) for Consumers Energy Michigan
Possible to link nest status to a smart outlet
Cant login to Nest Manager when account was migrated to google
New user looking for help connecting Nest & Chamberlain Products
FAQ: How to find out what "shard" (cloud slice IDE URL) your Account / Location is on?
Nest Protect and Nest Thermostat
Adding Nest Thermostat
Ecobee wakeup screen w/ motion sensors
Wired Fire Detector
Nest Manager Help My Home
New to ST, and need Nest help
Nest Secure (Alarm System) and Nest Cam IQ outdoor and Nest Hello (Doorbell Camera) and Nest Temperature Sensor and Nest x Yale Lock
Zigbee gas detector for kitchen
[RELEASE]My Ecobee Devices and ecosystem V5
Nest Integration not working
Smartthings to Nest Without Nst Manager?
No Longer Able To Create Nest Developer Profile?
Latest on thermostatic radiator valves
Best Smoke Detector to use with SmartThings - Nest or other?
Use Nest thermostat as a presence sensor
It has Ask Alexa integration? Be sure to update the wiki or I can. Great work!
I will also list this in my next Friday update!
Yes, it does with new weekly and daily voice reports for all NEST products. I’m leveraging your Ask Alexa smartapp to the max!!
I will also send you some updates for the Get Tips, Play/Repeat Tip commands soon as My NextTstat supports those verbal commands as well.
Regards.
Congrats @yvesracine on your release it’s nice to finally have someone else’s help in filling in the Nest space.
So are you certified with Works With Nest now?
I thought the nest was inferior to the Ecobee?
That’s great news.
I spent months trying to jump through there hoop and they wouldn’t certify me because I was using tricks to get the camera stream translated from the streaming URL and had graphing history and had functions that would override the nests Home/Away. The final nail was i had no way to secure the client id and secret.
Will this allow me to integrate my Nest Cam in to ST without making it public?
Sorry, sadly, it’s not possible as with the other Nest Integration,
http://thingsthataresmart.wiki/index.php?title=MyNextCam#Issue_.2311:_I_cannot_get_live_stream_from_My_Nest_Cam
That’s what I thought but was hoping. I guess it’s probably never going to happen at this point.
Nest did a pretty good job encrypting the Secure stream :expressionless:
Thank you for this. I have been wanting to put my Nest on my ST but the whole Nest Developers account issue was a challenge for me. But now I have a new snag. I created the Nest Developers account as directed, I have a Product ID and a Product Secret key. But when I go to put them into the OAuth, it asks me to Enable OA in SmartApp ( a button to click ). When I click that button, the Client ID and Client Secret fields are listed as Auto-Generated and it won’t let me paste anything in. What now?
Hi,
You need to copy and paste the product Id and product private key under Settings/AppSettings (not under oAuth)… Sorry, I will update the wiki to be clearer.
So you are a certified Works with Nest product and the end user still needs to create a developer account?
That’s different doesn’t sound any more certified than NST Manager
Thank you! I knew it was something silly I was doing and I was terrified I was going to screw it up :slight_smile:
And kudos for the super fast reply!! Can’t wait to start playing with this.
If I can make a suggestion…add a screenshot of what the IDE in that area.
Michael
Will do later…
I went to your site and then to the GitHub link but I can’t find anything about the new nest software.
I usually stay out of the weeds on stuff like this, but I feel the need to clarify a few things since I am being named on this thread.
  1. Any developer that signs up for an account with Nest is allowed to use the logos and other branding on their own website and Yves does have permission from the Nest team to use the WWN logo and other branding materials on his own website.
  2. As far as I can tell, this device type handler has not been certified by Nest in any way.
  3. These discussions about paid products, their support, and how to install should be moved to the vendors website.
Please keep these discussions civil and keep the topics directed towards the benefit of the community. I would suggest that if the community feels that a particular topic is spammy or more marketing than an actual community discourse that they flag it as such and leave it at that. It does no one any good to back and forth in an argument that never concludes.
