Hi,
For all Nest users regardless if you have a Nest or Google account, my code can expose all your Nest Tstats, Protects, and Sensors under your Nest primary account (except the ones from a partner program such as with an utility).
And, if you have lost your auth tokens from Nest and/or migrated to a Google Account, and your ST-Nest integration is not working anymore, then the new versions of MyNextManager(V2.6.6), MyNextTstatV2 (v2.4.6), MyNextAlarmV2 (v2.4.5) and MyNextSensorV2 (v2.1.7) may be for you.
The Nest protects and Nest Tstats can now detect motion. If you want to use that feature, I’d recommend changing the polling interval to 1 minute in MyNextManagerV2 for faster updates.
For the Nest Tstat, you’d need to activate motion detection. Make sure you have the latest firmware version for all your devices.
You can also use the motion capability in your WebCore scenarios.
You can now download the new major version at my store:
www.ecomatiqhomes.com/store
If you are already a contributor, you just need to use the original sellfy download link to get the new minor versions. The zip file contains all the required files for update and some release notes.
MyNextManagerV2.6.6: minor change to avoid null values in cookie
MyNextTstatV2.4.6: Corrected fanActive() method to avoid cast exception
_MyNextManagerV2 (service manager for My Next devices) now uses the Nest Web APis (not the “official” APIs as they have ended since August 31, 2019). The Web APIs don’t have the strict rate limiting as the old APIs and they are as responsive as the native Nest application.
_ MyNextTstatV2 now natively supports the following commands:
setHotWaterBoost: in the device UI and as a command for WebCore users. This is useful for Nest users in Europe.
setTargetHumidity: to set a target humidity level (for the control of your humidifier/dehumidifier connected to Nest)
For the full list of attributes, capabilities & commands supported,refer to the ST community wiki:
https://thingsthataresmart.wiki/index.php?title=My_Next_Tstat
https://thingsthataresmart.wiki/index.php?title=My_Next_Alarm
FYI, with your contribution, there are also some complimentary smartapps at my github:
https://github.com/yracine/device-type-myNext/tree/master/smartapps
Regards.
