RBoy
41
Thanks for that, okay I see what’s happening. This was a safety protocol built into the app to prevent a run away HVAC system setting (especially when using remote sensors). When an idle situation is detected the app ALWAYS sends the idle temperatures back to the thermostat and it does it irrespective of the configured weekday/time as a safety measure. So in your case because you have concurrently running smartapps you’re seeing two commands being sent for IDLE mode (this does not impact operating/motion detected temperatures as they will adhere to configured days/times).
If you have the same temperatures defined for IDLE mode in both SmartApps it will not impact the operation is any way. However we will look it and address this in the next release.
Thanks for bring this to our notice.
RBoy
42
Motion Sensor Based Thermostat - Version 02.02.00
Support for multiple concurrent instances of the SmartApp
Thanks for the quick update. The way I am planning on using this is for my bedroom. During the day, I use your 5-2 day scheduler to set the temp high or low so that my unit doesn’t turn on since no one is home. My partner has odd hours though and that sometimes does not fit into the set schedule. So I liked this because now once motion was detected, we could automatically adjust the temperature. But since the thermostat is in the bedroom, I realized that due to the safety built in, it would send the idle temperature overnight while we are sleeping if the motion sensor doesn’t detect our movements while we sleep.
Would the last update help address that?
RBoy
44
Yes that was one of the primary use cases for this SmartApp, infrequent/unknown hours of access during specific times.
EDIT: If you want to be energy efficient, you can also use this SmartApp in your bedroom at night. For the night schedule set the SmartApp inactivity timeout to 2 hours. So everytime you move it has a 2 hour window to maintain the temperature and then it sets it back to Idle if there’s no movement for 2 hours. This way it tends to follow sleep patterns, during deep sleep when there’s no movement it keeps the AC on IDLE and when you start coming out of deep sleep it switches it back on.
This has now been patched up and should work fine now. Safety has not been compromised but it won’t interfere with other SmartApps outside operating hours now and supports multiple concurrently installed instances.
You can use the 5-2 days and this SmartApp together, just make sure that they don’t have overlapping schedules. E.g. if the Motion Detection SmartApp stops at 5pm then the 5-2 Day thermostat should kick in after 5:10pm and you’re good. I would leave a 5-10 minute gap between the two SmartApp schedules to avoid overlaps due to ST timers accuracy and motion sensors quirks.
RBoy
46
Better yet, just released an update to improve the accuracy of the safety Idle to avoid the scheduled gap I spoke of earlier. With this patch, the SmartApp will check if an Idle is required at the end of the schedule and set it and if not it will skip it so you can avoid the “gap” between schedule. Do note that after updating to this patch you will need to open and click Done to reinitialize the SmartApp.
RBoy
47
Motion Sensor Based Thermostat - Version 02.02.01
Improved support for multiple concurrent instances of the SmartApp
As soon as the operating schedule ends of one SmartApp ends you schedule another instance of the SmartApp to start the next operating schedule. You can add as many SmartApps instance as you like now without any operating schedule gaps.
NOTE: After updating to this version of the code you will need to Open the SmartApp and click Done
RBoy
48
Motion Sensor Based Thermostat - Version 02.03.00
Updated app to support ST’s new Thermostat device handler with ‘Deadzones’
Improves support for end time going past midnight into next day
SmartThings new thermostat defines deadzones which would interfere with the operation of this SmartApp when using remote sensors. Update to this version if you’re using Remote Sensors.
@RBoy
Does the app include possibility to add presence sensor (phone) as well or only motion sensors? Don’t see it in the code from the original old version.
RBoy
50
The premium app has mode based conditions (i.e. run only in certain modes) with a remote sensor option.
Not quite sure what you mean by presence based. i.e. you want the thermostat to work only when certain people are present? If so have you considered linking the modes to presence through a routine. E.g. when X arrives, change mode to “Home”.
Yes, that’s what I mean, I thought adding presence sensor same way like you select the motion sensors, but you’re right with your suggestion how to solve that.
@RBoy
I have one more question RBoy, what happens if someone overrides the temperature on the thermostat or change the mode manually?
RBoy
53
It’ll stay that way until the next motion sensor activity is reported and then the SmartApp will kick in and do it’s thing.
The app will only run in the mode you’ve configured it to run, so if you change it to a mode that isn’t in the configured list it’ll ignore the motion detection events (the app doesn’t modify the modes).
Added advanced settings option to enable battery saver mode (reduces verification communications, only enable if you have a strong mesh with repeaters especially while using remote temperature sensors)
RBoy
57
Yes, all of our apps work with the new app. You just need the Classic app to install them (until the new app provides a way to install custom apps).
Once installed they will show up in the new app under Automations
I would love to see and option to control change from idle to operation based on X minutes of activity. I see we have it the other way around to not have it turn off. But I dont necessarily need it to turn on upstairs if someone is just passing the motion sensor to go to a room to get something and then back downstairs. So say motion needs to be 5 minutes to activate from idle to operational and 15 minutes of inactivity to change from operational to idle.
