RBoy
243
The device will report the battery status between 24 and 72 hours. So just wait for it to happen. Alternatively you can hit the request update button and the next time it wakes up (typically 6 hours) it will request an update on all key parameters.
You’ve figured out the tamper notification. Opening and closing the device resets it.
Battery level is still showing 1%. Tapping the ‘Request update’ button on the bottom of the screen doesn’t seem to do anything.
Seems crazy that the battery percentage isn’t updated more frequently.
RBoy
245
As with all Z-Wave devices the battery notifications are pushed by the
device to the hub or polled when requested. In this case the device seems
to be reporting 1% even when polled.
Try to remove the battery and reinsert it into the device. Are you using a
standard LiIon battery? Sometimes it can take a day or so to update, seen
it happen with locks also - probably a firmware quirk.
I’ve removed the two alkaline AAA batteries from the both of my motion detectors (and reinserted them) and it doesn’t seem to help.
On a third unit I did ‘Remove’ and reinstall the 15902 motion detector from my setup and that move the battery level on that one from 1% to 100%, but that is kind of a pain.
Kind of makes me wonder where the 1% battery level is stored. Must be in the HUB? Maybe I’ll go pull power (and the batteries) on my HUB and see if that works.
So I edited the MAIN line to show motion instead of temperature and it works nicely when I select the device. However, in my list of THINGS I get a big blue MOTION text and it doesnt change whether there is or isnt motion reported.
Can you help setup the code to make the motion primary for both when the device is selected and when the seen from the list of things?
Here is a snapshot of what I mean and keep in mind the device shows a grey No Motion status when I select it:
The app isn’t updating the value from the platform, try this scroll to the top and pull it down to refresh the page and it should force it to get the latest value from the platform.
I got a few zwave plus devices from monoprice recently. I was looking for a solution to use them with ST but so far I haven’t been so lucky. Would your app/device handler enable mono price sensors (15902, 15270, 15271) to work with ST’s first gen hub? Also, would your annual license expire after a year or is it about app updates/new release?
RBoy
251
You timing couldn’t have been better. We will be making an announcement in the coming weeks about a partnership with Monoprice. We are in the final stages of releasing custom device handlers for many of their products including the ones you mentioned above. Keep your eyes peeled
Hopefully they will work better than the 3 units I just returned. @RBoy was using your device drivers and the battery level would never go back above 1% after changing batteries and the motion detection was marginal at best. Units I had were the 15902.
I just used your handler thinking itll solve my problem of pairing this motion sensor to the hub. But im still unable to pair it.
I accidentally removed this device without excluding it and now i am unable to pair it back.
I have tried everything ive read including a 1 sec. Tamper switch pres which you and the manual suggests; i have also tried 3 pinhole presses with the same outcome. I have attempted these after excluding, rebooting the hub.
Hi there. If you’ve accidentally removed the device without excluding it first you won’t be able to pair it again without first excluding and resetting it.
See this article on how to put the hub into exclusion mode using the Classic app and then follow the instructions in the first post to exclude the device (keep it close to the hub).
After excluding it reset the device as described in the manual and then proceed to pair it. After pairing use the pin to push the button to force an update it should start working fine.
Not pairing typically means that the exclusion wasn’t successful and you may need to try more than once to exclude it until SmartThings confirms that the device was excluded.
hi there,
i just migrated from wink to samsung smartthing v3 hub.
I have 4 of gocontrol wapirz 1 motion sensors but I cannot find in the ST app anything that matches these devices when i go and add a device, the brand is not there. In fact none of Linear, monoprice or gocontrol, nordic are there. Plz help
RBoy
261
If you’ve already installed the device handler, you just need to pair the device with the hub.
For Z-Wave and ZigBee device you don’t need to select any brand. Open the new ST app, click on +, Click on Devices and at the bottom click on Scan nearby. Now put the device into pairing mode as explained in the first post and it should find and setup the device for you.
Hi, so I have been using your custom DH for several years now. Works beautifully. But after migrating I’m having a few issues. After 10pm, I have an automation that if no motion is detected for 30 minutes, it will perform “Goodnight”. With the new app, the motion is working just fine. But the automation is not sensing the motionless duration of 30 minutes. So at 10PM it performs “good night” every day. Even if there was motion at 9:58. In that scenario it shouldn’t run good night until 10:28. Any ideas? SmartThings Support won’t help because it uses a DH to function.
