[RELEASE] Mode Based Thermostat - Control Multiple Thermostats Temperature / Remote Temperature Sensors when Changing Modes
Hi there. That means either the smartapp and the devices aren’t installed in the same SmartThings location (check the IDE or mobile app) or the device is not using a compatible device handler that conforms to the SmartThings specifications.
If it’s the latter, you can change the device handler from the IDE to use the stock zwave device handler or use our Enhanced zwave thermostat device handler and SmartThings will automatically allow you to select it.
Also not seeing my thermostats coming up (in this app or other thermostat apps). Have a number of Sinope zigbee thermostats installed.
Using the Sinope supplied DTH found at https://www.sinopetech.com/wp-content/uploads/2019/03/Sinope-Technologies-TH1123ZB_TH1124ZB-V.1.0.5-SVN-503-1.txt
EDIT: Found my issue. ST has built-in Sinope DTH’s, one with the exact name as the custom DTH on the Sinope site. The built-in DTH must be based on an old version. When I was checking my devices, it looked like the DTH was set properly because of the name… but it wasn’t! All good now.
Ultimate Mode Change Thermostat Temperature - Version 02.11.00
  • Now you can set a timeout for open door/window sensors before it shuts down the system (default 1 minute)
  • Added swing temperature range limits
  • Added support for new Sonos for notifications
Ultimate Mode Change Thermostat Temperature - Version 03.00.00
  • (New) Support for new platform capabilities, now use with a wider range of thermostats, heating and cooling devices, including WiFi thermostats, battery thermostats, heat only thermostats, cool only thermostats, radiator thermostats and more
Hello
I am trying to setup my house heating automation with Heatit Z-water , TEMP2 and a couple of Zigbee temperature sensors. (I am using premium SmartApp)
My plan is to control main rooms with Heatit TEMP2 thermostats+thermal gears and other rooms (like laundry, entry rooms) with temperature sensors (using termostat handlers) and thermal gears all connecting to Z-water.
@RBoy
  1. can this smartapp start/stop mode heating for rooms with thermostat sensor only?
  2. Is it possible to use separate door/windows sensor for separate thermostat? How to do it?
    Maybe you have some comprehensive manual?
    Thanks.
This app is designed to work with Thermostat(s) at this time, we will be adding support for more devices/features in future.
In the meanwhile check out these two apps which support working with relays and temperature sensors that can work with the Heatit devices you’re using:
