RBoy
82
@chippie the via RFID text has been corrected and capitalized, thanks for reporting it. You can find the changes in version 04.02.04
The name of the user will only get printed in the notification tab by the SmartApp.
The recently tab is only accessible by the DTH and since this app doesnât use the DTH to program the codes the DTH is unaware of the code names.
Now all features are compatible with the stock SmartThing Z-Wave and ZigBee device handlers
After updating the code please open the SmartApp and click on Save for the new features to take effect
User Unlock/Lock Door Notifications and Actions - Version 04.03.00
Added support for custom user notification settings
Added support for keypads
Added support for limiting number of notifications per user
Key features of the SmartApp:
Monitor unlimited users and locks
Works with the built in SmartThings device handler
Easy and intuitive setup
Support for different types of locks (keypad, bluetooth, RFID, etc)
Define custom individual Unlock AND Lock actions for users such as:
Exit delay actions (wait for X minutes before running actions)
Separate actions for Keypad and Manual locking/unlocking and per door actions
Turning on lights if itâs dark outside
Unlocking/locking secondary locks
Opening/closing garage doors
Notifications on type of lock/unlock (manual, code, keypad, bluetooth, rfid etc)
Running routines
Changing modes
Arming/Disarming SHM
Turning on/off switches
Custom notifications settings (who and how many)
Define rules when to run and not run actions
Define Door Open/Close actions such as
Automatically relocking the door when itâs closed
Automatically unlocking the deadbolt if itâs extended, while door is open
Hi not sure if this was already mentioned or asked but I donât seem to be able to find if there is a way to notify me who the user was or code used to unlock the door is this possible? if so where do i find this in the set up. Iâm using a schage lock with and lock management code.
Hi there. If youâre programming your code through Lock User Management (LUM) or setting your user names through this app (this app doesnât program codes), then it it will notify you with the name of the user configured for a slot that was used to unlock the door. You can check the following if you arenât seeing the notifications:
The Notify option for the user is enabled in their user page and that the number of limitations is set blank or the appropriate number
The Disable all notifications option is not enabled in the Notifications page
OK so tried all suggestions no luck everything seems to work fine except push notice as to who unlocked the door under recent i get Lock User Management sent nameSlot command to front door lock.
Louy
Iâve responded to your email as well. If the notifications donât show up in the Recently tab then the lock events are reaching the hub.
Also check if youâre using an old custom device handler for your lock, there was a change to the ST hub firmware a few months ago which broke user notification and we had published an updated device handler to address it. If youâre using the stock device handler youâre good. Just check the Recently tab.
Thanks sorry about the doubling up on post and email questions Iâll stick here if that ok. So I did update the device handler to 4.4.2 yesterday. I do get notified in Recently when the lock is unlock and when it gets locked but does not indicate who unlocked the door. The lock will also disarm the house and notify me when it does when unlocked. So you think I should start from scratch?
From what youâre explaining youâre seeing the notification in the Recently tab but it doesnât give the name or the slot number? If so then youâre running into the hub firmware update issue I spoke of earlier. I think the new DTH wasnât published properly and hence may have taken effect. Try to republish it again or switch it to the default ST handler. Once the name or slot number starts showing in the Recently tab the app will also start pushing that information to you.
thanks no go, I will delete and re install the software tomorrow from scratch and try again the only thing iâm getting in the Recently is a continuous Lock User Management sent nameSlot command to front door lock every couple of minutes.
thanks
louy
That means the lock isnât responding properly to the programming requests. Before installing the app make sure that all codes are cleared from the lock and also that the lock is within 20ft if a buffering device. The key is to see those user slot number or names in the Recently tab, if thatâs not there then the messages from the lock arenât reaching the hub.
So just want to thank you for the support and let you know all is working as should be. I think it was all due to conflicts with software did a fresh install of everything and all is working great.
Thanks again for the great code and support
Louy
User Unlock/Lock Door Notifications and Actions - Version 04.08.00
Now you can create an action to toggle a switch when locking or unlocking via a keypad
This is helpful if youâre using LUM with a Keypad and a switch like a garage door opener or light where you need to have the same user code (unlock or lock) toggle itâs state.
Please ensure that your lock is within 20ft of a buffering device for the best experience (the buffering device should be between the hub and the lock for maximum effectiveness).
I think I am missing something, how do I manage user profiles? I need to add users under âmanage usersâ, but what should I call users? I have 3 users right now, me, my wife and kid. How do I connect these users to the smart app so the app knows when each of us are opening the app.
I have a danalock v3
