RBoy
#1574
With the latest version of the SmartApp, it just means that your device handler user name is not matching what the app is telling it. It updates the names so that SmartLocks will show the same name as the SmartApp. It’s just a cosmetic thing and has nothing to do with your lock codes if they are working fine.
One quick way to fix this would be to run the Clear Codes procedure on our website which gives your device handler a clean slate and fixes and any data corruptions. It’s always recommended to run the Clear
Code procedure after you install a new lock or you change the device handler.
EDIT: This may be caused if the slot name has any spaces in it. We’ve patched it up and you can download the update
Hey sir. I think I ran into a bug. I think I was successfully able to add a user with expiration settings. i set a date in the future (2018-03-02) where it activates and an expiration date of the next day (2018-03-03) at 8pm. Now when I try to go back to the User Configs I get a “Something’s Wrong. We can’t load your screen right now” error
RBoy
#1576
That’s a platform rendering error, the server might be overloaded. Just try after a while, we’ve noticed typically in the evenings folks start seeing these server UI issues.
Is there a new procedure for clearing codes? I upgraded the DTH to 04.00.03 and the SmartApp to 07.02.00. However, after updating, my hub is stuck in an endless loop with the messages:
[lock name] reported user n is a duplicate code! Code programming failed
for all eight of my users. So I’m trying to run the Clear Codes procedure but I’m getting tripped up by this part:
All the users should be < blank >, if not, tap on the user, clear the name and code and click on Done
Click on Done to return to the main page
When I clear the user name and code, there is no Done option, just Save at the top right. Clicking on Save, I get:
Backing out to the previous menu, it warns me that any unsaved changes will be lost.
It seems like the looping stopped. I guess it reached the maximum number of programming retries. I hope this means that the codes are still programmed into the locks, though. Otherwise, I’m going to have a bunch of unhappy tenants tomorrow.
I’m running Universal Z-Wave Lock With Alarms version 04.00.02. I notice u now have it at version 04.00.03. I will update the code and will let you know if the superficial error subsides. Keep in mind I have 2 locks the error is only referencing 1 of them and the same codes are used for both. No changes were made to the names or codes since the first lock has been in place. The only thing I can think of is the 2nd lock while it was reset with no codes I did set a master code. Could that have caused this superficial issue?
so I updated the device handler code to 04.00.03 code and that did not help so I started looking at the codes that were set for the 2nd lock. In smartthings under devices I compared my 1st lock to the 2nd and I can see for my 2nd lock it only shows 3 codes listed. though all 4 codes are programmed on the lock and are working. odd not sure why it states only 3 codes out of the 4. should I reset the lock and have it resync to get the full list updated to it or is there another way?
UPDATE: I changed the 4th code and it pushed the update to both locks. I can now see that a 4th code is set under the device for the 2nd lock. And all codes work. Though the superficial error is still occurring.
RBoy
#1581
Update to 07.02.00 and give it a few minutes to sync up the user names across your locks.
RBoy
#1582
If the “code” field if not empty the app will show you a message that name field if required. It’s better to clear the code first and then the name so that the app registers that the code is empty and it doesn’t need the name field.
Your lock is reporting a duplicate code which means some where in your lock there already exists that code you’re trying to program. You should reset your lock / clear all codes and program your codes afresh. This happens when someone manually programs the locks or programs more users and then reduces the user count.
If you can’t physically access your lock the simplest way to do this would be to set the number of users to match the maximum users supported by your lock, make sure all the user codes are empty (names don’t matter) and then hit Save. Give it about 5-10 minutes depending upon how many users your lock has and it will clear all the codes. Then go back in and program your codes.
The good thing about duplicate codes is that the code already exists in the lock so it will work, the app is just informing you that you can’t have two slots with the same codes.
In the next update we’ll just mention this in the message and also put in a way to clear duplicate codes.
Yes, all of the codes already existed. I just upgraded from 06.02.00 to 07.02.00 without changing any of the users or codes. After upgrading, the hub started to add codes, but of course they were already programmed into the locks:
Shouldn’t the update process have deleted all of the codes first before trying to add them again?
It’s good to know that the codes are still there. I will try to clear and re-program the codes sometime tonight when my tenants probably won’t be using the locks. You may want to modify the instructions on the web site, since they explicitly say to clear the name and the code.
I am also seeing the following message in the Activity Feed for one the locks. The message looks like it’s occurring every minute:
Lock multi user code man…
Lock multi user code management
with notifications and automatic
relock sent nameSlot command to
68-3 Deadbolt - Front
It’s only occurring for that one lock.
RBoy
#1584
Yes the app takes care of all codes within the specified user limit.
Duplicates are caused by codes that have been programmed outside the scope of the app. It could left over from before or programmed directly into the lock etc but because the user has limited the app to only program the first X codes, it only validates those codes. That’s why we suggest starting with a clean slate by resetting the lock when installing the app.
Till now the app used to ignore duplicate codes, now we’ve decided to notify the user so you’re aware that there are codes outside the scope of the app which may conflict with your programming. Duplicate codes are the reason why some folks reported the setCode being sent multiple times, so we now we’re making the user aware of the reason.
We’ll refine the duplicate code messaging and processing in the next update
As for the nameslot message, just deselect that lock from your user, click save and then come back select it and click save, it’s just cosmetic, we’ll patch it in a future update
Door Lock Code Multi User Management with Notifications and Actions - Version 07.02.01
Improved duplicate code/excess code management
Improved compatibility with SmartLocks
Two way name synchronization
Fix annoying nameSlot notifications
Smoother upgrades with automatic self-validation of settings after code updates
Some examples of how folks are using this app:
I give my landlord an access code for the lock but I want it disabled when I’m at home (presence based users)
When my children are at home and the parents aren’t home, then allow the babysitter’s code to work (presence based users)
When we’re away, allow my neighbor’s code to work (mode based users)
I can schedule a code for my nanny with multiple schedules per day (morning and evening)
I can program ahead for my vacation rental properties with a start and end date/time for my guests
When I lock my door from outside I want my house to lock up behind me (close garage doors, lock all other doors, turn off switches, arm the security system etc)
When I unlocked my outer door I want the inner door to also unlock and the lights to turn on but only at night
I want my employees to have access only during business hours or on specifics days/modes
Lock Code User Management is the most reliable and comprehensive commercial grade User Code Management SmartApp with many (unique) features:
Works with the built in SmartThings device handler (Z-Wave and ZigBee)
Sure-Programming engine: verifies that programming was successful
Unlimited users and locks
Easy and intuitive setup
Different types of users such as:
permanent
one time
expiration (start/end date/time)
scheduled (daily/weekly etc) with multiple schedules per user
presence based
mode based and many more
Support for different types of locks (keypad, bluetooth, RFID, etc)
Define custom individual Unlock and Lock actions for users such as:
Exit delay actions (wait for X minutes before running actions)
Separate actions for Keypad and Manual locking/unlocking and per door actions
Turning on lights if it’s dark outside
Unlocking/locking secondary locks
Opening/closing garage doors
Notifications on type of lock/unlock (manual, code, keypad, bluetooth, rfid etc)
Running routines
Changing modes
Arming/Disarming SHM
Turning on/off switches
Define rules when to run and not run actions
Define Door Open/Close actions such as
Automatically relocking the door when it’s closed
Automatically unlocking the deadbolt if it’s extended, while door is open
Ringing chimes when door is opened
Notifications if door is left open
Define actions for each door separately
Lots of built in safety mechanisms to ensure users have a reliable experience
Thanks for all the updates RBoy… they may be on your radar, but I wanted to suggest a few additional features:
VRBO (mentioned earlier, but would add a lot of value if we could integrate lock codes with the VRBO vacation rental API)
Per User Notifications (based on a label in the app, it appears that this may be in the works)
Door Position update to the Lock Device based on the Contact Device so that we can reference the Lock Device and get complete door status:
right now, we have a separate contact sensor and lock; some locks have the DPS built in, but many do not…
for those that do not, it would be great if this Lock Code app would set the DPS attribute on the associated lock device (since its already associated and subscribed to the separate contact sensors)…
basically, this would allow us to name the door lock something like ‘Front Door’ and we can associate all of our apps & rules with only that 1 device and when notifications (TXT, App or voice) reference the device, it will be simply called ‘Front Door’ (vs “Front Door Lock is Open” or “Front Door Contact is Open”)…
hopefully that use case makes sense, but basically, we all struggle with the fact that a door is 2 different devices… would be nice if the Lock could represent both as just a door (and this App could provide the necessary communication between devices.)
If you have a lock with an integrated Door Position Sensor (like Yale or August) then use our Enhanced Z-Wave Lock device handler and it will show up as a Lock and Door Contact Sensor in SmartThings (since device with 2 capabilities which can then be used any SmartApps)
Per user notifications are already there and you can enable/disable them along with restrictions on when to notify based on modes or user presence.
In the next version 07.04.00 we’ve added 2 more custom options for user notifications:
Limit the number of notifications for that user (first X notifications)
Ability to specify custom notifications options for the eac user (who to notify and how to notify)
Hello RBoy. I’ve been using your smartapps and so far they’re working really good until recently, wife always complaining that evertime I come home from work (11pm) I would wake her up because the speaker notification is too loud, which is just fine during daytime.
Can I suggest to include it in your future updates for us to set the volume on a specific time or a way to turn off the tts notification on a specific time. thank you so much.
Door Lock Code Multi User Management with Notifications and Actions - Version 07.04.03
Added support for customized notification settings for user custom actions
Improved support for timezone differences between mobile app and hub
Ability to limit number of notifications received per user
Sure Programming Engine - improved handling of mesh issues
permanent
one time
presence based
Running routines
Changing modes
Custom notifications settings (who and how many)
