[RELEASE] Lock User Management (LUM)
The stock (default) Lock Device Handlers from SmartThings are Z-Wave Lock and ZigBee Lock
Quick question - on the delay action setting in the door lock app. I saw a comment earlier in the thread from a few years back about anything above 20secs would cause issues. Is this still the case or can I set it 10 mins. and this will work?
also is the delay going to wait and to execute and check the do not do list of presence sensors?
It should be okay now. No reports of any issues yet. It will check the sensor state before taking action, we did take into account while designing the delayed actions features.
thanks for quick response. I noticed when the delay action is set in the ST app notifications section the messages thread for the locking of the door itself if delay is configured does not show up, but the activity feed displays the lock command with user x right away. I assume that when the delay time is up the message thread will display the message of the door lock and any routines that are configured?
reason I am asking is if I forgot something and go back in and use the keypad to unlock those messages show up right away and presumably cancels the delay timer on the door lock keypad actions that follow the delay. ---- I can confirm it does not cancel the delay actions they will run 10 minutes after the first keypad lock action. If this is not how it supposed to work where do we report this as a bug and what info do you need from me?
I have tested this Door lock app and the Universal Device Handler with a Schlage lock with good performance.
Took a few tries but eventually paired a brand-new Kwikset 910 Traditional keypad lock, and it is using the same device handler. Then, I logged into the IDE console to check if the hub and Kwikset are talking to eachother. So far so good.
One question I have is, I am noticing fewer features on the ST app controls for the Kwikset 910 lock compared to the Schlage. I see Lock, Unlock, Auto-lock on/off, Battery %, and Audio on/off. Is this all I can expect to use or is there anything missing, e.g. Code Entry on/off, Forced/Tamper modes?
@RBoy or @maddie: Now that all features are compatible with the stock SmartThing Z-Wave Lock, would you recommend I change my Yale Assure locks away from the Universal Enhanced Z-Wave Lock to the stock Z-Wave lock DTH?
You can definitely use the new stock device handler.
Do keep in mind that the enhanced handler has some additional features like alarms, one touch locking, auto lock, tamper etc which doesn’t exist with the stock handler.
Also new locks like August Pro, Danalock v3, RFID locks etc aren’t completely supported by the stock device handler.
The biggest advantage of the stock handler is local processing.
I started using your door lock code/lock user management app last week after using Eric Thayer’s Lock Manager. Both apps work great, but I just noticed I’m no longer getting text alerts on lock unlocking. Are text alerts a feature of your app, or EThayer’s, or both? I see the Notifications on the SmartThings notification page, but no more texts are coming in.
This morning I replaced the old dollar-store batteries with fresh Duracells on the Kwikset lock.After performing several refreshes, closing and reopening the ST app, something is not syncing with the RBoy app. So both the app and the hub dashboard are showing the battery power stuck at 30% instead of 100%.
Suggestions?
Yes it works fine. This also supports texting multiple recipients (see instructions in app). Depends on how you’ve setup texts in SmartThings, if you’re using the address book feature or just entering the number directly. Either way try to use the E164 standard e.g. +15551235678 while saving your phone numbers otherwise ST tends to ignore them and not deliver it
how does one go about submitting bugs? line 1322, ‘def msg="
’ needs to be moved up ~6 lines, to be outside the if/then scope, otherwise sendNotifications(msg) on line 1371 (which is outside the if/then scope) is a null-text notification. Let me know if there’s a better way to send this info.
Thanks, will check it out. You can always email our support team as well.
Now all features are compatible with the stock SmartThing Z-Wave and ZigBee device handlers
Door Lock Code Multi User Management with Notifications and Actions - Version 06.00.01
  • Fix for notifications when manual unlock actions are executed
Lock User Management is the most reliable and comprehensive commercial grade User Management SmartApp with many (unique) features:
  • Unlimited users and locks
  • Works with the built in SmartThings device handler (Z-Wave and ZigBee)
  • Easy and intuitive setup
  • Sure-Programming engine: verifies that programming was successful
  • Support for different types of locks (keypad, bluetooth, RFID, etc)
  • Define custom individual Unlock AND Lock actions for users such as:
    • Exit delay actions (wait for X minutes before running actions)
    • Separate actions for Keypad and Manual locking/unlocking and per door actions
    • Running routines
    • Changing modes
    • Arming/Disarming SHM
    • Turning on lights if it’s dark outside
    • Turning on/off switches
    • Define rules when to run and not run actions
    • Notifications on type of lock/unlock (manual, code, keypad, bluetooth, rfid etc)
  • Define Door Open/Close actions such as
    • Automatically relocking the door when it’s closed
    • Automatically unlocking the deadbolt if it’s extended, while door is open
    • Ringing chimes when door is opened
    • Notifications if door is left open
    • Define actions for each door separately
  • Multiple types of users such as permanent, one time, expiration (start and end date/time), scheduled (daily/weekly etc) with multiple schedules per user, presence based, mode based and many more
  • Lots of built in safety mechanisms to ensure users have a reliable experience
  • and lots more
Some examples of how folks are using this app:
  1. I give my landlord an access code for the lock but I want it disabled when I’m at home (presence based users)
  2. When my children are at home and the parents aren’t home, then allow the babysitter’s code to work (presence based users)
  3. When we’re away, allow my neighbor’s code to work (mode based users)
  4. I can schedule a code for my nanny with multiple schedules per day (morning and evening)
  5. I can program ahead for my vacation rental properties with a start and end date/time for my guests
Copyright © RBoy Apps
Sometimes it takes awhile to update. I usually give mine a day and then they report battery life correctly. You can also try to refresh the lock by going into the lock on the devices page in the smartthings app and clicking the refresh looking button.
Is there an easy to get updated for when you make changes to the app and devices? I periodically check the forum and do know that the version is published in the top section of your code. Just curious if you have considered adding version info to the device and app handlers titles so we can see which version we have from the ide page or send a email out to current customers on the site.
The SmartApp automatically checks for critical updates about once a week and then notifies the user if any updates are available for the SmartApp and device handlers (if you’re using the enhanced device handler) (unless the user has disabled the check for updates option in the SmartApp).
For minor updates you can subscribe to our Facebook page and get notified of updates. In the next upgrade to our website we will include an option to subscribe to email notifications as well.
How do I update the application. Do I need to copy and paste the complete code?
You can find detailed step by step instructions on our website, scroll to the bottom to the update section.
Hi, I have installed this smartapp yesterday for my “Yale Keyfree Multipoint Lock” and it works very well except few minor issues.
  1. On the lock screen the “Audio” tab message is working wrong way around. when it says “Audio OFF” the audio is on and when it says “Audio ON” infact the audio is not coming.
  2. the “Code Entry On/Off” Button doesn’t do anything.which should block code entry if its OFF but it doesn’t.
Assuming you’re using this device handler.
Please update to the latest version, the audio reversal was fixed a while ago.
