Thanks for responding to this issue so quickly. Updated to 05.07.00 and app working fine again, error free.
So the error is in the device handler? It is working fine for me, just the smart app is giving me an error. Iâm running the universal enhanced z wave lock 03.03.03.
Never mind, I see where you posted new smart app, I installed it with no errors, thanks so much!
The issue was that ST changed some lock capability properties which affects all handlers (stock and custom). So while the device handler itself would continue to function, SmartApps that depended on those specific capabilities will stop working. Hence the fix to work around the âmissingâ capabilities was provided in the SmartApp version 05.07.00
This is our full time job. Our goal is to ensure that the app just works with the standard or custom devices. Just plain n simple, no messing around.
Quick update: ST just confirmed a hotfix patch is going out shortly so it should fix the problems if youâre still using the older versions. If youâre on the latest version youâre all set anyways.
Thanks @Tyler
Hi, I am trying to read all the codes in a schlage connected padlock but without success.
Here is my code for subscribe:
settings["group_locks"].each{
log.debug "subscribing to $it"
subscribe(it, "lock", lockHandler)
Here is my reload all codes call
settings["group_locks"].each {
it.reloadAllCodes()
log.debug "$it reloading all codes"
I tried âlockâ, âlock.codeReportâ and âcodeReportâ in subscribe but no call back is fired.
Any suggestions?
Hi, Iâm using the Schlage BE469. The wife and kids lock the door using the front Schlage button on the front. Everytime they do that, I get a notification that the master code was used. I saw people mention that previously but I donât know if it was resolved.
For me to use notifications, I canât have it notifying me so frequently. I just want notifications under more rare circumstances. Thanks!
Yes it resolved some time ago. Have you updated to the latest version of
the SmartApp and the Enhanced ZWave Device Handler, if not please do that.
Have double checked that the BE469 is working fine here.
Is there any way to react on a specific user and do stuff only when that user unlocks the door? For example the one whoâs gonna water the flowers while we are gone. When he/she uses her tag I want my alarm system to automatically disarm. So I donât have to share alarm codes.
Thatâs the whole premise of the SmartApp, ability to configure individual user level unlock and lock action (need Enhanced Z-Wave DH for individual lock actions) apart from programming them (amongst other features).
Sorry, I canât find it anywhere to use on specific user. ??
I found it, but nothing happens. I added a light to code 2 just to test it. I get the notification in the lock history, but no light turns on. I have idlock. What could be wrong??
Probably a configuration issue. For IDLock confirm that youâre using the Enhanced Z-Wave Lock Device Handler. The Stock Device Handler doesnât support all the features of IDLock. Then if youâre still having an issue open IDE Live Logging. Unlock the door using the code. Copy paste and send us an eMail of what you see on Live Logging and also a screenshot of your SmartApp settings. EMail it to us (see our support page) or PM it to me.
Iâve installed and am very happy with this great addition, however I wanted to know if it were possible to get info from my z-wave lock to report on entry or attempts via the RFID and NFC key cards?
Having looked before without any luck I got the answer myself now! So code 144 is the opening of the lock by NFC tag or RFID card. The user number like the code entry message is the Level. Code is below;
case 144:
map = [ name: "lock", value: "unlocked" ]
if (cmd.alarmLevel) {
map.descriptionText = "$device.displayName was unlocked with card $cmd.alarmLevel"
map.data = [ usedCode: cmd.alarmLevel ]
break
Thanks for the work on this again itâs a great feature.
@RBoy Iâd like to make a feature request⊠I really like the custom actions that happen when a specific code is entered. When my house keeper arrives, I have it turn on a virtual switch which I use to automate a bunch of switches and my thermostats. All good there.
Whatâs missing is the ability to turn off a switch in the door lock section. The only option is run a routine. Could you please add the same options you have for locking to unlock as well? When mode is away and the door is locked, I want to turn off the virtual switch and shut everything down again. Thanks!
Door Lock Code Multi User Management with Notifications and Actions - Version 05.08.00
- Added ability to turn on/off switches when the external keypad is used to lock the door (for individual user code based locking and one touch keypad lock)
- Improved reliability of âExpire Onâ codes when the Z-Wave mesh is weak
- Improved reliability of the âDisable Verificationâ option
Recommend use the [Universal Enhanced Z-Wave Lock] ([RELEASE] Universal Enhanced Z-Wave Lock, Schlage Lock, Yale Lock, Kwikset Lock, IDLock, DanaLock and August Lock Device Handler with Alarm Control, Notification, RFID, Door Sensor and advanced features) device handler version 03.03.00 or newer for full SmartApp and automatic update notification functionality
I have a use case that I havenât been able to figure out. What would be the best way to receive a text only if the door was unlocked remotely while in Away mode?
From what Iâve figure out so far, I would get texts no matter how the door is unlocked and I donât want that.
Use CoRE and setup a custom rule to check the data field and type member being reported by the lock event.
