Yes but it all depends upon how your app has been configured.
So, how would someone configure the app to account for this then?
Does anyone know if this smart app works with the Kwikset 916?
Yes it works with any z wave lock. For now z wave since ST zigbee locks donât support remote programming
Since Friday last week, one of my scheduled codes does not set anymore. I tried reentering it in the app but it doesnât work⊠also - in the ârecentlyâ part of the device handler it explicitly says Front Door Lock Manager: Front door lock code 2 is not set. So it knows that it isnât setting it⊠but it does not explain why
This probably explains it. Delete your codes and complete the programming as empty slots and then start over with your codes afresh.
Also makes sure that re verification is enabled
Ok ⊠will do
@RBoy nice app, I really like the fact that itâs using the stock handler. One less code to be maintained, plus enables Smart Lighting instances triggered by locks to run locally. Feature request, can you add motion sensor as an option to the auto-lock feature?
Can you elaborate what you mean by adding the motion sensor to the auto lock feature
I donât have a contact on the door in ST, but I have motion sensors in front of my entries. I could use the relock door when motion stops (after x minutes) and the door is unlocked, instead of when the contact is closed and door is unlocked.
To that pointâŠwhy couldnât the doors internal motion sensors be used?..maybe not sensitive enough?
What internal motion sensors? Are you thinking of acceleration?
My badâŠthatâs it.
Yes but thatâs not a usual cause, the point of the door sensor is also to ensure the door is closed before itâs locked to prevent the deadbolt from damaging the door.
You can always do this using CoRE or RuleMachine.
Or routines or custom app, no biggie, I already have means of doing this, just thought someome else may benefit. I certainly understand this is an edge caseâŠ
Oh that can certainly be done. But if you already have a contact on that door, itâs easier to use the open/close. Youncan use the lock on knock too, if you want to make use of the accelerometer. Just donât set it up as unlock on knock, that may pose a slight problem.
:)))) that would definitely be interesting, knock to open! Magic!
You laugh, but I believe Bruce accidentally did it, when he first installed the door knocker ages agoâŠI remember laughing my @$$ offâŠIt cracks me every time I think about the door knocking idea.
Didnât know that! But seriously if you want to impress your guests itâs a neat trick or for your kids birthday party!
