RBoy
#2092
Thanks for your logs. The lock and the DTH are perfectly fine, I don’t see any issues there, everything looks exactly as it should be. It’s not reporting any usedCodes for manual locking/unlocking.
The bug appears to be in webcore where it’s not processing the information reported by the lock/DTH correctly. There’s a known bug in webcore with usedCodes when the value doesn’t exist or it’s 0 or 1. We’ve reported it to the developer last year.
As for programming codes to specific slots using LUM, you can definitely do that. The users are ordered by slot so you can pick the slot you want to program the user to, also when you open the individual user page it’ll show you what slot number it’s been programmed to.
Thanks for your time in looking into this. It does seem to be an issue with UsedCode assuming “Code 1” when the UsedCode is null based on your explanation and further reading.
To skip using slot 1 for any codes, I would have to re-create all my users and make a “dummy user” for slot one that I would I guess make inactive? I feel this will be the simplest way to work around this issue with Webcore. I can’t just renumber the existing users I have to slots 2-6 right?
RBoy
#2094
Using LUM - you can just remove user 1 or change the type to inactive and use a a different slot for that user and leave the rest as it.
Does this smartapp work in the new app? With the migration im sort of reluctant to spend money to aquire something that might stop working on the 14th of oct?
Hi there. We’re continually working with SmartThings to keep our SmartApps and Device Handlers up to date with the latest changes. A couple of quick notes:
LUM and RLA work with the stock Z-Wave Lock and ZigBee Lock device handlers
The Universal Enhanced Z-Wave lock DTH is optional but recommended since it gives you access to more lock features and also fixes bugs with the stock DTH’s and has workarounds for defects in some lock firmwares as explained here.
quick question. i have two Schlage smart locks and i currently have two separate LUM’ s configured. one for each lock. am i doing this the right way or i should be able to configure LUM to use both locks?
Hey there. LUM is very flexible and can be used any way depending on your preference. If you want to synchronize the same codes across all locks then you can use a single instance and select all the locks on the main page (infact you can even select a subset of those locks on the individual user pages if you want to limit a some users to specific locks), or you can setup difference instances of LUM for different locks. The only point to keep in mind is that one lock should only be controlled by a single app to avoid programming conflicts.
(New) Added support for WiFi/cloud devices (Meross garage door controllers, etc)
Please ensure that your lock is within 20ft of a beaming device for the best experience (the beaming device should be between the hub and the lock for maximum effectiveness).
I just noticed in the app that when I go to manage users, next to each of them it says the lock “IS CONFIGURED TO ACCEPT 0 DIGIT CODES ONLY. PROGRAMMING WILL FAIL.” I haven’t changed any settings, codes, etc. recently so I’m not sure how long that message has been there. What do I need to do?
RBoy
#2104
UPDATE: The 0 digit warning message has been in fixed in 07.14.00
I only had the issue once I added a Kwikset 912 in addition to 910. I had to manually force the 912 to use the RBoy app lock device driver in the Smartthings IDE.
Hey there. The 07.13.10 release added the ability to control WiFi devices via custom user actions. These devices are C2C integration for the new platform/app such as the Meross WiFi Garage door controller.
ST are about to pull the Classic app and as a consequence “SmartLocks”.
As i am in the UK and over 4,000 miles from my property i am wholly dependant on SmartLocks to manage my Schlage Z-Wave lock. Since UK users are not getting the Smart Lock Guest Access app i am going to need to get RBoy LUM.
I have used SmartLocks without issue for 18 months whilst the Z-Wave route is direct HUB<>LOCK, only about 12 feet away.
In the Covid environment i am not going to get to my property any time soon, so, the questions are, -
Can i install LUM without any need to physically ‘touch’ the Lock or ST-Hub?
As the lock has worked fine for 18months without a separate buffering device, can it continue when LUM replaces SmartLocks ?
thanks
RBoy
#2110
Hi there, I’m having exactly the same problem (max codes reported as one on yale zigbee module), I’ve alread tried a few DHTs without any success. Have you find any solution for this bug? Any help will be awesome.
