[OBSOLETE] Lock User Management (LUM)
With the IDLock you would want to start with using the Enhanced Z-Wave Lock device handler. Thanks stock device handler doesn’t always work with IDLock. If it’s showing up as green that means the lock has successfully programmed the code. If it still doesn’t work it’s a local lock issue. I just checked and it’s working here. This lock has a finicky keys and they don’t always register when you press them the first time so wait for the beep to ensure it registers when you press the key. The other thing to look for is to ensure that the privacy/vacation mode is disabled on the lock as those features block the user codes from operating the lock when enabled (even if successfully programmed).
