[OBSOLETE] Lock Manager
Notifications working? I tapped global settings>notifications and also user x>notifications and nothing happens just a refresh icon.
Using custom ethayer schlage DTH
Any ideas @ethayer
I tapped Notifications and switch over to ā€˜Lock Managerā€™ in graph ide but when I checked logs they are empty. All other features work except for notifications component .
Turn on and off debug in app and saw this:
But nothing else in regards to ā€˜notificationsā€™
When I go into Lock User smartapp it has exclamation mark and says ā€œsomethingā€™s wrongā€ everything seems ok though? I dont think I should ever have installed it - is there a way of removing it from the app?
Follow steps here [RELEASE] Universal Enhanced Z-Wave Lock, Schlage Lock, Yale Lock, Kwikset Lock, IDLock, DanaLock, August Pro and Samsung Lock Device Handler with Alarm Control, Notification, RFID, Door Sensor and advanced features no need to remove lock just follow steps to remove app.
Perfect. Thanks!
Those logs look fine. What version of LockManager do you have installed? How did you install it? Github? Copy paste? Could be a platform issue.
I installed v2.0 using github beta-2 branch.
I think i found a way to recreate this issue.
@ethayer try to see if add a contact using smartthings settingsā€™moreā€™>contact book then go back to lock manager app and click notifications then the notifications screen doesnā€™t show anymore. Once all contacts listed in contact book are deleted the notification screen loads correctly.
Separate/maybe related issue see below screen showing null
@ethayer It seems that when i used ā€˜send notifications toā€™ /contacts book icon and proceeded to add a contact then this causes the earlier issue where ā€˜notificationsā€™ screen stops working/rendering. Not sure if itā€™s platform issues but now Iā€™m not adding contacts using this option and only using text and push notifications and the only issue is the ā€˜nullā€™ showing in both text and push notifications.
I still canā€™t re-create your notification page issue. I have seen the ā€˜Null unlocked by Xā€™ message before. This is because your lock doesnā€™t have a name.
Navigate to the ā€˜My Homeā€™ section and scroll to your lock. Probably something like ā€˜Zwave Lockā€™
Click on the name and then click the cog in the upper right of the screen.
Where it reads ā€˜Give your device a nameā€™ Enter in a unique name to identify the lock, such as ā€˜Front Doorā€™
Notifications will no longer read ā€˜Null was unlocked by Joeā€™ will now read ā€˜Front Door was unlocked by Joeā€™
Ok cool the lock did have a default name so i was sure about the null but after renaming it to ā€˜front door lockā€™ the null is gone.
No worries on the other issue, ill stick with push and text notifications, they do job perfectly:).
I wanted to turn on/off door alarm mode using webcore but did not see the commands listed.
@ethayer Is there a plan to expose the commands/alarm mode available at the lock settings/cogwheel screen on Webcore for future releases?
Hey- Iā€™m using the 2.0 beta with 2 Schlage Connect locks and everything seemed to be working perfectly initiallyā€¦ until I locked/unlocked both locks with codes set in the smartapp and I got no notifications and no hello home routines ran. I set them to run on the user, lock, and global levels. Still nothing.
Edit: I switched from the stock device handler to yours and the following happened:
-Code Locking/Unlocking notifications worked
-Running ā€œIā€™m Backā€ routine on code unlock worked
-Running ā€œGoodbyeā€ routine on code lock did not work. Instead, it ran ā€œIā€™m backā€. Happened on global, lock, and user levels.
OK thanks for the heads up! Im not sure why the stock DTH didnā€™t workā€¦ I think itā€™s important that peoples donā€™t use the ā€œ****** - With Codesā€ DTHā€¦ but otherwise
The ā€œIā€™m backā€ routine running on lock with code was a copy paste oversight by me. This should now be fixed.
Noticed you updated the code recently. Do you suggest a complete uninstall/reinstall?
Problem. (Running the beta 2.0 version).
I replaced my lock so deleted it from ST. Now when I try to open Lock Manager, I get a ā€œSomethingā€™s Wrongā€ error. I canā€™t even delete this app from IDE, since it is installed in ST. What do I do?
@ethayer
Some commands are available in webcore :image|281x499
Maybe just expose alarmode command and e.g parameter string type ā€˜Tamperā€™ ??
Goto Locations
Installed SmartApps
Edit (upper right hand corner)
Scroll down to Other
Uninstall every Instance of the Door Lock Userā€¦ SmartApp. Also the ones labeled Lock Multi Userā€¦
Steps that help me force remove, provided in another thread.
Thanks. That was easy, once I knew where to look!
@ethayer I followed your instructions to add the Lock Manager App. It shows in my list of apps
But it does not show up in ā€˜My Appsā€™ on my mobile device (I am using the SmartThings Classic App on my Google Pixel phone)
What did I do wrong?
Never mind. I figured it out
With the Iris Keypadā€¦is it possible to prevent routines from running twice in a row? For instanceā€¦if I arm away - it runs the good bye routine twice (only want it to run once).
