Lock status not shown in app (unknown) and app says it can no update the lock status.
Yet lock status is correctly reported by lock under my home.
I just installed a Kwikset lock. Well I should say it was a warranty replacement lock for one that started melting (there was a short). I currently have 4 more Kwikset locks around the house. Anyways, I have the correct DH and everything and lock manager correctly imported all my users and codes to my lock. About an hour later, out of the blue, it started disabling certain people from the new lock. I went in and reset the user data for the users that got disabled. All worked except for one user. The code was 0827. It wouldnāt for the life of it enable that user. So I played around, removed that user, and re-set up the user with same code. Still wouldnāt set code for that lock (all other locks worked). So again, I deleted user and added user with a code of 1313. That worked great. Went in and changed code to 0827 and the it changed to code on that specific lock to 2423. so I figure maybe something with the code so I changed it to 0828 and it saved the code to 2424. Finally i gave up and changed it to 0829 and that saved correctly.
On kwiksets, the buttons are 2 numbers (1-2) (3-4) (5-6) (7-8) (9-0) so maybe something internal with the lock for that specific set of numbers (7-8). I have other codes that use 7 & 8, just not as the last number. Iām thinking something is messing up when the last number is 7 or 8.
Updates: Just tried changing it from 0829 to 0827 and worked on all locks except for that one. Wont change code. Changed back to 0829 and itās fine.
Tried adding a new user/code of 1317 and that added fine so my above theory on the (7-8) button isnāt right.
Itās like there is something preventing that specific code 0827 and 0828 from being used only on that lock. Unfortunately Iām 5 hours away so I canāt easily re-set the lock.
P.S. the live logging also says I have 15 lock users, at one time I did, but now I only have 11.
OK so I think i figured it out. After doing some testing, it wonāt allow you to add a user with the same code as another. So if I have one user with code 1234, i canāt add another user with codes 1234, 2234, 1134, 2134, 2234, 1244, etcā¦ (remember with kwikset each button has 2 possible codes associated with it). I think this must be coded into the lock itself as a safety or something. If it was ālock managerā related, and 0827 was somehow stuck in the memory, it wouldnāt allow it to be set on any other lock. Since Iām only having issues with it being set on one specific lock, it must be lock related. When I do the code 0827, the code sets fine on all my other locks except for that specific one mentioned. So when that lock arbitrarily started disabling users, it must have kept 0827 somewhere in the memory and wonāt let me set that code again. So Iāll probably have to reset the lock next time Iām there. Does anyone know if you can reset all the codes from memory remotely?
The 15 lock users includes the users and the locks combined i figured out.
Donāt want to jinx myself, but since I cleared up some somewhat self-inflicted issues a while back, Lock Manager has been purring like a Rolls Royce. Just phenomenal work, @ethayer. Thanks very much.
I just sent another donation to Erik, and I encourage other users to show their appreciation via a donationā¦even a few bucks is appreciated, and well worth it considering the many hours he puts into development and support and the extensive functionality Lock Manager provides.
There are over 1500 posts in this thread, and only 54 clicks on his donation links.
Donāt make Erik feel like an unsupported public radio station. Buy him a cup of coffee to let him know you appreciate it, makes you feel better, makes Erik feel better.
I have tried several lock Manager types and had some sort of problem with them. I then found this one and it has been working like a charm. One very minor thing that bugs me is that when the door is locked or unlocked via smartthings it says door unlocked/locked manually. To me this was not done manually but electronically. Is there a way for the program to say locked/unlocked by User x present sensor, or locked/unlocked electronically by users x. I know I can see the number of times a users has used the locked which is great but it would be nice to know when the lock is done by a present sensor, who it was that was arriving or leaving.
Hi Erik, I have followed the dropbox instructions for Lock Manager which were great for an amateur like me The app has appeared on my phone but I dont think it is communicating with the lock? It lets me select the front door option. When I click on the lock it shows all 30 slots but doesnt ālearnā the codes as you mention. If I exit the app and go back in the lock is no longer showing and it lets me add it as a new lock again. I also tried to add a test user code but it didnt work which makes me think there is a communication break down? Thanks!
Hello.
Itās been awhile.
Iām working on some updates. Hopefully API service will be ready soon, but I have been doing housecleaning on the app to make developing on it more enjoyable. This will include getting rid of all the child apps. The app architecture will still use the child-app system, but all child app code will live in the same file.
This is working well, and Iāll test it to make sure itās good to go while I develop the minimum viable amount of functionality for the API serviceā¦ which is a lot.
*User Creation
*User Scheduling
I also want to include a feature called āentanglementsā that will allow you to tie two switches together across locationsā¦ though maybe that can wait.
This new app will be version 2.0. Not because it includes awesome new features (well, the API might be cool), but because (unfortunately) it will cause users to have to re-install the app. =(
//general pro-tips>
Iāve noticed a lot of people saying their data doesnāt āstickā in the app. I think this is a result of people attempting to access the app from the āMarketplaceā and not from the installed apps section. This will cause a lot of problems.
- Youāll notice your data doesnāt āsaveā This is because youāre creating a whole new app install! Thereās no data to see in a new app.
- When you have more than 1 instance of Lock Manager installed, They will fight, forever. You will program your user into 1 app, and then since the other app knows nothing [jon snow] it will delete your userā¦ then the first app will see that the user is gone and it might program it in again, and so on and so on until you go mad and your batteries die.
So donāt be a goober, install only 1 app at a time. For advanced user purposes, and when I first wrote this app, I didnāt include the flag to disallow multiple installs. The new app will have that flag enabled.
Lock status doesnāt receive codes programmed before installing Lock Manager
This is normal. For security reasons, most (all?) locks do not give their codes to the HUB once they are programmed. The SmartThings device handler tries to keep a record of what it thinks the codes are, but it is not guaranteed to be correct.
PS.
Thank you for your donations. I donāt expect them, but I very much appreciate them. While certain aspects of the API might not be free (The server is going to cost me money) I will continue to develop and offer this app for free as long as it is useful.
I have to say Iām already quite happy that having gotten about 40% through the guide my SmartThings app now displays the āSmart Locksā menu and the āstatusā, ālock codesā, and āhistoryā tabs seem to display the correct info. What bothers me is more what I didnāt do in the guide:
- In āMy Devicesā on website (graph.api.smartthings.com) I see no devices listed. Iāve waited but nothing comes back. I think I did āactivateā the app on the smartthings mobile app (although Iām forgetting what I did precisely). this also means that I can not Edit the Lock Device.
I am literally half-way around the world from my lock so being very cautious and not making any door code changes but would love some assurances or directions on getting to the happy path.
Ken
@ksnyde try logging into IDE with https://account.smartthings.com instead of the link you posted above.
That did the trick! Thank you!
One follow-up question though ā¦ when I click āeditā on the device and look at the ātypeā dropdown it has already highlighted Z-wave Lock. I looked at the list and there was no mention of a specific Yale option. Is that an issue?
In the ādataā section of the device I see the following listed:
- fw: 254.194
- manufacturer: Yale
- MSR: 0129-B52B-34F8
Z-Wave Lock is the stock ST device handler for z-wave locks. If you wish to use the ST Smart Locks app, you would need that device handler. If you wish to use ethayerās Lock Manager app, you would need to install the Z-Wave Lock Reporting device handler and assign it to your Yale lock. that device handler can be found hereā¦
I eventually switched to Rboyapps because it was more āreliableā than this one. Not a knock on your work, I think your app has much better features and Rboyappsā method is to completely reset every code slot upon saving (which is why I think itās probably more āstableā) and is incredibly slow.
That being said, Iād still like to switch back because of the more sophisticated scheduling and changing a key will only update its respective slot. So Iām wondering, did you ever get more bug reports about the issues I reported May '17
I have this exact same problem on my Yale YRD 446. My other lock (a Schlage) works fine in Lock Manager. Has anyone solved this yet?
If I couldā¦ Iām using ethayerās App and hereās my take:
- I had difficulty getting it installed the first time.
- That was mostly my fault (the instructions could have been a little better)
- Second install workedā¦ and since then itās been bulletproof.
My lock is Schlage BE469.
Ok, setting this up and want to make sure I am using the right DTH - I have a Schalge Camelot so use the zwave-schlage-touchscreen-lock DTH right?
TIA
That is correct.
Thanks - perhaps dumb question ā¦
In the tiles for the lock there is a red line that when selected is a dimmer control / level set from 1-5 ā¦ what the heck is this for ?
For the past week my Lock Manager app has been completely disintegrating (with some added help from me), after working great for months. I did the recent updates (after some of these difficulties started to emerge), I tried to do a Z-wave mesh repair. I have two smartapps installed: the ā5-2 Day Thermostatā and the āDoor Lock Code user Managementā¦ā. I have 4 schlage z-wave locks. NONE of the locks work via their keypads now. I can only use a physical key or press ālockedā or āunlockedā in the ST app in my iPhone under āMy Homeā > āThings.ā
When I go to Automation > Door lock code user managementā¦ and select all 4 locks, 20 users (slots) and then configure several of the users, all as āpermanentā with 4-digit codes, and āNotify on useā, and then click Done and Save, I do not get the old green pop up saying that the info is being saved. When I go to the hamburger menu, and click on Notifications, it seems to show an endless loop of āRequesting Front Door to add permanent code FRED to user 1, code: 1234ā etc. for all the different locks/things and users I have tried to install. The messages all constantly say ārequestingā with no confirmations. Iām exhausted. Please help!
