SmartThings Community
[RELEASE] Lock Manager
smartapp_locks
(Kampto) #1205
Is it possible to override the auto lock feature and have it reference if a door sensor is closed before auto locking? Tired of my kids slamming the door closed with the deadbolt out because it auto locked after 30sec. Using Kwikset 910…
Thanks.
#1206
@kampto - This Lock Manager has always been great for me but I was having the same issue with the wife & kids slamming the door with the deadbolt out. I started using the below for the Auto Lock and disabled the Autolock on the Lockmanager Smart App. It will keep the door from Auto Locking if the Contact is not closed and will send a notification if the door has been open after a certain amount of time. It has worked great for me so far & my door jam has appreciated it :slight_smile:
Only note - I had a little bit where my contact sensor was stuck on open, when this happened, the door never autolocked. Only real thing to look out for, BUT, the notification should give you the heads up that it hasnt been closed.
After playing with WebCoRe a lot lately though, this may be pretty easy to set up in there as well. I havent updated yet because this app has worked pretty well lately.
(Kampto) #1207
I installed the club steve autolock smartapp… Configured it to use the lock and door sensor. Still locked the door after being open for 30sec. Will play with it some more.
#1208
Make sure you shut of the Auto lock from the Lock Manager smart app. Go into your lock and there is a button on the bottom Left that says Auto Lock. Shut that off and try again.
Edit: Bottom LEFT!
(Kampto) #1209
Thanks, turned autolock off on the dip switch on the lock. Works now!!
(jerry) #1210
I’m having a very weird problem with lock manager. I upgraded from the old User Lock Manager, which was unreliable for me with my Schlage Connect lock. I copied all of the old user codes by hand into LM, but didn’t delete ULM, wanting to make suer that LM worked properly first. So far, so good - all the users codes worked fine. Now, though, I can’t create any new codes. When I make a new user, it tells me that the user has been added and is now automating. I try the lock and the new code works. After a while, though (not sure how long, but <30 minutes) the code goes away. When I look at the lock within the LM app, the slot in question looks fine after being set, but later its status changes to “Controller failed to set user code”. The “entries” code shows 1, not 0, so I know that it actually worked when I tried it. If I go into the user and push the “reset user”, it tells me “user re-enabled, lock has been reset”, and it works fine. I check the app and, sure enough, the entry count has incremented. but, again, a few minutes later it doesn’t work again.
The codes that were also used in ULM - those I put into LM initially - are stable, and continue to work. It’s just that I can’t make any new ones. And, no, I haven’t exceeded the number of available slots.
The “recently” tab on the lock has a bunch of “Lock: Front Door Lock- Sent Undatecodes Command to Front Door Lock” messages. These are happening more often than I am adding users, more than 1 message per code addition.
The lock is of type “Z-Wave Schlage Touchscreen Lock”. The apps installed are ethayer:Keypad, ethayer:Lock, ethayer:Lock User (all unpublished) and ethayer:Lock manager (published). I also have rboy:Lock multiuser code management… installed, but haven’t opened or used it. I had User Lock Manager installed, but it is now deleted and the problem persists
What should I try? What’s going on? Thanks, in advance, for any help with this.
(jerry) #1211
Here is a debug log of the problem. I reset the user at 4:13. That’s the only thing I did. As you can see, there’s lots of activity for the next 8 minutes or so. Then, at 4:20.32, it logs a msg that Mary Pat (the user who I reset) no longer has access.
Any ideas?
0f0c56f7-9735-45a4-aa3d-3115d4a9928f  4:21:04 PM: debug No codes to set
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:21:04 PM: debug running load codes
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:59 PM: debug run code logic
458b104d-fb5a-46ee-b763-00ca33e00106 4:20:44 PM: debug Not parsing XML message:
<s:Envelope xmlns:s=“ht tp://schemas.xmlsoap.org/soap/envelope/” s:encodingStyle=“ht tp://schemas.xmlsoap.org/soap/encoding/”>
<s:Body>
<u:GetVolumeResponse xmlns:u=“urn:schemas-upnp-org:service:RenderingControl:1”>
<CurrentVolume>
54
</CurrentVolume>
</u:GetVolumeResponse>
</s:Body>
</s:Envelope>
458b104d-fb5a-46ee-b763-00ca33e00106 4:20:44 PM: trace Extracting current volume
458b104d-fb5a-46ee-b763-00ca33e00106 4:20:44 PM: trace sonosAction(GetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master])
458b104d-fb5a-46ee-b763-00ca33e00106 4:20:44 PM: trace getVolume()
458b104d-fb5a-46ee-b763-00ca33e00106 4:20:44 PM: trace doPoll
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:33 PM: debug “zw device: 02, command: 9881, payload: 00 63 03 0A 00 " parsed to [[‘name’:‘codeReport’, ‘value’:10, ‘data’:[‘code’:’’], ‘descriptionText’:Front Door Lock code 10 is not set, ‘displayed’:true, ‘isStateChange’:false, ‘linkText’:‘Front Door Lock’]]
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:33 PM: debug code report parsed to [[‘name’:‘codeReport’, ‘value’:10, ‘data’:[‘code’:’’], ‘descriptionText’:Front Door Lock code 10 is not set, ‘displayed’:true, ‘isStateChange’:false, ‘linkText’:‘Front Door Lock’]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:32 PM: debug Mary Pat no longer has access to Front Door Lock
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:32 PM: debug Received: s:10 c:null
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:31 PM: debug “zw device: 02, command: 9881, payload: 00 63 03 0A 00 " parsed to [[‘name’:‘codeReport’, ‘value’:10, ‘data’:[‘code’:’’], ‘descriptionText’:Front Door Lock code 10 was deleted, ‘displayed’:true, ‘isStateChange’:true, ‘linkText’:‘Front Door Lock’]]
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:31 PM: debug code report parsed to [[‘name’:‘codeReport’, ‘value’:10, ‘data’:[‘code’:’’], ‘descriptionText’:Front Door Lock code 10 was deleted, ‘displayed’:true, ‘isStateChange’:true, ‘linkText’:‘Front Door Lock’]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:29 PM: debug update: [[“code10”,””]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:29 PM: debug 1410:null s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:29 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:29 PM: debug deleting code 10
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:29 PM: debug code10 was 1410, set to deleted
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:29 PM: debug updateCodes called with: '[[“code10”,""]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:24 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:24 PM: debug Received: [code22:, code21:, code24:, code23:, fw:113.22, code20:, ver:7.1, lastbatt:1507294061813, code29:, blankcodes:true, code25:, code26:, code27:, MSR:003B-6341-5044, enc:1, lastPoll:1507329633278, code28:, code13:, code12:, code11:, assoc:1, code10:1410, init:true, code9:, code6:2807, code5:4286, code8:4030, code7:9041, code2:1767, code1:6475, pinLength:null, codes:30, code18:, code4:5194, code30:, code19:, code3:0460, code16:, code17:, code14:, code15:]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:24 PM: debug Lock has 30 code slots.
bde3378b-7953-4fec-935a-7fc7943942aa 4:20:24 PM: debug poll is sending []
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:20:08 PM: debug Lock has 30 code slots.
bda207fc-1b6c-4639-b53f-810d8e364139 4:20:08 PM: debug Parse returned {{ linkText }} has arrived
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:55 PM: debug No codes to set
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:55 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:55 PM: debug running load codes
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:50 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:20 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:20 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:20 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:19:20 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:19:20 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:19:15 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:45 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:45 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:45 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:18:45 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:18:45 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:41 PM: debug Lock has 30 code slots.
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:40 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:10 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:10 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:10 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:18:10 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:18:10 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:18:04 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:17:34 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:17:34 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:17:34 PM: debug running load codes
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:17:28 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:58 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:58 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:58 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:16:58 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:16:58 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:53 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:23 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:23 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:23 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:16:23 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:16:23 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:16:18 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:48 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:48 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:48 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:15:48 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:15:48 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
458b104d-fb5a-46ee-b763-00ca33e00106 4:15:44 PM: debug Not parsing XML message:
<s:Body>
<CurrentVolume>
54
</CurrentVolume>
</s:Body>
</s:Envelope>
458b104d-fb5a-46ee-b763-00ca33e00106 4:15:44 PM: trace Extracting current volume
458b104d-fb5a-46ee-b763-00ca33e00106 4:15:44 PM: trace sonosAction(GetVolume, RenderingControl, /MediaRenderer/RenderingControl/Control, [InstanceID:0, Channel:Master])
458b104d-fb5a-46ee-b763-00ca33e00106 4:15:44 PM: trace getVolume()
458b104d-fb5a-46ee-b763-00ca33e00106 4:15:44 PM: trace doPoll
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:43 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:13 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:13 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:13 PM: debug running load codes
bde3378b-7953-4fec-935a-7fc7943942aa 4:15:13 PM: debug code10 remains unchanged.
bde3378b-7953-4fec-935a-7fc7943942aa 4:15:13 PM: debug updateCodes called with: '[[“code10”,“1410”]]'
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:15:07 PM: debug run code logic
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:14:37 PM: debug update: [[“code10”,“1410”]]
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:14:37 PM: debug null:1410 s:10
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:14:37 PM: debug running load codes
0f0c56f7-9735-45a4-aa3d-3115d4a9928f 4:14:32 PM: debug run code logic
4:14:17 PM: info Waiting on events…
4:14:17 PM: info For past logs for individual things go to the My Devices section, find the device and click on the Events link on the device information page.
4:14:17 PM: info This console provides live logging of your SmartThings.
(Sean) #1212
Can I use this with both Schlage Locks and a Yale Lock together in this app?
assuming I have the code length set to the same value!
Reason why is I have 3 Schlage Lock’s but I cannot mount these on one my doors, because it is too wide (3") I can only mount a 2 3/4 inch lock max.
So I was looking at adding a Yale lock (its specs at only 2 3/4")
or any other suggestions?
#1213
Hi Ethayer,
I finished all the steps on Page 12 of the manual. Found all four apps under my smart apps. But I couldn’t find any apps from my apps under marketplace. Could you give me some help?
Henf
(Mike) #1214
I have two Schlages and one Kwickset, so using a Yale should not be an issue.
#1215
It sounds like you may have installed the apps on the wrong shard (server) in the IDE which is easily done.
See here:
#1216
Hi, Thanks for the quick response.
Actually, I solved the previous problem. I published all the 4 apps I installed under my smartapps, then they showed up on my phone.
But new issue coming, I created new lock( which is my front door lock) and one new User( “cooking Lady”) and they both showed on my phone and with the green check mark on the top go my screen says Lock manager is now installed and automating. But after I click the “done” on the upper right corner, the page when back to Smartapps under the marketplace. when I click my apps and lock manager, all the" front door" and cooking Lady are gone. nothing left there. What happened? Can anybody help me? Appreciated !
(jkp) #1217
Use the Lock Manager that is located in Automation: SmartApps not the one in MarketPlace: Smartapps: My Apps (which your image is showing that is where you are). Hope this helps :slight_smile:
#1218
where is the Automation? on the phone?
(jkp) #1219
the icon to the left of the MarketPlace icon (the one highlighted in your image above)
#1220
Found it! will try! great thanks!
#1221
Thank you! jkp! Now they are stay.
I set up a new code and it doesn’t work. Do I still need to use the programming code to set up on the lock?
Also, there is another screen shot shows this:
Is there something wrong and what does the require another special DTH mean?
(jkp) #1222
Did you assign the correct DTH to the lock which is in the install guide? They can be found here:
#1223
Sorry, I am very new. is the DTH stands for Devices Handlers? Now Under my devices handler, shows nothing, like this
should I add one from those two?
(jkp) #1224
Which lock do you have?
