Cant say for sure on the Kwikset, but i use the ‘Garyd9’ handler (available from GitHub account above) for my Schlage and it has worked well for quite some time now.
You will need to use the ‘Developer Tools’ to create/set the custom device handlers necessary for each lock: https://graph.api.smartthings.com/
Highly recommend following the install guide posted above if you are new to all of this. It is one of the best I have seen around.
I have a two Schlages and one Kwickset. For the Kwickset I use the Z-Wave Lock Reporting DTH. For the Schlage I use the Z-Wave Schlage Touchscreen Lock. These are the two DTHs detailed in the installation instructions for this app.
Assuming DTH somehow references a device handler. Everyone is using the acronym and the definition of that acronym is nowhere to be found. Wiki turned up primarily NC Tarheels newspapers and Urban Dictionary, while funny, didn’t offer much more help. Clarification would be nice…unless everyone using the acronym has no idea what it means and has just been too ashamed to ask.
Second, has anyone else noticed that, in general, changing a code for an existing user required deletion of said user and recreation of a new user account? Somewhat similarly, after creating a new user account or deleting an unwanted one, it doesn’t seem that the change takes effect until after I log out of my SmartThings app and then log back in.
I am looking for a behavior that I can use that will provide me a high level of confidence that everything is working properly. I will be managing this lock from over 2200 miles away for no less than two years and lapses in reliability, while manageable when experienced on occasion, will eventually make the juice NOT worth the squeeze.
Dropbox changed the policy for shared folders and broke all the icons. I’ll get them sorted out shortly with an update… I have to find a new place to host them.
I can’t do that as I’m using it for homestay. Some guests just wanted to leave it for a moment to buy something across the street (just 20 steps away).
On the SmartThings app ->
Click ‘My home’ ->
click ‘Things’>
<find your lock, click on it>
Tap on the tile ‘Lock & Leave’ slowly (about 5s apart) until it reads ‘Lock & Leave Enabled’
It may truncate the text to fit the tile to show something like “Lock & Leave En…”
I’m having a huge problem with my BE469 Schlage lock.
I was able to install Lock Manager, and get it running. I’ve tried to add 4 sets of user codes. This is where I get into problems:
2 codes only ever seem to get set in slot 1 and 2. Users in Slot 3 and 4 can’t get set and I get the common error people report about failure “Controller failed to set code for [user]”.
Commonly, my SmartThings Lock Manager app section forgets my lock. It just disappears and I have to keep readding it. After I do, the codes are all not set.
I’ve also noticed on the smartthings IDE, my hub keeps getting forgotten as well (this probably explains #2). In my SmartThings mobile app, my devices and hub seem to be fine there so the hub is clearly connected and reporting things to the cloud. Not sure what the heck is going on.
