Removed Yale lock via device exclusion on samsung app, pushed #7 key, then #3, yada yada. Lock confirmed removed off my z-wave network. I then opened my laptop and removed the updated Z-Wave Lock Reporting DTH that was just updated via @ethayer github repo, then removed the app itself from the iOS installed list, and finally removing it via the smartthings website and all the child apps as well. (keep in mind, the physical lock hasn’t been reset, as you have to take it apart to access a special button, so User #1 and User #2, as well as my master code are still set)
I then put the lock in inclusion mode and added a new thing to my smartthings app via the iOS app, this time it defauled to Z-Wave Lock as the name, instead of Z-Wave Lock With Reporting, as I have already removed the custom DTH installed from your repo earlier today. I then added the DTH again, and selected my lock after publishing it. Next, I re-added all the Lock Master apps and child apps as I normally would and returned to my iOS device to install it.
My question is do I need to add the users again? Which would be myself for User 1 and my wife for User 2, keep in mind our codes are currently still stored in the lock as I programmed them in before I discovered this app about a week later after my purchase, I added the “users” in the lock manager app to mirror what I basically did on the lock when setting up the master code and users (total of 2).
As it stands now, it says App is learning codes. They will appear here when received. Lock may require special DTH to work properly and that’s it. If I leave it all night long, it will most likely still say this (I also have the overwrite ON to delete codes not in the users list)
If I add myself as User #1 and use the code programmed in the lock I know to be true, and the same for my wife for User #2 in the Lock Manager app, they will show up as User 1 and User 2, I will receive a notification for myself and my wife that we are now users in the lock, and have been assigned codes. However, the unlock count will always remain 0, and the only functionality this app and DTH seem to have is well, a ton of manual lock and unlock notifications on my device, as I do not receive the code based ones I have turned on for myself and my wife, I do not receive the incorrect code after 1 wrong entry message, I do not receive basically anything besides manual lock and unlock.
I’m pretty much at a complete standstill after a couple weeks of tinkering with this new lock, I don’t see it having much functionality without these features in this app working for me…should I return it? I don’t understand what I’m doing wrong, I did everything as you said. Any ideas? Physically take the lock apart and reset it?
