It just sent another request, where it left off at Slot 7. Seems to have stalled
Erik, any luck running into the same issue I have? I just checked again and it is still happening.
No, unfortunately⊠I deleted the app several times and I wasnât able to replicate the issue.
Iâve made the requestCode routine a lot more aggressive. Can you update your app and test it out for me? I clocked my BE469 at just a little over 4 minutes using the new method.
EDIT: my kwikset 910 also took ~4 minutes
I made a mistake(probably several) when writing the tutorial. I should have stated that you should select âLock Managerâ from the IDE, check âPublishâ checkbox and click âExecute Updateâ
After âLock Managerâ is installed, then go ahead and click update from repo, select the Lock Manager repo again, select the 3 remaining child apps and then click âExecute Updateâ (you can leave the publish checkbox unchecked)
Just tried to install new app from GitHub, got this error:
Oh No! Something Went Wrong!
Error
500: Internal Server Error
URI
/ide/app/doRepoUpdates
Reference Id
b3ef8cac-037a-4521-9c99-cd8b237f7588
Date
Mon Mar 13 12:49:27 UTC 2017
I already deleted old code and DTH, followed your install instructions
If you are copying and pasting the data thatâs probably the problem, it was for me. Type the information in.
Sorry realize a little more info will help, Iâm referring to the page 3 in the instructions where you add the repository.
No, I used GitHub, followed instructions exactly. The error came up when I clicked âExecute Updateâ
Read my previous post.
Got it. Thanks
[quote=âethayer, post:367, topic:63022â]
[/quote] @ethayer or any github expert⊠Sorry for being obtuse, because I think you have already answered my question, but to be super-clear: If parent & child apps are correctly installed as published & not published, respectively, then can subsequent github repo updates ignore the âpublishâ checkbox and updates will proceed to leave the parent published and the child unpublished?
I updated the code now when I open my locks and press done I get the following error in the Logs:
java.lang.NullPointerException: Cannot execute null+null @ line 254
Whoops, I added a variable that gets set on some initializing scripts⊠but it only works if you hadnât been using the app already, this should be fixed.
The FE are getting a ârequestcodeâ but are not responding back after 6 mins no more requests and the lock never respondedâŠ
My Front Door BE got a ton of ârequestcodeâ and started where it left off last night at Slot 7 but after 10 mins it has only responded to Slots 6 and 7. Still getting ârequestcodeâ but no response from lock.
The app finally let me go in and do a refresh on the âFront Doorâ it took 6 mins but it received al of the slots.
Problem: I deleted a Temp user and code, yesterday, when I was trying the Burn Feature. The code is still in the lock. It shows the code in Slot 4 but doesnât show a user. Iâve done 3 refreshes.
Do you have Overwrite Mode toggled off in âAdvanced Settingsâ in the main page?
Hopefully the edit I made last night helps with that refresh issue, Iâm hoping they populate well now. From what you said, it sounds like that part worked.
Yes overwrite is on, just double checked. I just added another temp user and assigned slot four. The code changed to new code. I just deleted the user. The new code is still in the lock and the app shows the code in slot 4 but no user.name
Ok, I can reproduce this on my platform too. Pretty sure itâs a simple fix, Iâll look at it tonight.
Thatâs right! If you donât publish the child apps, the main app still has access to them but they wonât show up in your My Apps section. If you publish them, it doesnât really hurt anything, theyâll just show up on your device and youâll just have to ignore them.
Iâm sorry that I canât figure this out. My only thought is to nuke your install one last time, make sure youâre updated on the most recent code on GitHub and then create the app again. =( Let me know if you do this and you still have the issue.
The DTH I have in this repo IS garyd9âs old DTH, with just a boolean change in a couple spots, so that shouldnât cause the disparity. Iâm using this edited version myself with the exact same lock, so Iâm not sure why weâre getting various levels of success.
Thanks for the reply Erik. Iâll delete, update code, and start over tonight if I get time. Will keep you updated once I get to it.
Hi Erik, a couple additional observations;
When arming through the keypad, the user specific keypad routines do not run, only the general (all user) routines will run. This may have been a platform error but I have not been able to test past switching from user specific to general (which fixed the issue).
Also, I noticed that while your keypad SmartApp calls the function correctly, the Zigbee Keypad DTH has an error which prevents the exit delay beeping from being initiated. Iâm going to create a pull request on that DTH in order to fix the issue but I figure you may want to get the updated DTH once itâs available (maybe host it like you are the modified Schlage Touchscreen DTH).
