@red9r make sure you have it set like the attached pic
Yessir, exactly like that. Iām guessing I may have messed something up when integrating github.
FYI, thing are now working for me. Only 2 exceptions, I havenāt been able to get your DTH code to sucesfully sync from GitHub, it just errors. For now, I will just copy and paste it in.
Iām still getting the message null was added to doors as it add the codes. Names are all correct otherwise in every other place that I look. Iām not doing anything fancy, just a first name like Jeff.
I got it to work. I retyped everything instead of copy/paste from the document.
Now Iām getting the following errors when I attempt to Update from Repo:
Error 500: Internal Server Error
URI: /ide/app/doRepoUpdates
Reference Id: 2ff2a37e-cd36-43ff-9ce3-c13a353a0ceb
Date: Sun Mar 12 00:20:44 UTC 2017
got mine working but i seriously screwed something upā¦
its installed like 5 times
Got the Update from Repo to work as well by adding the 4 apps one at a time.
My Schlage BE locks updated codes, 3 of them took from 10 to 20 mins. I have three FE Schlage locks that started the āRequestcodeā 2 hours ago and still havenāt updated. Iām using the following DTHās on the FEās:
1 has the New DTH
1 has "Z-wave Lock"
1 has āZ-wave lock reportingā, this is the one I have always used with these locks.
Did these three locks work well with the old app?
EDIT: Maybe I can come up with a combination of logic between how the old app functioned and how this works nowā¦
Erik,
Yes they worked fine with the old app. Even the new locks, as I mentioned are taking longer to update.
Awesome support,
Michael
Good NEWS ā this works perfectly! great collaboration - the notification allows me to know WHO unlocked the door with a verbal notification - through my Sonos ! really really love this !
Hi Erik, looks like Iām still having some issues. I added locks 1 by 1 until they checked all slots for pins. 1 lock took longer than others, so not sure what is up with that. I then added users and it seemed ok. I just tried to look at the locks a few minutes ago to see what pins have been put in what slot, just to make sure they are being reported, and it did the spinning thing again but never loaded. I tried again with the ide log open and this error is displayed: error java.lang.NullPointerException: Cannot get property āusageā on null object @ line 947. Looks like the same error as earlier. My guess is it is line 947 in the DTH, not the Lock Manager smartapp code? Let me know what else I can get or test to help you out.
Remind me, what Schlage lock are you using? Iām going to try to get in the same state youāre in. The app seems to be working OK for me, but Iām going to uninstall everything and try from the ground up to see if I canāt get it to pop that error.
I too am having this issue. I have added a test slot - that was set to burn after 2 uses.
The notification does indicate that is āburning code nowā however the code continues to unlock the door when entered on the keypad.
I have tired 2 both DTH - same results - using the DTH you have posted here Erik.
Not sure this helps:
I have 3 BE469ās. Thanks for the help! Prior to V1, I was using Garyās DTH and did not have any issues. I completely understand the need to change, but just wanted to let you know the progression of things.
Would you consider adding multiple selection of modes in the scheduling a user section? I think this?
Line 312 in user
section {
input(name: 'modeStart', title: 'Allow Access only when in this mode', type: 'mode', required: false, mutliple: true, submitOnChange: true)
I saw this error as well when clicking on My SmartApps straight from the smartthings developer login landing page. However, if i go to my āMy Locationsā first and select first, then My SmartApps will direct to https://graph-na02-useast1.api.smartthings.com/ide/apps (which seems to be the correct place to do things in my account) instead of https://graph.api.smartthings.com/ide/apps.
Thatās a typo in the documentation - it should be āethayer/lock-managerā
Erik,
I just tried Burning codes:
- When I did burn after 1 time everything worked and code Burned, on my Front Door
- When I did burn after 2 times, on Front Door, it didnāt burn the code, and the BE has been in ārequestcodeā for over 2 hours now. Code still works
I added my three users back but got an error (forget what it was) when I added one with a schedule - Thursdays. It appears to have taken it but when I try to go back into that user, it clocks for a moment and then does not go into the edit mode for that user. I can edit the other two users.
here is the log entry. any ideas?
3:31:49 PM: error groovy.lang.MissingMethodException: No signature of method: script1489346626715825465053.yyyy-MM-dd() is applicable for argument
sorry, did not realize i could swipe left to remove. removed and added back and it seems to be OK.
Can you go into the BEās settings page and then click ādoneā to initialize it again? Maybe it will continue the polling after that.
Thanks for letting me know about the issue. Iāll be trying to make this part smoother tonight.
