here is the screenshot of the leaksmart sensor. i replaced the batteries
and it still comes up as always wet.
Hello
Yes I took the batteries out of the sensor
Any chance you have access to a Wink hub? Version 1F is pretty old. I think 26 is the latest version.
Yes I have a wink hub. What would I need to do
Yes I have a wink hub. What will I need to do
Remove them from SmartThings.
Pair them with the Wink hub.
Double check the version once linked to Wink.
Wait about 3 to 4 hours.
Check to see if they have updated.
If not wait another hour.
Mine all took 2-4 hours.
Hi Eric
Hey thanks alot for the help. Like I say I am in no way a computer person
but I like to learn. We did get the wink hub up and running and did include
the leaksmart with the wink and yes I have noticed after about 4 hours it
did up date the leaksmart sensor. I will the tomorrow include it back into
smartthings. I would like to thank you for your help. Jeff
Let me know if it works or not.
Hi Eric
Wanted to let you know that I hooked the sensor back up to smartthings and it is working great now, Thank you so much.
I’ve got everything setup, but it looks like I’m only getting temp/battery status. I don’t get the wet/dry status, though the UI on the app shows “Dry”. I’m assuming the sensor sends out a notification when the status changes from dry to wet (rather than being polled by the hub), but want to be sure. I have the Aeotec Z-Wave sensors which work this way and seem to have great battery life.
I see that a few other folks have been experience a similar issue to mine (not receiving wet/dry status). What is the resolution? I have v21 firmware. Do I need to update to v26?
Also, what is “compatibility” setting in the app?
What version of the Hub do you have? Compatibility mode needs to be turned on for version 1 of the hub.
I’ve got a v2 hub.
With version 21 you should be ok, but should upgrade if you can. The version isn’t your issue. When you get the sensor wet does it beep?
I had to, in this order, reset mine (which it never beeps to let you know), pull the battery, wait a bit, reinstall battery and re-join it.
Yes, it beeps when wet.
Thanks! I’ll try that sequence tonight. When you say “re-join it”, do you remove it from your hub before the reset, or after?
Neither. Leave it as a device in ST. When you re-join in to ST after the reset it will join as the same device since Zigbee device id’s are static.
Try these steps, exactly…
1 - Put the ST app into pairing mode.
2 - Press and hold the button for 5-6 seconds (I can’t remember if it blinks differently or not once it resets).
3 - Pull 1 battery out, hold down the button.
4 - Push the battery back in and let go of the button immediately (as soon as the battery is in < 500ms), you should hear a short loud beep.
5 - Wait 4-5 seconds and press the button once quickly, don’t hold it down.
Sorry everyone but I am a Newbie with ST hub. Looking forward to getting all my current things to work off of it and went right to adding LeakSmart products. The problem is I have my GitHub integration ready to go and everything seems to be in place however I got caught on step 2 . I do not see a “My Device Types” section in the navigation bar. So I go to “My Devices” but it does not have a “settings” button. If I click on “My Device Handlers” I get a “settings” button. Then I click the “Add new repository” from there but nothing matches the instructions.I am obviously looking in the wrong place. Help I am excited to get this thing going… Thanks.
It works great now! I updated some to v26, but left one at v21… both seem to work the same. I’m going to monitor the battery life difference between the versions. The one I was struggling to get working (on v21) is already down to 95%. Hoping the v26 ones are a bit more reasonable.
