Please excuse my long thread…newbie just getting started.
So my house is light config is setup with Hue and Caseta which are controlled by Homekit/Siri and Amazon/Alexa. Works perfect.
Smarthing Hub I have doors and motion sensors config and working. This past week after lots of reading I installed Lannouncer on an Samsung S6 connected to a bluetooth speaker. I installed Bigtalker smartapp also. Works good.
Installed VLC thing also on a computer and connected another bluetooth speaker, this also works great.
I am using VLC/Bigtalk to announce open and closed door events.That all I need it for.
In SHM I have 2 problems.
I am using Lannouncer as a Siren when my house is armed but the volume is very low. I set Lannouncer volume to loud but still. I even coonect my Lannouncer device wired to speaker and still low volume. Connected it to my bluetooth stereo receiver and still low volume… How can I increase the siren to be loud enough?
Why am I only seeing lannouncer in my SHM config as only a siren? In the lannouncer thing I can test all the different effects( strobe, siren, speak, tone etc) and it works. I would like to atleast use tone and speak in SHM also.
Thank you.
Hi folks… am I missing something obvious? I’ve got LANnouncer up and running, but I can only get it to give me the audio notifications when the android app is running in the foreground. If my phone has any other App up, or if it is asleep, it does not notify. Once I open up the LANnouncer App, then it catches up with all the notifications that come through at that time… is that expected behavior? (I’m on Android 7.0)
Can’t really help with a solution, but I can report that is not expected behavior. Mine, on three different platforms, speaks when LANnouncer is in the background.
Don’t exit LANNouncer (don’t hit “back” until you’re out); just hit your Android home button (little button in the middle of the bottom of the phone with a circle or house on it), which should take you to your main phone screen, and launch another app. Or switch apps with the task switcher. But don’t exit.
Ensure LANNouncer is not “battery optimized” in settings. Really that shouldn’t matter, but under the conditions you’re having, perhaps it does.
I can’t seem to connect to my Fire tablet. I put in the ip address and port and it just stays grey. I tried redoing the whole thing with no luck. It worked then my power cut out and it doesn’t work anymore.
One possibility - If the tablet did not have a static ip address, when your power came back up it may have been assigned a different IP address when it reconnected. I would verify the address of the tablet.
I got it to reconnect and was setting up some core pistons and big talker and all of a sudden can only use speak setting. Did I do that on accident maybe?
When you were setting-up/configuring Big Talker, did you set the switch on the first configuration page to OFF? It defaults to Music Player and not Speech Synthesis. For LANnouncer it needs to be on Speech Synthesis.
Could I do both? When it was setup to default music player it did speech and chimes. Could I maybe have two of the same device one setup as voice synthesizer and the other as a music player to get both benefitsm
I get spoken event notifications from Big Talker set to speech synthesis through my tablet with LANnouncer. I use CoRE to ring a chime on the tablet via LANnouncer when a door sensor is opened or closed.
Ok I feel really dumb and maybe because I kinda am with this stuff. I don’t really know what in doing. I add the device handler. I then go to my devices. Add new and I can find LANnouncer on the bottom. I select it but it looks nothing like the walk though page. It wants a name and device Id and a hub or home? I can get to step 7 and that’s it. Step 8 doesn’t look like anything I see
I have a tablet (the one that came with my Vizio TV), connected via Bluetooth to an Echo. Here is a Piston that chimes if doors are open too long. The chime is weak on the tablet but from the Echo its so cool!
Awesome. Yup got it all working now. Than you so much for the help. Do you know of a way to make it repeat a word without having to type it oup a lot of times? Want it to say intruder once the alarm sounds.
