[RELEASE] KuKuHarmony - DTH and SmartApp that support to control devices in Logitech Harmony(using Harmony-API)
smartapp_av
harmony
dth_av
requires_server
project_av
(Bill S.) #597
AFAIK, you can install nodejs on the Synology DS218. I found this https://github.com/StephanThierry/nodejs4synologynas. Once you get that done, you should be able to use the npm version of the API.
(Bill S.) #598
What do you get if you go to http://<your_pi_ip>:8282?
(Bill S.) #599
(A little late) As others have said, your best bet would be to write a custom DTH (modeled on KuKu’s DTHs) OR setup the fireplace as a “aircon” type. That’s what I do with mine and utilize the 5 custom slots for functions. It works (for the most part), but it’s not as seamless as I would like it to be.
(DJAC) #600
I get a harmony page
Info
GET /hubs
GET /hubs/:hub_slug/status
GET /hubs/:hub_slug/commands
GET /hubs/:hub_slug/activities
GET /hubs/:hub_slug/activities/:activity_slug/commands
GET /hubs/:hub_slug/devices
GET /hubs/:hub_slug/devices/:device_slug/commands
Control
PUT /hubs/:hub_slug/off
POST /hubs/:hub_slug/activities/:activity_slug
POST /hubs/:hub_slug/:command_slug
POST DEPRECATED /hubs/:hub_slug/start_activity?activity=:activity_slug
POST /hubs/:hub_slug/devices/:device_slug/commands/:command_slug
Your Hubs
Main 1
GET /hubs/main-1/status
GET /hubs/main-1/activities
GET /hubs/main-1/commands
GET /hubs/main-1/activities/candles/commands
GET /hubs/main-1/activities/lg-live-tv/commands
GET /hubs/main-1/activities/make-it-cooler/commands
GET /hubs/main-1/activities/pandora-channel/commands
GET /hubs/main-1/activities/poweroff/commands
GET /hubs/main-1/devices
GET /hubs/main-1/devices/koko-aroma-dehumidifier/commands
GET /hubs/main-1/devices/candle-sticks/commands
GET /hubs/main-1/devices/lg-living-room-tv/commands
GET /hubs/main-1/devices/lg-living-room-tv-always-on/commands
GET /hubs/main-1/devices/york-climate-control/commands
Is that a good start…lol
thank you again for your time
(Bill S.) #601
Yay! That’s the desired result. You’re all set now. :smiley:
No problem!
(DJAC) #602
Only one thing…
I cant discover my hub on the smart app and
how do i make sure it will auto start on reboot
(Bill S.) #603
On the smart app, you have to make sure that you use the IP address and port. So, make sure the Harmony-API Server IP Address looks like <your_pi_ip>:8282. Don’t put http:// there as it will break it.
To get Docker to restart on boot:
# sudo vim /etc/systemd/system/harmony-api.service
    <harmony-api.service File content>
    [Unit]
    Description=Harmony API container
    Requires=docker.service
    After=docker.service
    [Service]
    Restart=always
    ExecStart=/usr/bin/docker start -a harmony-api
    ExecStop=/usr/bin/docker stop -t 2 harmony-api
    [Install]
    WantedBy=multi-user.target
    # sudo systemctl enable /etc/systemd/system/harmony-api.service
(DJAC) #604
Yes this is the part that got me confused. I dont know how to use vim and when i puched that in… i could not exit…
Now i think my VIM has a duplicate file…
New to this
THANK YOU ITS WORKING!!! I didnt put the port number in.
(Bill S.) #605
LOL. Quick ref:
To save and exit in VIM: ESC :wq
To exit without saving in VIM: ESC :q!
To save without exiting in VIM: ESC :w!
So, just repeat the steps above for the service file using the ESC :wq command when you are done. After that, run sudo systemctl daemon-reload and then sudo systemctl enable /etc/systemd/system/harmony-api.service.
(Bill S.) #606
The other thing you might want to do is use nano instead of vim. In nano, you can use CTRL+[key] for commands and it’s a bit more intuitive. Us old folks are the ones that use vi/vim mostly. :wink:
Glad you’re up and running!
(DJAC) #607
thank you for all your help…
I really appreciate it!!
I will test it. DO you accept donations
(Bill S.) #608
No donation needed mate. I’m happy to help!
(DJAC) #609
ok so i tried this method and it seems to work but when i restart nothing happens.
also mine would only work if i put in
sudo systemctl enable docker harmony-api-server
:/etc/systemd/system $ ls
autologin@.service network-online.target.wants
bluetooth.target.wants pm2-root.service
dbus-org.bluez.service poweroff.target.wants
dbus-org.freedesktop.Avahi.service printer.target.wants
dhcpcd5.service rc-local.service.d
dhcpcd.service.d reboot.target.wants
display-manager.service remote-fs.target.wants
getty.target.wants samba-ad-dc.service
getty@tty1.service.d sockets.target.wants
halt.target.wants sysinit.target.wants
harmony-api-server.service syslog.service
harmony-api.service timers.target.wants
multi-user.target.wants
(Bill S.) #610
sudo systemctl enable docker harmony-api-server only enables the service(s). It doesn’t start them.
sudo systemctl start harmony-api-server and then sudo systemctl status harmony-api-server will start the service and then give you a status of it.
(DJAC) #611
Yes you are right. I have done that too.
That is the weird thing
i get this
sudo systemctl start /etc/systemd/system/harmony-api-server.service
Failed to start etc-systemd-system-harmony\x2dapi\x2dserver.service.mount: Unit etc-systemd-system-harmony\x2dapi\x2dserver.service.mount not found.
pi@raspberrypi:/etc/systemd/system $ ls
harmony-api.service
(Bill S.) #612
Run this and post the results: cat /etc/systemd/system/harmony-api.service
(DJAC) #613
$ cat /etc/systemd/system/harmony-api.service
<harmony-api.service>
[Unit]
[Service]
Restart=always
[Install]
Looks right!!
(Bill S.) #614
sudo systemctl start /etc/systemd/system/harmony-api.service
Run that ^^^ (remove the -server part).
(DJAC) #615
I get the same result
sudo systemctl start /etc/systemd/system/harmony-api.service** Failed to start etc-systemd-system-harmony\x2dapi.service.mount: Unit etc-systemd-system-harmony\x2dapi.service.mount not found. **_~ cd /etc/systemd/system_
**:/etc/systemd/system sudo systemctl start /etc/systemd/system/harmony-api.service** Failed to start etc-systemd-system-harmony\x2dapi.service.mount: Unit etc-systemd-system-harmony\x2dapi.service.mount not found. pi@raspberrypi:/etc/systemd/system
(Bill S.) #616
Ok, let’s try sudo systemctl start harmony-api.service && sudo systemctl status harmony-api.service
